Hi guys. I’m coming up to the shrouds in my build shortly and other than a picture which I’ll post, the instructions are a little bit silent on details. So I’ve been doing some research into ways of doing them and standard practice
Firstly I’ve seen from my research the the shroud seems to be served. But how much of the shroud should be served? Is it the whole shroud down to the deadeye or is it just for the loop around the mast
Also secondly I see that they are done in pairs.
So if one shroud goes to the forward most starboard deadeye, does the other go to the forward most port deadeye or the aft most part of the same channel? Or just simply next to it? I’m sorry if this doesn’t make sense...if it doesn’t please let me know so I can explain it better.BFE393A6-B8B9-493A-91E0-E31DA17BD324.thumb.jpeg.f25aa36464fa5124fc75de64bf978196.jpeg
Vinne:
You neglect to say what you are building. That said, I suggest you look at some examples on this web site. Look at EdT's,Young America clipper starting at page 76 where he begins working the shrouds. Also if you look at the Syren's,Cutter Cheerful you will see not all shrouds are served completely. Hope this helps.
Joe
Vinnie,  shrouds were indeed set up in pairs, each pair made from one length of rope with an eye seized into it to go over the mast head, so one length would go from the deadeye, up and around the masthead and back down to the next deadeye abaft the first one on the same side of the ship. Shrouds were set up as follows; first pair on the starboard side, second pair on the port side, third pair on the starboard side, etc.  If there were an odd number of shrouds, the single shroud was called a 'swifter'.  Swifters were sometimes made up from one length of rope with an eye seized in the middle to go from the after deadeye on one side, up over the masthead and down to the after deadeye on the other side.  Alternately, each swifter was made independently with an eye seized in the end to go over the masthead.
Shrouds were normally served around the eye where they went over the masthead and down several feet to prevent chafing on rigging around the top.  It was also common practice to serve the foremost shrouds on each mast for their full length to help minimise chafing of sails.
John
21 minutes ago, Thistle17 said:
Vinne:
Joe
Apologies thistle17...I’m working on the Bounty...and having a ball doing it :D
Hi Vinnie;
Your picture doesn't show it,  so unless it is shown elsewhere,  there was a rounded piece of timber,  the bolster,  set on top of the trestle-trees.  This was to ensure that the shrouds did not sit against a sharp edge,  and become weakened by it.
Also,  on many ships,  the shrouds were not the first ropes to go over the masthead.  If you are making a warship,  take a look at James Lees' 'Masting and rigging of English Ships of War'.  If it is a merchant vessel,  try Underhill's 'Masting and Rigging the Clipper Ship and Ocean Carrier', which is very well illustrated and informative,  written by a man who loved sailing ships,  when there were still enough of them around for him to have personal experience of them.
All the best,
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
Wow thank you Jim Lad that really helps...and you answered even the next question I was going to ask if you told me that both ends of the pair where on the same side and there was an odd number of shrouds! :o...mind blown
8 minutes ago, Mark P said:
Hi Vinnie;
All the best,
Mark P
Thank you mark p...It seems my kit doesn’t include this detail. I will also take this into account and will do some research. And then do some kit bashing
As I said I am working on the Bounty which I imagine was rigged as a merchant even after her RN refit. Thank you for the book recommendations, I need to build up my stash and will take your advice :D
The Art of Rigging, by George Biddlecombe, is an easily and inexpensively obtained book covering the shrouds and much else. I would not be surprised if you could get an eBay copy for under $5. Including shipping. Its got a comprehensive glossary and covers every important bit of rigging in excruciating detail. Not many illustrations though. Another good book to have is Wolfram Zu Mondfelds Historic Ship Models. Again, very inexpensiv. Mondfelds book has lots of illustrations on every page and covers broad swaths of gear rigging and techniques from all ship eras. You won’t regret owning either book.
Quote
 Niagara USS Constitution
Also good references to consider:
Darcy Lever, The Young Sea Officers' Sheet Anchor (A slightly later time period, though)
David Antscherl, The Fully Framed Model, Volume IV
C. Nepean Longridge The Anatomy of Nelson's Ships (Again, slightly later)
She’s a real beauty hellmhut. I love how weathered your deck looks!
It appears that you have served the part of the shroud that goes around the mast...if you have may I ask what your method was?
I’m glad to hear it’s worked well :) ...I discovered on another build log these “serving machines” and I’ve ordered one from domanoff workshop a few days ago. I can’t wait till it gets here!
Vinnie,
Check your sources for the bounty rigging.  She may have used catharpins on the shrouds as well.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
