Whoa! Back up the train! What’s the kit? Are you using aftermarket or Scratch? Tell us a story!!
These  big BB’s are a massive bit of plastic (the bride would kill me if I went this big, I’ve got too much 1/350 in extra PE).
Greg
The kit Trumpter 1/200 the RC is after market. I will need to add rudder servo, speed controller, battery pack and receiver. Lights and other moving parts are in the planning stage. Also using PE kit.
Edited by jock2000
On 7/10/2019 at 9:10 PM, jock2000 said:
Started on some small bits with PE. I don’t know what this is and can’t find a reference, maybe someone can help.
Maybe if you give us some perspective as to where these fit on the ship we could help
Current Builds
Mikasa by I Love Kit - 1:200 - Plastic
HMS Beagle by Occre - 1:48 - Wood
Hello Jock2000,
The object you are asking seems to be "Pom pom gun director". The_Royal_Navy_during_the_Second_World_War_A3651.jpg.722ffa4c47fd9070a0a7062a22cbf6d5.jpg
I found Trumpeter kit instruction by chance(https://issuu.com/modeland/docs/03709), and instruction shows the object to be glued corner of "director control tower platform".
But I believe there should be single 20mm Oerlikon MG in this position when she adopted atructive camouflage.
Above image is from Pontos grade up set.
And my 1/700 model of Rodney(https://photos.google.com/share/AF1QipNVs5uetAQMQkkC2WQZiGWTZbEHBS4RZXcPzqHA1inJubKjROC32A-155Dr_oe0ZQ?key=eHlrY1pHSEwweEUtZHB3azNlU0VHY2p0N3Nodzl3).
Unfortunately Trumpeter kit seems to be "chimera" from different time frame of Rodney. For example painting instruction shows her 1942 camouflage pattern, and "most of" AA gun positions seems to be right in her 1942 configuration. OTOH, kit PE parts for radar on both mast peak seems to be Type 279, but they should be Type 281 in 1942.
Also Trumpeter kit shows quadruple 0.5"MG on aft corner of bridge structure. They are right for her earlier war years, but this should be replaced pom pom derector with Type 282 radar. Below is instruction from Tom's Modelworks 1/700 PE set and shows these alternation.
Of course this is your model, and you have privilege to decide how to build your model. But still I hope my info of above would be help for you.
Regards,
Mitsuaki
Edited by fake johnbull
Mitsuaki Kubota
Current building: HMS Bellerophon (1786)
Recent completion: IJN Hiburi Class Kaibokan Escorts/ Pit-Road 1/700
                                  HMAS Vendetta/Showcase Models Australia 1/350
                                  HMS Nelson/Trumpeter 1/700
                                  Mayflower/Airfix 1/96
                                  USS Powhatan/scratch 1/400
                                  HMCS Snowberry/Revell 1/144
great build so far......... :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
To get some relief from the Pom Pom I started on the aircraft while searching for information I found this video on the launch and recover of a Walrus it showed great detail.
