Hello everyone,
this is my forth kit build and my second build-log. I bought this kit on eBay for a very reasonable price some years ago because this model is one of some that forced me into the hobby and I hoped to develope enough skill someday to build it. So let’s give it a try. I wanted to build the Cheerful next but after building the Sherbourne and the AVS I got a little tired about modeling another single-masted ship. So returning to 1/64 scale - seems tiny in comparison to quarter-scale.
The kit itself seems to be of good quality - except for the supplied walnut stripes that look awful. So I may replace that wood. I was also able to get an old copy of the AOTS book related to the Granado that might prove very useful for reference. First thing I did was to build the supplied rack to put the model on during the construction. Then I carefully released all the bulkheads to dry-fit on the keel.
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
After studying the AOTS I‘ve already found some differences in the planking layout and the gunport sizes. I fear I need more time for preparation of this build than for the previous ones. I scanned the side-view drawing in the book, it is divided into two sections to match the size of the book. Then the two pictures were merged together with photoshop and enlarged it to match the size of the model. So I can use it for reference and hope that the AOTS book is a reliable source.
Completed Build:
Actually I made the first step, tapering the stern to the bearding line. As the kit is designed with no rabbit I will have to improvise or think about some sort of bashing to add one. I made a template based on the plan and transferred the bearding line to the false keel. Then used a piece of plywood with sandpaper attached to it by double adhesive tape to taper the keel so it goes from 5mm to 2mm at the stern.
Completed Build:
Thank you Phil. I added a rabbit and corrected the bulkheads so all sizes remain the same as before. After tapering the stern and adding a rabbit I‘m now ready to to glue all bulkheads in place. I will use an alignment-tool from Hobbyzone (that was obviously made for bigger models) for that.
Completed Build:
All bulkheads installed. The rabbit will make the first and second planking much easier. I will add some balsa fillers to bow and stern bulkheads to get a smooth run of the planking.
Completed Build:
Great start ! Very happy that I can follow this new build. And the Granado is a very interesting subject !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
I added some balsa filler blocks where needed. They secure a smooth plank run and give more gluing surface. Sanded them to shape with a dremel and selfmade sanding sticks. They are all made of scrap plywood and double adhesive tape. Bevelled all bulkheads. The hull is now ready for the first planking. And I will have to clean up my workshop!
Completed Build:
This build is looking great, cant wait for an update!!!! I am about to plank the Granado build I have in progress.....
  • 2 years later...
hello in fact rabbit is rabett
François
In progress Trabaccolo -MarisStella - 1:32
________________
Completed :
Endurance (log - Gallery)(OcCre), Granado 1756 - HM Bomb vessel - JoTiKa/Caldercraft - 1:64
