it's all in experimentation and fabrication........sometimes the first try doesn't work.   so you do it all again ;)   I've had mine as well.   your leaving me in the dust just like you did with the half moon....still haven't masted her yet.   your doing a fine job with this one,  considering that the kit isn't very 'exact'.  I'm finding out more as I work on the second hull frame.......I'm having to reshape two of the mid ship bulkheads.  it's sad when one hull is cloned from the original parts......and that frame is assembled better than the one using the original parts!  feel good that your hull came out as well as it did........I wonder if the fellow who built that other one ran into the same problems?
with your speed..........when I finally finish mine,  you'll be either fishing,  or just getting back from your road trips ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello all, thanks for taking the time to hit the like button...got the rail cap made, mounted and painted out, the paper pattern was layed out on some thicker basswood stock, took 9 pieces scarfed together to make the whole capIMG_0409.JPG.7873ed6fef6288944ccfbf6e4f36f1c4.JPGIMG_0407.JPG.268e12214112cf47ff705b36177af83a.JPGIMG_0408.JPG.4033b6981b1c6e7e364bca6700cb086b.JPG
each piece was cut to fit against both its neighbors to get the joints nice and tight
IMG_0412.JPG.8b4e099eb3936637ba61ce580030f300.JPGIMG_0413.JPG.774007730e567c7084675394826ccd42.JPGIMG_0411.JPG.55e89b1557c53e918d6bab8a74f420e8.JPG
and then painted out...
IMG_0414.JPG.fd47c53346c9e8ffb1ae5b66b4ed5ed2.JPGIMG_0415.JPG.7c2f7ab500178ad423a938df481a73fe.JPG
considering repainted the cap in the dark green...think it may tie the main hul and the deck furniture together a little better?
look'in good J.......well done with the caps :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
guilty as charged.......but it was in J's signature  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
well, that's true, ok so it is my fault
partners in crime  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
it would take the apocalypse for Wal Mart to shut down.   sorry to hear Sam....I hope your set to weather the storm.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
well then...........now that you have some free time,  start another project!   hey........if others can hoard TP,  you can hoard table time!  :D   jes' say'in!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
either that or start grow'in a lot of large leafed plants ;)   no saw grass please!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm planning on installing one of these
Now that we've solved that particulier crisis on with the build...still working on little odds and ends.  I'm still planning to use as much of the kit stuff as possible and that includes the cast metal rigging blocks.
I have no idea what these are made of and nothing I have in my chemical arsenal would blacken them, so I resorted to paint...mixed a very dark brown acrylic and painted them.  Once dried they were shot with a couple coats of matt clear.IMG_0418.JPG.f26512388302a875347fed197c9bac66.JPG
Then I turned to the mast tops, new ones were made from the paper patterns, I just glued up some planking stock with cross braces underneath
then cut and drilled the appropriate holes in them
test fit of the fore mast top
and that's all for today...thanks to all who've taken the time to hit the like button or comment
Edited by jct
LMAO!   man....that would be like sandpaper....what RPM do you plan on runn'in it?!?!?!  whatever you do....don't hook it to your dremel! :omg:
do you need blocks??????  don't use those!  what size.....I'll send ya some.  I'm going to try and fit pulleys in the ones I have.......might work well for power blocks.  really .....if you need some.   the tops are another thing I would change,  as I've never seen tops like that on any ship.   the one shown on the left would be the better choice,  if you were going to use them.  I hope someone can correct me,  but if you are going to do a schooner rig,  there are no tops.......just the trestle trees and perhaps a cross tree.  in some cases,  the cross tree will serve as a spreader for the back stays.  what information are you working from?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
14 hours ago, src said:
That TP solution looks , um... uncomfortable.
8 hours ago, Fright said:
All I can say on your TP issue is, "Holy Crap Monkies" !!!!!
All this may be true...but just think how springtime fresh you would be!!
Of that I was unaware, but it makes sense...at this point I'm still replicating the kit parts that are unusable.  My plan is to use the American schooner plan layed out in Rigging Period Fore and Aft Craft .   Why don't you like the metal blocks?
