Thanks for all the likes and the comments!
I made the barrel from a dowel rod.  I used card stock to make the banding.
I cut the other pieces out of basswood and glued them together.
I will add more banding after everything dries and I can base coat everything.
The barrel is just sitting in the carriage.
Edited by GrandpaPhil
Building:
It’s mostly painted now.
I’m waiting on the glue to dry so I can final paint it.
I used faux metallics for the barrel and the banding.
Once the bombard dries, I need to touch up the paint and do a little more dry brushing and highlighting.
Building:
That's very good Phil,  do you use these side projects or just display them?
If you use them, do you have many armies?
Edited by Edwardkenway
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
very nice. brings back memories. in former Czechoslovakia, there was this magazine published, called ABC. each issue coming with card model, mostly for beginers, but over the years, plenty of complex and complicated models been released. my personal favourite, MPR https://images.app.goo.gl/hRyWzyzbgUS8naqb6
back to your bombard cannon.
in one of the issues, there was a 3d model of the bombard cannon (or its reconstruction according to different sources). i will not post the model here, because it is not public domain, but i believe it wont hurt if i post the instruction drawings. the cannon was meant to be made out of paper and a crayon.
i must stress, this is not public domain. i also have physical copy of this model. (electronic copy too, for archive purposes).
reason i post this is that on this plan there is also a plan for "accessory". sort of "gun port lid"
Edited by maaaslo
Pavol stands for Paul, Pablo, Paolo etc. Please do not try to pronounce it, just call me Pav...
the cannon looks really neat Phil.......very creative ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
