It was again time to dry fit all the components so far. But before I did that I added some eyelets, made holes for additional future eyelets and added blocks to the installed eyelets on the bowsprit cap. Then I assembled them all together.
Something wasn’t right – it was too cluttered. I didn’t like the two hearts which were on either side of the bowsprit. I had made them separately. Looking closely at the drawings and books again, it appears the hearts were both on one same sling. The hearts were removed and a new double heart sling was fashioned.
Knowing that the bowsprit and the jib boom had yards slung from them and therefore need slings made, the spritsail yard and the spritsail topsail yard were constructed. Again this is following the philosophy of making everything I can off-ship before stuff is nailed down, as it were.
Hi Jon,
just had a look into your build log, a very nicely built model, the rigging and masting so far also Looks great
Nils
Current builds
-Lightship Elbe 1
Completed
The bowsprit yard has a thimble spliced loop sling (technical term right?) Actually depending on what source you are looking at, there is a thimble or not. I chose to use one. Again, the line was served and then one end of the served line was wrapped around a stock 3/32” brass tube to from the loop and seizing to the right size.
A piece of the tubing was then cut off from the stock material about the same thickness as the seized line. Using tools I bought for making jewelry, I used a bead reamer to flare out the inside hole of the brass “donut” on each side and filed a groove around the outside edge to hold the line in place. Then it was just a matter of placing it inside the line loop.
It was at this point I realized I now had a problem as how was I going to get it on the yard. This component should have been made and installed before the cleats were glued into place. Then the line would have been formed into a circle with a pseudo splice. The circle would have been cinched and seized to form a figure 8 with a smaller loop on top for the thimble. The larger loop would then slide onto the yard. Of course the dimensions of the initial circle would have had to been dead on.
But I didn’t do it that way. Instead I had to glue in increments first to put it into position and then to wrap the two open ends around the back to cut them to size so that they would butt up to each other. Then I glued them down.
Maybe the way I did do it was easier, I don’t know.
The spritsail yard has rings on it for the guy pendants. Actually they are thimbles on a metal band that wraps around the yard. To simulate this, the metal band is simple thin strip of paper cut from some plain copier paper and colored black with a Sharpie pen. The eyelets that came with the Mamoli kit are 3 mm f which I thought were way out of scale so I used ones which were about 1.5 mm to make the thimbles.
After doing a bit of research (thank you Blue Ensign and Gil Middleton) as to how to make the stirrups and foot ropes, I came across (for lack of a better term) the Micro Pseudo Splice. I looked at a number of builders’ methods and this seems to be the best (to me at least). Because of the small scale, making a real splice is neigh impossible and making it look to scale. This method is real simple (because even I could do it) and the results are clean. I drew up the method as shown below.
Edited by JSGerson
The methods work well to add a loop splice to an eyelet or in this case just an open loop. To create the open loop, I used the long end wire of an eyelet. When completed, the loop was slid off leaving an open loop.
Once I had four stirrups made and wrapped around the spritsail yard in the proper position, I inserted a music wire which had the same diameter as the eyelet through the stirrup loops and made sure everything was level and even. I used a clothes pin to add some weight to the wire to keep the stirrups taut. The wrappings around the yard were then glued into place and the vertical lines were “painted” with diluted PVA glue to stiffen them up.
After everything had dried and the excess lines trimmed, the music wire was removed leaving four hanging stirrups perfectly vertical, properly spaced, and horizontally even. The foot rope had a pseudo splice made at one end to slip on the outer end of the yard. Once the foot ropes were threaded through the loops using a needle threader, the inner end was wrapped around the yard itself like the stirrups.
Spritsail Yard and the Spritsail Topsail Yard
Neat trick but I'm still a little lost on exactly how you did that.  Can you provide some closer pics of those lines.  I'll be headed here probably in a week or two and I had a different idea on how to creat those lines.
Sorry for the delay in responding but I was at the NRG Conference in St. Louis last week and just got back today (19 Oct 14). Trying to respond to email on an iphone is hard on the eyes. I don't know how those young kids do it. So onto your question. I had a great time by the way.
I can't take credit for the method I showed. I am following Blue Ensign as he builds the HMS Pegasus (starting at comment 696 for the foot ropes) who by the way credits Gil Middleton for the pseudo (my term) splice. See, we all help each other. See if Blue Ensign's more detailed descriptions help. If you still have questions, please feel free to ask me again.
Dude, I so do not have that skill level.  I'll have to come back and visit these pages again.  I'm working on sanding down the yard arms to their propery dimensions at this time.  As it seems you are working on a different portion of the ship, looks like I'll have to go digging for examples somewhere else.   I so bow to your skills.  Not worthy.... not worthy.  LOL
My skills? I have never done this stuff before! I'm learning as I am going which is why I'm moving as slow as I am. I just taking one step at a time, trying to make as few errors and do-overs as I can, but no matter how I try, I make a bunch of them...I just don't post most of them 8-)
Installing the Bowsprit
I had gotten as far as I could with the bowsprit and its constituent components; it was time to install bowsprit. I used epoxy glue at the base of the bowsprit and slid it into place.
Using .45mm Syren Ship Model Company black miniature rope, the gammoning, was started with an eye splice and then threaded through the grating, through the gammoning hole in the stem, and back up top four times.
Then it was wrapped around the vertical lines horizontally half way down under the grating. The horizontal turns were supposed to equal the number of vertical turns but elected to do only two. The space was quite cramped and even with a light aimed directly in there, it was hard to tell there was any wrapping at all.
Nice details on the head, Jon. That gammoning can be tricky -- mine came loose numerous times as I was wrapping it, and then I realized I had done it incorrectly and had to redo it.  I like the way your Seats of Ease worked out -- they make me wish I'd been more persistent in trying to fit them in.
Good work,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks for the kind comments Martin. The Seat of Ease is based on Pasi Ahopelto's model (before the site crashed). He has since resumed his log but he has not re-posted all that was lost. At the time I was constructing it, I had not seen (or at least recognized) one on other models so I followed him. Now I see that his design appears to be a bit unique in the triangle shape. Still, it works for me.
Bobstay
The Bobstay is a fully served line with one end passing through the stem and fastened to itself in front of the figurehead as a long loop splice. The other end is looped spliced with a heart. The heart is lashed to the heart installed earlier under the bowsprit.
Bowsprit Shrouds
The bowsprit shrouds are fully served with one end attached to bow eye rings with an eye loop splice. The other end is looped spliced with a heart. The heart is lashed to the hearts installed earlier at the sides of the bowsprit. Although not shown on the plans, I elected to follow David Antscherl’s FFS and added a thimble into the bow eye splices.
A Piece of brass tubing was first reamed to create a conical edge to the hole on one side which was fairly easy using a Dremmel drill with a fine burr on it. The piece was then cut off the tube stock. Reaming the other side was a bit more difficult due to its tiny size. For that, I used a button reamer hand tool. With a fine file a groove was filed into the edge of the ring to hold the line in place. Since the edge was going to be covered by the line, it didn’t have to look good, just be functional.
BTY: The burrs I used in the Dremmel I got from my Dentist. I asked him what he did with his drill bits/burrs when they wear out and he told me after he uses them once, he tosses them. After I told what I wanted them for model making, he collected a week’s worth for me and now I’ve got a “lifetime” worth! These are diamond coated burrs in various shapes and sizes and looked brand new.
The bow end of the shrouds were attached first then the hearts were lashed together to those on the bowsprit.
I'm almost here too.  I just  purchased some hearts and bulleyes for this stuff.  My parts were shipped last night so I should have them early next week.  A word of warning to ya.  There are a lot of blocks in that little area of the seats of ease.
Scott, out of curiosity where did you order the hearts from? So far the ones that I've used, I've made myself which I admit are not perfect. Syren Model Ship Co (whose stuff I love) has hearts as small as 5.5 mm but I think that is still too large for where I just used mine.
Great work, Jon!  I can't get enough of those shots of the head -- that's a difficult and complicated series of details, and you've handled them well.
And that's good news that your dentist was willing to hand over his burrs. Congratulations on that one!
Cheers,
Martin
I got my hearts from Model Expo, 7mm Walnut hearts MS0707.  I also purchased 2.5 mm bulleyes MS2460 for the thimbles in the shrouds and other tight areas.  I also purchased 2mm Parrels MS0940 for my gaffs and lower fore and main yard arms.  I just didn't see any way I could create these pieces with the tools I had.  I was also finally able to order sail materials but I'll be ferreling my sails for my build.  Well, I hope I will.
