Here is my new build. It will be for one of my daughters. It looks like it is going to be a fun build. I will be working on it at the same time as my other project, the Confederacy :)
I think I am just going to build this one out of the box.
Jean-Philippe (JP)
Current build: Syren , HMS Victory Cross Section, Essex
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: Rattlesnake (Scratch-built)
Completed:
Some parts were warped so I had to put them under clamps20190120_172413.thumb.jpg.5a003498fb9537c7cc838c01fed3e45f.jpg
Started to put together the hull. It was pretty straight forward so far.
20190121_145429.thumb.jpg.2f35c85fc98bed3d0d943b6aa0a23c33.jpg20190121_145847.thumb.jpg.636536b5e33800717ce482050fe27cea.jpg20190121_163100.thumb.jpg.2efdb0e763d6f55b9d4850f3af127435.jpg20190121_163146.thumb.jpg.9ebb5febc8d445789d17dad4e829f1cf.jpg20190121_170024.thumb.jpg.d5b8055412f2038b6f591ece01c8e348.jpg20190122_215122.thumb.jpg.c859cb2eade19eadaf716671d24f8c8d.jpg
Prepared the stern and drill the hole for the tiller.20190122_222627.thumb.jpg.7e376b97d5229dc05494f66f8fa8cbb4.jpg20190122_223112.thumb.jpg.ef5c0277657ebb065d3271ea33b73a53.jpg
Jean-Philippe (JP)
Completed:
Planking starts... After fairing the Hull, I started with the first plank.
Jean-Philippe (JP)
Completed:
Long overdue update.
Worked on first planking and completed it.
Next steps... Wood filler smoothing the Hull and second planking
Jean-Philippe (JP)
Completed:
After a long absence and lack of update, I am starting to resume working on this model.
Starting second planking of the Transom.
Jean-Philippe (JP)
Completed:
Started to work on the deck.
Removing the unnecessary portion of the bulkhead.
Planking the stern section.
20190424_233623.thumb.jpg.17b11415c6ec0aeff418099473fc60ee.jpg20190424_233633.thumb.jpg.fd196f4475f51a8b55de1e478ed39045.jpg
Jean-Philippe (JP)
Completed:
  • 2 months later...
Long break. My garage is small and I had to reorganize my larger tools and all my scrap wood.  Here are a few pictures of the progress. Imagine the planer and drill press on the workbench. Impossible to lay out plans and various projects. 20190702_094436.thumb.jpg.446b436438c9460d141ddc03301c4f63.jpg20190604_220227.thumb.jpg.81735953f165dc2dd2189dbdc1d92770.jpg20190702_094455.thumb.jpg.f5113bbd71f994232ae466c71b304b1a.jpg
Now to the ship update. I worked on the keel and double planked it.
20190701_223849.thumb.jpg.53fe43aa7441a616c2ced2420e2c5f39.jpg20190701_223846.thumb.jpg.492a0366ef7282b1c3e1bd4b64a9c2f8.jpg20190701_232115.thumb.jpg.70fcd1016928be299ac1593e9f488bb8.jpg20190701_233137.thumb.jpg.ace6325a35770e3670735f6a5c34cee0.jpg
Jean-Philippe (JP)
Completed:
Finished the Bow for now.
Planking the deck...
Jean-Philippe (JP)
Completed:
Small progress. I fitted and installed the railing.
Jean-Philippe (JP)
Completed:
Continued progress. Worked on ship wall support and Drilled hole for the mast.
Created fake doors.
Added the mast support.
20190811_222937.thumb.jpg.74cfa2242059cb1b610195872500aefd.jpg20190811_222932.thumb.jpg.76b7d6f68c2b5db95d671443c95ac0f7.jpg
Getting it ready for painting. I need to add a few supports and planks and it is priming time.
20190811_230357.thumb.jpg.3ced6d0967ae44efb31b153818fce6c1.jpg20190811_225835.thumb.jpg.c668073e95e5c4fb53ea6a3814c6d22b.jpg
Edited by captgino
Jean-Philippe (JP)
Completed:
Fixed a mistake with the railing. I misread the plan and forgot to add a plank under the railings.
20190816_213402.thumb.jpg.96ee0379373192c346b6a790b55819fa.jpg20190816_222954.thumb.jpg.81c2a72e6d0d7bfbba4e471dbd02df98.jpg20190816_222958.thumb.jpg.5a3aa4a140d355c17dd6c6b2667337e5.jpg
Better now. Moving to adding the bench support.
20190816_234524.thumb.jpg.7c8abed439836bb5b66bfc947de7d64f.jpg20190817_075133.thumb.jpg.195e23506676ab8ced3de3a7f7651439.jpg20190817_075117.thumb.jpg.c50a3753c65f112dae1b2b8a00d22a35.jpg
Jean-Philippe (JP)
Completed:
Continued to work on the front of the ship. I am trying to install everything needed before priming and painting the SHIP.
20190822_230556.thumb.jpg.dbd90c28c1c03e7073aba67c1113480a.jpg20190822_230550.thumb.jpg.2fd4c5ecdd1551d0153428fe94fd5c2f.jpg
I also did a final Sanding of the Hull and removed all dust with mineral spirit.
Working on the rudder.
20190823_233631.thumb.jpg.715320b0120db7986d4280b92382eadf.jpg20190823_235942.thumb.jpg.b6be8ab475478cac4135ca5454b910f3.jpg
Jean-Philippe (JP)
Completed:
Painting time. I did not capture all steps as I was caught up in the process.
Primed all the model. Painted Hull black and inside blue.
20190917_215806.thumb.jpg.ae1478f222253e5682b7528dbd329626.jpg20190917_215736.thumb.jpg.11416985e15dfe8fd21ba3a43544c77d.jpg20190917_215723.thumb.jpg.eacd08fb1df8094413f23d2afef29b70.jpg
After doing some research, the first part of the ship was red so I corrected that.
After it all dried, I sprayed a coat of clear matte to protect the ship.
Jean-Philippe (JP)
Completed:
  • 4 months later...
Quick update and small progress on the rudder.
Jean-Philippe (JP)
Completed:
Working on the rudder continues... A liitte soldering and voilà!
I still have to touch up the paint which was a little bit damaged in the process. 😕
Jean-Philippe (JP)
Completed:
Rudder attached and a few more details...
Jean-Philippe (JP)
Completed:
Dead-eyes and chain plates in position.
I will be starting masts either tomorrow or the day after.
Jean-Philippe (JP)
Completed:
Completed the mast and gaffs construction. Next steps will be finalizing any sanding touches, staining and painting.
Jean-Philippe (JP)
Completed:
Painting done. I am waiting for the paint to cure before putting one or two coats of vernis.
Jean-Philippe (JP)
Completed:
Time to start the rigging.
Attached the mast.
Worked on the shrouds by serving them, long and tedious process 🤪 then fasten the deadeyes.
Finalized attaching on side.
20200404_230429.thumb.jpg.7e423273363ec948b3e7a0bb79366566.jpg20200404_230436.thumb.jpg.db8b19b6427f87dce7606d6571513174.jpg
Jean-Philippe (JP)
Completed:
