Considering the whole collection --- brackets.
Brian
Spanish is written in "escuadra".
  but I think the best definition is carpenter's square.
Is it true?
cabrapente
Edited by cabrapente
A great start on the figurehead.  I can't wait to see it finished and in place.
thought had not put the candles.
but the book of 74 guns, is very good. Now if I'm thinking ...
I tried to make the sticks, hand brushing and not come out.
on the lathe, I can not use guvias because the stick is too long.
I found the solution.
two pieces, with a hole to fit and glued with sandpaper.
with this method, it bounces off the stick very right.
at the ends, I put rubbers, very tight, so you do not split ends.
gluing one day and in 15 minutes the stick is made.
cabrapente
The drawing shows transition from round to square section on the masts.
what a marvellous work!
the number of details!
i would like to be able to do the same work,the "fleuron" is one of ship that i'd like to build and one the most beautifull french ship
i will follow your topics with great pleasure
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Looking better and better with every bit of progress.
I love that kitchen.  I'm going to use yours as a reference when I build the ones for my ship.
