I have used teabag paper to make a sail for a 1/64 boat. The paper was reclaimed from a used teabag and therefore has sound environmental credentials, but the size is limited. The photo shows a tea-stained sail glued to a wire mast; the seams are drawn on with pencil.
A quick search on the web for 'tea bag paper' shows several suppliers who offer sheets or rolls at low cost. My intention with Whiting is to use this paper for the sails, and even to try printing the seams on it. At my rate of building this is probably a year away...
George
George Bandurek
Near the coast in Sussex, England
Current build: HMS Whiting (Caldercraft Ballahoo with enhancements)
Previous builds: Cutter Sherbourne (Caldercraft) and many non-ship models
I have finally caught up on taxes, financial dealings for the nonprofit I am Treasurer for, my own savings accounts, and preparing a lecture - it has been a hectic couple of weeks - and can now get back to important things! I have a little bit of progress to report on the ship model.
I left off with the preparation of a sail, the main spar gaff topsail. The next step was adding the boltropes. These are on the port side of fore-and-aft sails where the linings were placed (on square sails the bolt ropes are on the aft side of the sail).
I made a few changes to my work area.
I stapled a sheet of parchment paper to the cardboard work surface (the other side serves as a cutting board). I also have a piece of parchment paper to place over the glued areas for heating them with an iron. The parchment paper seems to work better than the waxed paper.
The little Mini Iron II (Clover No. 9100) is a quilting iron for seams. I saw it mentioned in another post on the Forum as a plank bending tool. But it is also perfect for ironing the tablings, linings and bolt ropes after they have been glued. It is less cumbersome than a large iron and the  small tip gets into tight spaces. But I also used it to iron the entire sail after everything was finished. And now I have a plank bender too!
It is basically a 40 Watt/120 Volt soldering iron with specialized ironing tips. It has three heat levels, low (200F/105C), medium (390F/200C) and high(580F/295C). They recommend the low setting for silk.
I also mixed up some diluted white glue 50:50 with water. I like the white glue because it dries without a trace and you can loosen it if you need to with water or the diluted glue. The small clamps are essential to prevent the sail from moving while you are attaching the ropes!
boltropes2.jpg.8fe531bd46e81190e56e570ed80090ae.jpgThis sail has a larger boltrope across the head (1/2 diameter of the main topmast stay) and smaller ropes on the leech, foot and luff (1/4 the diameter of the topmast stay). I used 0.012" (0.30 mm) rope on the head and 0.008" (0.20 mm) on the other sides.
Note that the rope is glued to the port side of the sail (opposite the tablings) and not to the edge of the sail. This is the way the books say to do it and it gives a larger surface area for the glue to attach to. I do not plan to lace the bolt ropes to the sail edges as is done with real sails, because the lacing material would be microscopic.
At the corners I created a small loop "cringle."
This method requires a bit of patience. Of course the rope has a mind of its own and wants to be anywhere but exactly along the sail edge. So you have to do a little bit at a time and wait for the glue to dry before continuing. The little iron does speed things up a bit. There were a few places where I had to go back and reposition the rope so it was nice that the white glue can be softened after it dried.
boltropes3.jpg.74756a9d4ff57c1773d7ea8f1e38ac4a.jpgboltropes5.jpg.fe9f57bc7a477470a9171dc97381ce53.jpg
After the glue set up I seized the cringles with small stuff and white glue. This should place all the strain on the bolt ropes. As you can see in the photos there are a few small spots that can be reworked to get the rope exactly along the sail edge.
After the glue dried the small stuff was trimmed.
boltropes7.jpg.9876d69adcdb8cef89f04595243d20c5.jpgboltropes8.jpg.5765003e959da18e50b4bdd722263d2b.jpg
boltropes6.jpg.b779070196cdaae09fc6da686688b1e8.jpgThe ends of the larger rope across head of the sail were turned into a loop for a cringle and a short bit of rope was glued down along the top of the leech and luff. Small stuff was tied around the cringle for seizing. Here I did sew some small stuff through the sail material and around both ropes.
The head of the sail will be laced to the spar. For this I will sew the lacing through the sail material just inside the bolt rope.
Here is the finished (I hope) sail. Eight more to go (if I install the fore course).
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
I have been sidetracked for a few weeks but am now back at work on the sails.
I had to redesign a few of the sails. After reading about how sails are made I had to rethink the designs to make them as a sail maker would, using full 24 inch cloth widths where possible.
flyingjibnew.thumb.jpg.0cb3152402d52de1961e5a496acf911b.jpgjibnew.thumb.jpg.162f5a25171e61bb7250353619c1f83f.jpg
I changed the flying jib and jib to have a whole number of cloths along the foot of the sail, as well as adding the roach (curved foot).
foresailnew.thumb.jpg.d3e19f5160fb21fe08baf0bb18751b27.jpgmainsailnew.thumb.jpg.f603f20abdd8aa5be410f019e3cf50da.jpg
For the fore sail and main sail the design was changed to have a whole number of cloths across the head and foot - and the roach was added. The  reef bands were changed to 6 inches wide (1/4 cloth width) and two reef bands were used instead of just one (Lees, page 154-155).
I plan to install the foresail and mainsail first, along with their gaffs and boom. They are lower on the masts and will be "inside" all the other rigging for the topsails. They will have to be tied to the mast hoops, so I want to get them in place before adding all the additional rigging that might get in the way.
Edited by Dr PR
Phil
I have just plunged down the rabbit hole again, trying to learn how sails were put together. After reading through eighteen books describing sail making, I have concluded that whatever one author says another will disagree with it!
All agree that since the middle ages sails have been constructed with parallel cloth strips (cloths) that are sewn together. How they were sewn together and how wide the overlap of the cloths was is not always agreed upon. But most authors agree that for the last several centuries in Europe and America in most cases the cloth width was 24 inches.
Everyone says the edges of sails were lined with a bolt rope for added strength, and amazingly every author says the bolt ropes were attached to the port side of fore-and-aft sails and the aft side of square sails. This was the only thing they all agreed on!
The outer edges of the sail cloths (head, foot, leech and luff) were folded over and seamed (hemmed) for added strength. This was called tabling. Most agree on this, but which side of the sail was the tabling folded to? Almost none of the books say which side! The few authors that dare to venture a guess seem to agree that the tabling was on the after side of square sails. Some say the tabling was on the port side of fore-and-aft sails, but one author says it was on the starboard side (mainly on modern British racing yachts).
Some parts of sails were strengthened with extra cloth pieces called linings (although a few authors also call tablings linings). Most agree that linings were on the face of square sails (the opposite side from the tablings). Some say linings were on the port side of fore-and-aft sails (along with the tablings and bolt rope).
The reef bands were sewn to the forward side of square sails and to the starboard side of fore-and-aft sails. But one author claims reef bands were sewn on both sides of the sail. Another says reef bands were sewn under the leech linings. But if the reef bands are on the starboard side of a sail that means the linings must also be on the starboard side, and not on the port!
You have to love it when one author says white is black, and another says black is white. And which end of the egg do you crack first anyway?
And now there is Phil's way!
On square sails the tablings are on the aft side and the linings and reef bands are on the forward side. On larger ships bunt cloths and additional reinforcing bands are on the fore side. The top lining (to prevent chafing against the mast tops) is on the aft side along the foot of the sail.
For fore-and-aft sails the tablings and linings are on opposite sides like the square sails. Tablings are on the port side, Linings and reef bands are on the starboard.
Now I can get on with making the sails for the model!
Edited by Dr PR
Phil
I have sails at last!
A few have the tablings and linings but there still are a lot of details to add.
topsail.jpg.c25d71e86684555c36b7a1ba3a86192a.jpgThe model is 1:48 scale, where 1 foot scales to 1/4 inch. The sail cloths were two feet (48 inches) wide, and that comes out to 1/2 inch scale. I have a metal ruler that is 1/2 inch wide and that really helped me to draw the lines for the cloths and seams. It was also very useful for cutting the sails from the larger sheets of material.
I mentioned earlier that this sail material is pretty tough (when dry). I am able to erase any errors when drawing the pencil lines for the seams. However, although most of the pencil marks are removed it isn't easy to get the last bit, leaving a faint pencil line where it isn't wanted. I found a simple way to fix that - I just paint over the lines with the original buff colored paint I used to color the sail cloth.
Phil
I discovered a problem with my belaying plan for the lines from the main gaff topsail. I had routed these to the port and starboard bulwark pin rails.  But this had the tack and sheet pulling to opposite sides where they might interfere with the swing of the gaff. And the halliard had no tackle, but just ran straight to a belaying pin.
The topsail spar was fairly long and heavy; the sail and other rigging added to this. It would be difficult to lift it with just the one block at the top of the mast and no mechanical advantage. I added a ringbolt on the deck just aft of the port bulwark pin rail where the single block of a luff tackle will be hooked. The fall from the tackle will belay on the aft most belaying pin on that pin rail.
In the drawing the sail, sheet and tack are light blue. The topsail halliard is green, as are the main boom topping lift and the main gaff peak and throat halliards.
Here is the revised belaying plan.
The topsail halliard luff tackle belays to ring bolt 5 port and the tackle fall to aft pin rail pin 6.
The main boom topping lift tackles belay to ring bolt 6 port and starboard, and the fall belays to pin 5 port and starboard. The topping lift runs up inboard of the topsail halliard.
The main gaff topsail sheet, tack and brail (if any) belay to cleats on the main boom. This way the lines swing with the boom, gaff and sail.
I wouldn't bet that this is the last change I will have to make to the belaying plan!
Phil
I am sure that similar problems occurred in reality while a new lieutenant was desperately leafing through his copy of Lever's 'Young officers sheet anchor' to find the right page.
George
George Bandurek
Still here. I have been working out the supplies needed for my next model, the USS Cape MSI-2, and that has taken a bit of time. It is summer, and time for outdoor activities. Now I must do the taxes for a non-profit (I am the Treasurer). Then I hope to get back to the Albatros and finish the sails and start the rigging.
Phil
I have been ordering supplies for my next build, the USS Cape MSI-2, and planning my next moves on the Albatros.
Before continuing with the rigging I need to clean up some loose ends (literally) on the deck. I have belayed a few lines but I need to add the rope loops. While fiddling with some of these I broke a hook on the static lines positioning the pivot gun. I just bumped the cannon barrel and pop! one of the hooks broke. I have broken a couple other hooks while assembling the model, and this has made me rethink what I want to use for the rest of the rigging.
Hooks.jpg.0c4f432cf0c912903dd34e54c6a077d1.jpgI have been using the Syren plastic hooks (left in the photo). These are the 4mm hooks, and I am also using a few 3mm and 5mm hooks. They look good and are a uniform size. But I don't want to have to be replacing broken hooks after I have a lot of the lines already in place.
I decided to make some hooks from brass wire (right in the photo). I used 0.024 inch (0.6 mm) wire and formed it around drill bits that were the same diameter as the openings in the Syren hooks. The loops were soldered closed and then they were blackened with Brass Black. I was trying to make 4mm hooks, but as you can see my hooks are not as uniform as the Syren parts. Some look more like 5mm hooks.
I will use the metal parts as insurance against broken hooks. The model won't have a lot of hooks side by side in any place, so slight size differences won't matter.
Edited by Dr PR
Phil
I have some progress to report. When I find time I have been adding the bolt ropes to the sails. Here is a photo of the sail loft with work underway on the fore course and a finished fore staysail.
It is monotonous work. The rope tends to wander off from where I want it so I can glue only fairly short lengths to the sail edge at one time. I use a tool to hold down the loose end and "paint" diluted (1:1 with water) white glue along the sail edge, While the glue is still damp I use the brush to push the rope into place along the sail edge. The glue doesn't stick to the parchment paper on the work surface.
Here are the completed triangular sails laid out on the sail loft (kitchen) floor.
Now I am working on the larger sails (course, topsail, fore sail and main sail). They should be finished in a week or two. Then I have to put on all the reef points.
So far I have found no reference that says what diameter/circumference line was used for reef points. One source does say they were flat braided straps that came to a point. Well, I am not going to try to do anything like that. I think I will just use the smallest thread I have.
While adding the bolt rope I had a sudden "oh, no!" moment. The triangular sails used a lot of the 0.008" tan rope, and I realized that when I did the calculations to determine how much of each rope size I need I didn't include the bolt ropes! I went back to my spreadsheet and added up the lengths of bolt rope. Fortunately, I have a lot of extra rope on hand. I should have about nine feet (3 meters) of the 0.008" left after the model is finished.
Phil
Free at last, free at last! Taxes are done (I hope). Now I can get back to important things.
Next I need to add the reef points to the larger sails. But how long should they be, and what size rope?
As for the length, Steel (The Art of Rigging, 1796) says:
"POINTS, short pieces of braided cordage, plaited together as gaskets are; beginning at the middle with nine foxes, and tapering to five at the ends, and from one fathom and a half to one fathom in length."
A fathom is 6.0 feet (1.828804 meters) , so the points would be 6-9 feet (1.8 to 2.74 meters) long. At 1:48 that comes out to 1.5 to 2.25 inches (38 to 57 mm).
Falconer (Universal Dictionary of the Marine, 1769) says:
"... the top-sails are always, and the courses generally, reefed with points, which are flat braided pieces of cordage, whose lengths are nearly double the circumference of the yard. These being inserted in the eyelet-holes, are fixed in the sail by means of two knots in the middle, one of which is before, and the other behind the reef-band."
The circumference of the course yard on my model is 0.6 inches (15 mm) and the main boom is 0.66 inches (16.8 mm). That would make the course points 1.2 inches (30 mm) and the boom points 1.32 inches (33.6 mm).
Falconer's point length is a bit shorter than Steel's, but close enough for speculation. Half the length of the point lines will be hanging down each side of the sail, and at 1:48 that will be somewhere between 0.6 and 0.75 inches (15 to 19 mm) on each side of the sail, minimum. They could be half again as long using Steel's rule, or 0.9 to 1.125 inches (23 to 28 mm).
On my model the reef bands on the main (gaff) sail are spaced 1.5 inches (38 mm) apart. Looking at historical drawings and paintings I see the reef points from an upper band may extend from half to two-thirds the distance between reef bands. So I can use reef points from 0.75 to 1.0 inches (15 to 25 mm) on each side of the sail. I think I will use 1 inch (25 mm) on each side, so the reef point lines will be 2 inches (50 mm) long, with a bit of allowance (to be determined) for the overhand knots on each side of the sail.
Note: On square sails with multiple reef bands near the top the reef points are successively longer by a bit on reef bands from top to bottom. This allows for more sail material being gathered together by the lower reef points.
This leaves the question of what the reef points should be made of. I am not going to try to make 1:48 flat braided and pointed pieces. And I didn't include reef points in my calculations for the amount of rope I would need for the model.
I have a spool with 75 yards of tan cotton covered polyester thread (J & P Coates Dual Duty Plus) that is smaller than the smallest rope I am using (0.008 inch, 0.2 mm) and larger than the small stuff I use for seizing (about 0.003 inches or 0.07 mm). It is supposed to be for buttons and carpets, but now it will be used for reefing sails!
Edited by Dr PR
Phil
  • 5 weeks later...
Up to this point I have thought the most tedious part of this build was rigging the cannons. I certainly do not want to build a model with several dozen cannons on deck that need to be fully rigged!
But today I found something even more tedious than rigging cannons.
What you are looking at is 80 reef points (or just called "points"). 13 for the topsail, 25 for the fore sail, and 36 for the main sail - plus 6 extras. The fore course would have 17 more, but I plan to rig that sail furled to the spar and I don't want the extra bulk in the sail. It took several boring hours to tie all of these!
The points will be 1 inch (25.4 mm) long on each side of the sail. I experimented and found that the overhand knots will consume 1/8 inch (3.2 mm) of the point thread each. I cut 80 pieces 2.5 inches (63.5 mm) long. Then I tied an overhand knot in each, positioned 1 inch from one end. I placed a crop of white glue (diluted 1:1 with water) on the knots so they won't come untied. After that I dipped the long end of the thread in the white glue to stiffen it. This end will have to pass through a hole in the sail in the reef band.
After passing the long end through the hole in the sail I will need to tie another overhand knot in each point, snugging it up as close to the sail material as possible. Then the long ends will be trimmed to 1 inch long. I suspect this will be even more boring and tedious that creating the 80 individual points.
I am also working on my MSI model, and have it built to the point of planking the hull. That will be a slow process, installing one plank at a time and waiting for the glue to set. While waiting for that I will be doing work on the schooner model to finish rigging the sails.
Phil
Here are the sails with reef points installed.
Fore topsail.
Fore sail (fore gaff sail).
Main sail (main gaff sail).
The ends of the reef points are fastened to the sail with drops of white glue. Some will need repositioning to make them "hang" more realistically.
Now I need to add blocks for the sheets and clewlines to the topsail and ties to attach the gaff sails to the mast hoops. The topsail will be tied to the topsail yard and the gaff sails will be laced to the gaffs. Then I should be ready to start rigging the sails to the masts.
Edited by Dr PR
Phil
John,
Thanks!
I will need to iron the sails again before installing them. The wrinkles iron out nicely.
I have built only one model previously with sails - a 1969 model kit (Billings?) of the Santa Maria with paper sails. Only three sails with none of the details.
For this model I wanted to see how much detail would be needed. The sails and their rigging are almost as much work as the rest of the ship. I still have a long way to go before it is finished!
If I ever build another model with sails I think I will cut the silkspan into 2 scale foot strips and glue them together instead of drawing in the seams with pencil. When doubled like that the seams look more realistic when backlighted than the parallel pencil marks.
Edited by Dr PR
Phil
Well done Phil
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
That’s a great idea Phil… Of course you would add extra detail. 👍
Dowmer and John, thanks!
A nice thing about the diluted white glue (Elmer's Glue All) is it dries clear and is invisible. So it is perfect for gluing down the ends of the points. Even better, it is totally transparent when the sail is back lighted - although the glue is there it is not visible but the shadow of the points on the back side is. The combination of silkspan and white glue is very good for sails.
In an earlier post I said if I couldn't erase all of an errant pencil mark I could just paint over it with the same paint I used to color the sails and the mark wouldn't be visible. While this is true, the additional paint shows up as a dark splotch when the sail is back lighted! Not perfect! But most models are viewed with light from the viewer's direction so it really isn't noticeable. But is is better to not have errant pencil marks!
Another thing I have noticed is that some modelers use multiple layers of silkspan on each sail. I am not sure why they do this. One reason for using silkspan is that it is very thin, close to scale thickness for sail material. Perhaps for larger scales (1:35 or 1:25) a thicker material would be better, but there are several thicknesses of silkspan, I used the thinnest for this 1:48 scale model, and it is about 0.001 inch (0.0254 mm) thick, or about 0.05 inch (1.27 mm) at 1:1 scale.
Light weight modern cotton sail cloths are 0.012 to 0.025 inch (0.3 to 0.65 mm) thick (1:1 scale). So the thinnest silkspan is about a medium weight scale sail cloth at 1:48.
Edited by Dr PR
Phil
  • 2 months later...
I have a bit of progress to report. Work on the sails was tedious and the rigging promised to be even worse, so I decided to take a break from the schooner build for a while. However, I have been doing some small fiddly bits ever now and then so it hasn't come to a complete halt. In the mean time I have started my model of the USS Cape MSI-2.
While I am waiting for a wood delivery to continue the Cape I have started work again on the schooner sails. This reminds me of the tedium of the earlier build. Again, I am spending too much time on the floor searching for little pieces that suddenly disappeared!
Foresail.jpg.0a27ee05440bd07931d7eb33993b421d.jpgThis is the fore (gaff) sail with all the trimmings. I have decided it will be the first sail to be rigged on the model.
It is laced to the fore gaff along the top.
I have added lines on the forward (luff) side to attach to the mast hoops. These are looped around the sail and bolt rope and glued in place. The two ends will be wrapped around the wooden hoops and glued together on the inside of the hoop. There are 12 ties for hoops, and there will be a 13th spare hoop at the bottom.
Blocks for the sheet and tack tackles are attached to the cringles at the lower sail corners.
The tack luff tackle attaches to a ring bolt at the base of the mast and the fall belays to a pin on the fife rail at the base of the mast.
The sheet gun tackle attaches to a ring bolt on deck near the base of the main mast and the fall belays to a nearby cleat.
Blocks for the peak halliard and throat halliard are attached to the gaff. These halliards belay on the pin rails outboard of the masts on the bulwarks.
Pendants for the gaff vangs are hanging from the end of the gaff. The vangs attach to ring bolts just forward of the after pin rails on the bulwarks, run through the blocks on the vang pendants, and the falls belay to a pin on the after pin rails.
Under the jaws are blocks for the brail. The brail attaches to the sheet cringle, runs through the block under the jaws, and then belays at the fife rail at the base of the mast.
The next step will be to rig the sail on the mast.
Edited by Dr PR
Phil
The foresail is rigged (mostly) on the mast! I chose to start with this sail because it is low on the mast, and the hoops will be inside a cluster of rigging when the other sails on the mast have been rigged. There were quite a few "obstacles" in the standing rigging as it is.
I lifted the group of hoops to about the middle of the mast and used a clamp to hold them there. One by one they were raised or lowered to the position of the lines tied to the sail and held there with additional clamps until they were tied to the sail.
Near the mast top the standing rigging lines crowded the work a bit. Lower on the mast I had a bit more room to work.
Foresailrigging6.jpg.dbef698ee19c03187dfa062a464b0866.jpgThe two lines from the sail were wrapped around the mast hoop, one over the top and the other under the hoop. They were brought back aft and held with clamps. I put a small drop of fast-drying Duco Cement on the ropes inside the hoop to hold them in place. This cement dries shiny, but it won't be visible inside the hoop. On the outside the lines were soaked with while glue diluted 1:1 with water. After the glue dried the loose ends of the lines were trimmed close to the hoops.
The lines are not knotted around the hoops, but are held in place only by the glue. The hoops will be under no strain on the model so I hope the glue will be all that is needed!
Here is a picture of the sail fastened to the mast hoops. It hangs pretty good from the gaff and along the mast. However, there is a bit of crowding under the gaff jaws and a noticeable wrinkle in the sail. I can live with that.
The gaff peak halliard and throat halliard are rigged and tied to pins on the port and starboard bulwark pin rails respectively. The sail's tack is rigged to a luff tackle attached to a ring bolt in the deck just aft of the mast. The running end is belayed to a pin on the starboard side of the fife rail around the base of the mast.
I have not rigged the sail's sheet yet. The line and tackle are attached to the sail but are just held down with a clamp in the photo. I want to be able to pull the sail aside while I am rigging the lines for the sails on the main mast.
The sail's brail has not been rigged to the sheet cringle yet - I forgot it in the rush to get this sail hung! I may regret that when I get around to rigging it.
The vangs are still to be rigged after the main mast rigging is finished.
Here is a photo of the vessel as it is now. One sail down, eight more to go!
Note: The white paper "flag" on the lines from the jib boom is to warn me to not get tangled up in them. The dark brown lines are hard to see against a cluttered background. Immediately after rigging the jib boom a button on my shirt sleeve caught one of the lines and jerked the boom pretty hard. One of the jib boom stays broke and I had to rig it all over again! Just another one of those lessons learned the hard way!
Edited by Dr PR
Phil
Thanks John!
One more done.
The main sail is the most complex sail. In addition to rigging to the gaff and mast hoops, it also has the main boom rigging to deal with. The sail is "loose footed," and is not laced to the boom. The tack is tied to a ring bolt on the top of the boom jaws. The clew has the sheet rope attached to the cringle. The sheet runs through a sheave at the end of the boom and then forward to where it is stropped to a single block. A double block is tied to a ring bolt on the bottom of the boom jaws. These blocks form a luff tackle for the sheet, with the fall tied to a cleat on the port side of the boom.
The boom is supported at the forward end by the boom rest on the mast.
The aft end is held in place by the boom sheet tackles. Most drawings show the lower double blocks hooked to eye bolts in the deck. I rigged them to eye bolts on the bulwarks, with the falls tied to cleats (not fully rigged in these photos).
If the blocks were hooked to eye bolts on deck the tackle would fall on the tiller when the boom was swung outboard. And if the crew ever did haul cannons back to the stern chase ports the boom tackle would interfere with the cannons. So I rigged the tackles high.
There are eye bolts on the deck where the tackle also could be rigged.
The gaff is rigged pretty much like the fore gaff. The block sticking up above the aft end of the gaff is for the sheet of the spar gaff topsail. A smaller block is also hanging from the end of the gaff - it is for the flag halliard.
I designed the masts, spars and sails in 2D CAD drawings and used the measurements to lay out the sails and calculate the lengths of the rigging ropes. But the proof is in the pudding they say. I was pleased to see that things ended up in their intended places after everything was rigged. In particular, the gaff jaws are riding on the metal sheet on the mast, while the boom jaws are resting on the boom support. And the gaff throat halliard tackle hangs nicely and is not two-blocked.
Sometimes the best laid plans do work!
There are a number of lines still to be rigged. Port and starboard topping lifts will attach to the end of the boom, then run through single blocks on pendants hanging from the crosstrees, and down to single blocks that are part of a running tackle. The standing parts of the running tackles fasten to eye bolts on deck just aft of the pin rails. The falls belay to pins in the pin rails.
Like the fore sail, the vangs have not yet been rigged, nor has the flag halliard.
I rigged the gaff sails before the higher sails so the running rigging from the other sails would not be in the way of tying the sails to the mast hoops. But this created another problem. The sails block access to the pin rails from the opposite sides of the ship, and this makes it harder to tie ropes to the pins. It still can be done, for I have belayed the throat and peak halliards of both gaffs to their respective belaying pins. But it wasn't a simple exercise. There are 26 more ropes to be tied to these pin rails, and it will be a test of my patience!
Edited by Dr PR
Phil
The detail, planning and execution are amazing Phil.  You have set the bar very high with this work.  Very very nice!!
It is very exciting when you are on your boat, as the Captain, and considering things like stern chasers!  My favorite part of building so far.
Edited by Coyote_6
Steve
San Diego Ship Modelers Guild
I will need a couple dozen rope loops of different sizes to hang on the pin rails after all the lines have been belayed. I read through the topics posted in the Masting Rigging and Sails section of the Forum, and came up with a simple way to make these loops.
There were several different methods for making rope loops, but most involved looping some rope around pins, pulling out part of the first loop, and hooking it over another pin with a twist.
I used a scrap piece of wood that had been used to test different stains. Straight pins were hammered into holes in a diamond pattern, and then the tops of the pins were cut off. The spacing was designed to make loops that would just touch the deck when hanging from belaying pins.
The single pin "around the corner" from the loop pins is for the rope "eye" for the belaying pin to fit over.  It is removed when the loop is taken off the fixture.
You can see the basic arrangement on the right, and a loop in progress on the left. After the rope loop was completed it was soaked with white glue diluted 1:1 with water.
The fixture has five sets of pins to allow "mass production" of the rope loops.
The loose end from the first loop that makes the eye for the belaying pin will be trimmed off after the glue sets. The other end is pulled taut by the clamps while the glue sets. Then it is trimmed to about the bottom end of the loop.
Here are five loops made with 0.025 inch (0.63 mm) rope (left). On the right they are hanging on pins in a pin rail.
ropeloops025.jpg.8843ad7e4084195791bd754de09622c3.jpgropeloopsonpinrail.jpg.b0df3818222055f54463f36314a0424c.jpg
These suck! The eye that fits over the belaying pin doesn't wrap under the bundle of rope as it should, and it comes off at an odd angle, and not right at the top of the loops. This causes the loops to hang at an odd angle, and too high. When I tried to pull the loops down to a more natural position the glue failed and they unraveled into a rats nest of lines! It was a waste of good rope!
Punt!
I am going to have to come up with a better way to make rope loops. If anyone has suggestions I am "all ears."
Note: In past builds I have rigged the lines and then belayed them on the belaying pins, with sufficient extra line to loop them and tie them off as it is actually done on real ships. Those loops looked really good.
Edited by Dr PR
Phil
