3 minutes ago, Rob S said:
Hi Emmet!  I'm responding to your question about the nails in my planks (Rob S: 1/64 HMS Victory by Mamoli). I soak my planks before shaping them to fit on a given section. Once they have been shaped and fitted, I add the wood glue to the plank underside where it will be touching the bulkhead sides, etc.  Then, after applying the glue and when actually attaching each plank, I typically start at the bow and with my 'loose hand' (one not holding the plank in place) I push in a small nail as far as I can and then with a small hammer, tap it home.  I do that for each plank/bulkhead connection as I move aft.  Once the planks are in place for several days, the nails can be removed. The nails were included with the kit.  Finally, be sure to check out Y.T.'s HMS Victory as he is a master at planking and shows the nails as well.  Your build looks great and best in future work! Rob S.
I follow YT and a few others.  MSW certainly helps me understand many ways of doing things.  Thanks for the details. What I was wondering is the size of the nails and the size of the hole. The hole has to be big enough not to split the plank but small enough to squeeze the plank against the hull.  I have use some small nails and removed them. I like the way they work.  But I am still experimenting with various ways.  Rubber bands work great along with push pins.  The problem I have with the push pins is they do not come out easy enough.
Thanks for your help.
27 minutes ago, GrandpaPhil said:
I like straight pins (heavy sewing pins).  I remove them with needle nose pliers.  Use a twisting motion to get them to release.
Thanks for your ideas.  The help you give is very encouraging to us new people.   I have studied most of your pages.
Do you drill at all or do you just stick the needles through the wood?
On 1/12/2020 at 3:25 PM, GrandpaPhil said:
I drill with a very small drill bit if needed.
I also have a tack hammer that I use (preferred method).
Thinking about it a sewing needle is wedge shaped.  I have been using a 1mm drill for push pins and tiny nails.  The push pins do not want to come out whereas the nails are difficult to handle-but they work and they come out.
Thanks again!  Have a good night.
Edited by Emmet
adding media
No need to. Just continue to add posts -- the page will roll over once it reaches a preset post count.
Thanks you
Edited by Emmet
adding media
On 1/23/2020 at 9:41 AM, Emmet said:
Thanks you
There is no way, short of paintng the hull, that I can solve the messy work with super glue on the finished planks. I sanded a lot but I am too close to going through the 0,5 mm planks. I could probably do a better job today but, again, with having to install planks that are reduced down to 1.5mm with tapering I have to find an alternative for future jobs.  Perhaps a longer lasting CA glue might give me time to apply the glue more carefully or find a way to clamp the planks.  At any rate I am going to carve the serious blotches, redo and accept it as my first ship.  I do not think a varnish stain would solve the problem.
Edited by Emmet
adding media
2 minutes ago, VTHokiEE said:
What type of CA glue did you use? I think using CA takes a lot of practice, but maybe a gel version for things like planking would help prevent the stains.
Thak you for your interest.
Just as an aside I have looked for details on planking on this site as well as others and found no help.
I started out using Pro CA- medium gap filling by Great Plains. I used toothpicks and poured the glue onto an open surface. The ~12" planks had to be tapered to 1.5 mm and curved upwards as well.  I just could not get the glue (in there) without a mess. I am shortening this comment.  I would apply glue to about 1.5-2 in. press down and wait. sometimes there would just be too much glue and too little. In any event it was not working.  So then I tried using the original super glue wit the small spout.  That seemed to work better but it was still too messy with the small planks.  After that I went to Loctite CA glue with a brush.  That was more effective at getting the job done but still too messy. I went ahead and decided I would sand away. That turned out to just be too much to remove the excess glue.
Recently I am trying Gorilla CA.  I will put a picture on as soon as I finish this reply.  I found that I had more time with this particular application.  Wheter the nature of the wood is different I do not know. This also not planking which is far more difficult.
I would add that I have built cabinets and other furniture and never had this difficulty.
For laughs-I confess I used super glue to fix a tooth on a plate temporarily and it worked just fine.
Thanks again
It can be tricky to find, but it is available here.
I went through most of those if not in detail  I have seen alot on the way to organize planks and the different ways of filling in spaces. But as of yet nothing in detains  about exactly how to apply the CA glue  the planks or the hull.  By and large the detail is missing.  I believe I have downloaded every one of those pdfs.
Ah. I have used CA on all of my hulls up to this point, but never on one that I intended to leave as bare wood. Leakage between planks and even through the wood itself comes with the territory with CA. On my latest model, I have used a product called Rapidfuse from DAP. I believe it is a CA derivative, but not nearly as messy. It sets in 30 seconds and is completely dry in three minutes. With any CA product, it is important to apply the bead of glue down the center of the plank, because it will spread when pressure is applied. Hope this helps a bit.
All ideas are helpful. I see it is about $12 for two 0.1 oz tubes and $19 at Amazon for 0.85 oz.  I will definitely keep that in mind.
I realize skill is part of this as well. As I have said the planks were tapered from 3mm to 1.5mm-tough to find the center.  Often is put it on the plank with the 3mm part and then on the hull for the 1.5mm pieces.  Bear in mind it was the first time I used super glue in this fashion.  Plank planning on the next ship will include working with CA.  I have actually entertained the idea of doing a partial on the first planks and using pva with clamps until forced into CA.  But we shall see.  I am also not at my home base. At home I have more ways of dealing with difficulties.
Let me add that I am enjoying the many challenges of building. There are many more to go.  I just have to see this as a learning process,
Thanks fo ryour help.
That doesn't sound right. I got a small bottle (0.85 oz) at the hardware store for about five or six dollars.
20 minutes ago, VTHokiEE said:
I would recommend going to a physical store for DAP Rapidfuse where it will be cheaper; I see it at Walmart for around $5 and Lowes for about $6 (or buy it online from a different source).
Got it .Thanks
Usually I go to Walmart and do a pickup but I did not see it there.  I guess it has to be ordered and shipped.  Thanks!
shopping pays
As I said-shopping pays
On 3/10/2020 at 10:48 AM, VTHokiEE said:
I've found these videos are helpful as well regarding another planking method:
I will definitely spend time with this. I have seen videos on utube but not as good as these.
Edited by Emmet
adding media
I need to say that I have many different things going on to accomplish the rigging.  So while my pics look somewhat helter skelter it is all about rigging.
Edited by Emmet
adding media
Fascinating and well illustrated log; I think I can learn from your planking exercise....and other build practices. Very well done.  Looking forward to pulling up a chair, kicking back and enjoying the journey with you.  Hope things get back to normal soon!
Rob
active projects: HMS Victory, Mamoli 1/90 scale
Thanks
I meant to say that I invite criticism of my pics and explanations.  It takes some time to portray the work. I try to say as little as possible and I wonder if it is enough.  I am trying to try to lay groundwork about the difficulty in doing the first ship.  There is so much to learn.  I want to be able to look back and review the log when I start my next ship.  I enjoy your log because you seem to be giving more detail than other logs.  The guys who have a lot of experience don't bother with certain details that they learned a long time ago.
"if in doubt ask is the engineers gospel" - if you want to know anything there are plenty of people who will answer you with a specific question. but we all had to go through the learning curve! there are plenty of books explaining the basics too- local library might have some?
Keith
I have many books at this point-kindle is useful that way.  I also have downloaded everything that makes sense to me from this site as well as from other sources.  utube works but not necessarily for La Nina. It is good for some general understanding. Thanks for your input.  If you know of a specific book please advise.
Hi Emmet
Great ship I have also been thinking  of building an older ship
Keep up the great work Cheers snowy
This is Emmet. I am finished with La Nna. I will be starting Santa Maria soon. Have to get home.
