Capt. Mike
Quoddy Boat YANKEE HERO by Capt. Mike - Bluejacket Shipcrafters- Scale 1:32 - - First kit in 40 years - SMALL
Good morning, all!
This is my first model in 40 years and my first wooden kit ever. Luckily, as a sailor of traditional vessels, I have a little basic knowledge to fall back on.
I have elected to start with the Bluejacket kit YANKEE HERO, and since it's a snowy day here in Massachusetts, I am making fairly rapid progress. I've got he hull shaped, the hold and cabin top assembled, and I've just glued the deck to the hull and am waiting for the glue to dry. Wish me luck!
Capt Mike
Share this post
Link to post
Share on other sites
I have fond memories of my first model the Yankee Clipper.  Putting the primer on really will help show any imperfections in your hull shape.  Just sand or putty as needed and another coat of primer.  You are doing great!
Share this post
Link to post
I laughed when I saw your reason for editing your first post. Thank you for taking the time to read that! I did tweak your title just a bit to show the complete name of the manufacturer; I like to do so for the benefit of interested newcomers who may have never heard of the company before. Looks like you have made a fine start on your model.
Share this post
Link to post
I had a discussion with True North about the paint coverage. Their supplier of one of their solvent bases changed formulas, but didn't change part numbers or tell them. TN has re-formulated their paints and they again perform like they should. Would you like a new jar of white?
Nic
Share this post
Link to post
That would be great. Thank you! My solution for coverage was to put several layers on, and it literally takes days to dry. Being impatient I went ahead and tried to work on the model anyway, with regrettable results.
A good jar of white paint would at least let me try to re-coat the white coamings and mouldings once I am done!
Share this post
Link to post
I f***ed up the cabin yesterday. It was sliding in OK during the fitting stage, but since the fit was very tight I had decided not to force it all the way.
When it came time for the final installation, it would not seat all the way, so 1) I applied too much force and broke the coaming and then 2) I had to pry it out again and dig out some more of the hull before it would fit back in correctly. Thank goodness I had not used any glue!
The cabin fit fine after just a little more digging out of the hull but the cabin & coaming are definitely the worse for wear and are no longer 90 degrees. Hopefully the moulding and some more white paint will cover up the worst of it.
My poor wife just looked at my my face and walked out of the room.
Today was better. I glued on the bowsprit and main traveler and the wales strakes and then taped and painted the hull.
Share this post
Link to post
A good day today, assembling the spars, second coat on hull, etc. Nic from Bluejacket was kind enough to send me some more flat white. In the meantime I just prime anything before painting it white.
But here I'll have to leave for a month while I am traveling. This build is not abandoned! Just "on hold" until January.
Share this post
Link to post
After taking the winter off to drive across the country with my wife, I am back on the job. Quarantine leaves lots of time to fill :) The mast is stepped and the spars are assembled. Now I discover that it literally takes me five minutes of fumbling to tie an overhand knot with thin thread!
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
