Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
While awaiting laths to dry to continue building up the bow cheeks, I built the Mamoli jig for shaping the bow main rails. These laths are 1mmx1mm, 1mmx2mm and 1mmx3mm, shaped, glued together and then edges chamfered. Next, look up ‘chamfer’.
Rob
active projects: HMS Victory, Mamoli 1/90 scale
Initial results were positive from the jig above. Now assembling the rail elements before the chamfer process.
Rob
Still working the bow cheek build up.  I’ve had trouble shaping the 2mm x 3mm walnut laths ‘against the grain’ and after looking in the forum help section was able to find a topic addressing this.  While the wood demonstrated seemed to be a little less wide, there were some good suggestions.  I actually boiled some water and put the walnut pieces in for about 10 minutes and was able to get a better bend with my shaping iron.  You can see pictures below.  I’ll resume the cheek build up in the next few days.
I’m also working to chamfer the main rails created with the Mamoli jig.  They were shaped, dried and then glued together.  It’s not too easy holding these down, but slowly am able to take the edges off.
Rob
Here are the BEFORE pictures of the ‘finished’ bow cheeks using what I understand are the Mamoli directions. However, I’ve not added all the layers they suggest as the cheeks would extend 8mm from the bow surface at their widest point. These extend 4mm. Next is to continue sanding, add minimal filler and sand again. Then on to the main rails.
Rob
Well, here WAS my bow section.... What a mess. I’ve since dismantled everything on the bow and am starting over including removing the main rails. The dismantling process went well and I’ll be able to reuse most everything. I’ve got some good bow section examples to study further and hopefully I’ll be able to laugh about this debacle later!
Rob
Just a thought..
Those rails will really get in the way when you start doing some rigging; particularly the bowsprit gammoning..
You might think about getting all your parts ready and mounting them permanently at a later time..
― Jimmy Buffett
Current builds:    Rattlesnake
On Hold:  HMS Resolution ( AKA Ferrett )
3 hours ago, Gregory said:
Just a thought..
Thanks Gregory; appreciate the advice. However, I’m planning to finish the model ‘hull down’ per the below picture.  Will that still be an issue in this case?
Rob
Here is the first step back. Symmetry is much better looking down, however the port main rail ‘bow’ appears more significant. This may be OK... depending.
Rob
Nice concept..
I think the gammoning might still be an option that would fit in, but it would be up to you..
― Jimmy Buffett
Just another possibility for consideration.
The Confederacy comes without rigging plans and is presented with this image.
I think the bowsprit without the stub masts might look a little incongruous..  But, that is my personal opinion, and has no bearing on what is considered proper..
Consider the painting of Enterprize:
No bowsprit, no masts.
― Jimmy Buffett
Thank you for the examples Gregory. In my opinion this is a better option for displaying by taking up less room but still looks good.
The bow work is coming along and looking better, in my opinion.
Rob
Bow progress as of this morning. Grate work is challenging as they fall apart and need continuing glue application. Especially when shaping them.
Rob
I replied in my log but thought I would put it here also.
Rob,
We are staying in Florida as long as possible but have to be back to Jersey in mid April for some doctor stuff. Hopefully we do not have to stay in Jersey long and can be back in New Hampshire by mid May.  We have to be flexible because doctor decisions keep us around sometimes.
Let me say that the Santa Maria is a difficult ship. Being away from building takes time to recover and you have to do a big review of what you are doing.
Continuing to assemble the bow finishing elements.  Still can’t adequately bend the 1.5mm x 3mm walnut laths laterally without breaking them.  This is after a 2 day soak and using an electric plank bender (see earlier section in my log if interested).  I’ve come up with a non elegant, but working solution using a 5mm  plank and cutting it down to 3mm and manually adding the curve.  The original, unbendable walnut lath on top, the replacement 5mm lime lath (left over planking) and cut out/modified piece.  The resultant attached piece is shown (unpainted).
Rob
Starboard side ‘roughly’ completed. Need to correct the forward rails extension over the main rail.
Rob
nice work, that's certainly a difficult bend.
you may consider styrene strip for such difficult parts, especially if the model is painted as yours.
another option is the "flexible beech" sold by Cornwall in several dimensions. That's a chemically treated wooden strip, and you can tie knots on them even dry, but after soaking can be formed to any shape, which is well retained when dried again.
Past builds: Prins Willem,  Amati Coca
Current Build: Occre Diana
Thanks for the insight David! I’ll take a look.
Rob
Working some of the detail as I complete the bow area. The knightheads are 3mm x 3mm walnut laths that I used a small chisel with the laths held in a vise. The grates did not turn out as I had hoped.
Rob
Marine’s walk with accompanying grate (1 of 2).  I’ve tried a new approach to mitigating the grate brittleness with associated breakage by gluing the side grates (see pencil point for one) on each of 4 sides and then I was able to successfully tailor the sides without the whole thing falling apart.  Still some additional work to get it to properly fit.  Next pictures will show the completed item installed.
Rob
Still working on the bow finishing and have painted and installed the starboard false rail.  These rails are made of lead and you can see where they don’t seamlessly interface with the main rail.  The lead will break if I attempt to bend it, even a little.  My thought will be to shape and put a piece of wood in the gap.  I’m not aware of any more elegant type solutions.  Lesson learned may be to fit the false and main rails while shaping the main rails to minimize that gap.   There is a larger gap on the port side.
Rob
Hello everyone!  Hope you are staying safe and healthy and that you/yours have been safely vaccinated.  Summer is nearly upon us and I'm taking this opportunity to step away from the shipyard for a bit to enjoy the nice weather and do some outdoors type activities.  I've been briefly in/out of the shipyard to complete the bow area and will be in the later summer/early, GLW, ramping up working on finishing the quarterdeck area moldings, etc.  I'm also reading 'Nelson, a Dream of Glory' by John Sugden to get a better understanding of Nelson's earlier years and exploits.  So far, fascinating reading.
Please be sure to have a safe and enjoyable summer season and keep up the good work on your models!
Rob S
Rob
Rob, As a Nelson fan, if you have not already done so, please consider signing up for the Trafalgar TV series and Adam Preston's podcasts.  Details on the series are in the Nautical/Naval history forum posted by Adam.
Cheers
Allan
  • 5 months later...
Time to start restarting the shipyard as the temperature dips below 40 degrees Fahrenheit and we are moving into Nov. Now working to finish the quarterdeck which requires a lot of precise, detailed work. We’ll see how it goes.
Rob
  • 2 months later...
Beginning the finishing of the upper and quarter decks. I’m not very good at creating the small column structures from 3x3mm blocks 20mm or so in length as you can see below. Will be looking for more reliable methods for creating them.
Rob
