Battle of Waterloo Attack on La Haye Sainte Farm by Old Collingwood - 1/56 (28mm)
Not about  LHS   but about  the  defence of  Hougoumont  at Waterloo   -   found  an  excellent   Google Maps  walk through  inside  the  courtyard  and  buildings   -
OC.
https://www.google.co.uk/maps/@50.6706522,4.3946093,3a,75y,82.88h,88.93t/data=!3m6!1e1!3m4!1sAF1QipPIJOCdFc4-hzW-uvug44tVEUNztoNDiwf40IvP!2e10!7i9390!8i4695?entry=ttu
Edited by Old Collingwood
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
Evening all,    I have been pulling my hair  out applying a  few  coats  of my  Mig Ammo   Lucky  Ultra Matt  Acrylic  varnish,  despite  shaking it  till me  arm nearly falls   off  and   brushing it  on  very  thnly  -  do  you thnk I can  get the  Blues   on the jacket arms  to  go  (fabric shade)   flat   -  Nope, they  are  staying like a  slight satin sheen,   simply dont know  the reason or  answer.
OC.
Current builds
Completed works.
Link to comment
Update  -   I think  my trick  of warming  up the  bottle  has worked,   as  the  finish  seems  more flat  now   -  Third  time  Lucky.
OC.
Current builds
Completed works.
Link to comment
So  I can confirm  - warming up  my  Acrylic  Varnish   does  help  the  flow  and   dulling  (with a  Matt  Varnish)  I think  our  temp  being lower  over this  side  of the  pond   to   you  guys   over there  may have something to  do  with it  as  at a guess  I would  have  been  brushing it  on at a  temp  of  roughly  12*C  -  53*F   but  heating it  up to  around  25*C   seems  to  help   -   still   needs a  good   shake after  warming though.
OC.
Current builds
Completed works.
Link to comment
Morning all,   so  -  where  I am  at  right now,   I  have  flat coat varnished  about  30  of my  French  dudes  with  more  to  do,  I also  have some British that need the  same treatment  -  however  I have ordered  a  bottle  of  Loctite Flexible  Gel Super Glue  ( I have read a lot of good thngs  about this  glue)   the  idea  is  when it arrives  I will   cut away  what ever  figures  I have  done, that  can then be placed  on my dio  dependent  on areas  being finished  -  like the  road  and  orchard.
OC.
Current builds
Completed works.
Link to comment
OC, that Loctite Gel is a good choice; I use it on my resin cars. 👍
Oh, we watched "Napoleon" on AppleTV streaming service. I got the service to follow Masters of the Air; an excellent series on the air war, Anyway, my Admiral said Napoleon was a waste of time. I'm glad I didn't spend the bucks to see it on a theater. They played fast and loose with the battle scenes. Waterloo was a joke. Napleon led a charge, no battle at La Haye Sainte farm or Hougemont, the Prussians attacked from the west(?). Oh and Wellington kept the Alliance forces on the facing side of the hill, rather than on the back side. :unsure:  This movie ranks up there with "Pearl Harbor"
Ken
Started: MS Bounty Longboat,
Link to comment
Yes  I had heard  the  new film  was   very  lacking  more of a  bio  just  on him,  and not  very  accurate  regarding the  battle.
OC.
Current builds
Completed works.
Link to comment
I put those in my "Sealed with a Kiss" classification.... One dedicated to social angst rather than telling an accurate story...
Quote:
Link to comment
Indeed   brother.
OC.
Current builds
Completed works.
Link to comment
So   I have  now  flat coated  30  of my figures  and  put them to One side,  and   fixed down another Fifteen  on top of my  paint  bottles  ready  for the  same treatment.
OC.
Current builds
Completed works.
Link to comment
Morning all,  I have been  toying with the  idea  of trying to  do some  mock  smoke  coming from the  rifles - muskets,   I have been looking on  the net  how to  do it  -  cotton fibres  like in cotton  wool  wrapped  around  a wire  and  glued  then  the thin  wire  wrapped around the  end of the barrel  - or  in my case  glued to the  inside edge of the  bayonets  with  the  cotton pulled  over to  hide the  wire.
Some  who are  really good  even  simulate the  orange - yellow  colour  of the  flash and  some blackening  but  I have seen them using an airbrush  to  do it  (think it would be  difficult with  brushes)
So  I am  not  sure  as  if its not  done  right  it might  look tacky and spoil the  Whole thing.
OC.
Current builds
Completed works.
Link to comment
19 minutes ago, king derelict said:
That would look great if you can pull it off. Would it be easier where there are troops in line and the smoke can be distributed across the row. Maybe then you could sneak a small yellow led into the smoke. Do you have some unpainted figures to try it on?
great idea
alan
I will   have to  have  a  fiddle  with  my  odds  and  ends.
OC.
Current builds
Completed works.
Link to comment
I have been searching  the  net  for   Rifle  and  Musket   firing still   and  have managed to  find  these  -  Baker Rifle  as  used by the  1st  and 2nd  Light KGL   and  the  Luneberge Regiment   and  the  common Musket  as  used  by  the  5th KGL   (Red Jackets)   and also  the  French.
I have  done a  couple  of  screenshots   to  show  the  different stages  of  smoke  from the  Breech  and then  the Muzzle,  it gives a  few  smoke  options.
Still  not mine  - got them off  the  net.
OC.
Current builds
Completed works.
Link to comment
Favourite recruiting poster for the 95TH Rifles ,(And also a Sharpe Fan😎)
“In this distinguished Service, you will carry a Rifle no heavier than a Fowling-Piece. You will knock down your Enemy at Five Hundred Yards, instead of missing him at Fifty.
On Service, your Post is always the Post of Honour, and your Quarters the best in the Army; for you have the first of everything; and at Home you are sure of Respect—because a BRITISH RIFLEMAN always makes himself Respectable.
GOD SAVE the KING! and his Rifle Regiment!
Link to comment
Just another  couple  of pics  I have been  working on.
OC.
Current builds
Completed works.
Link to comment
Morning all,   while   re flat coating my  figures  -  (I have  done about 50  so far)   some  are taking a  couple  of   coats  as  my dreaded  Blue  is  being stubborn,  I have also  been doing lots  of reading   from  all  the different  Waterloo  links,  and   I have decided  to  leave  my  Polish (French Guard)   Lancer  out  of my dio,  as  they   did  not  actually  come  near  to  the  farm  but  took part  further   towards   Hougoumont    and  further   in the  centre  attacking   Ponsonbys  Greys   charge,   but  in   exchange  I have decided  to add a  couple  of  British  95th  rifles  that  I will  place  on the  road  at the  extreme  end   near the  kitchen garden  -  they  will  be  placed   pressed against the  wall   because of the   Lifeguards   blasting past.
OC.
Current builds
Completed works.
Link to comment
Morning all,  think I found out the secret  to getting a  nice flat finish  with my  Lucky Ultra Matt   varnish,  after a   thorough  shake  (my arms are still  shaking now  lol)   I  put a  small  amount  in a  dish  then  after  loading the  brush  I  removed most  of it  against the  dish  wall,  then  I  removed even more  on some  tissue,   then when I ran the  brush  over the figure  it was  like  just adding a  slight  wet  finish  in a  really thin  layer   -  yep  it  seemed to have worked.
And  long last  a  few  pics  -  sorry for  the poor  quaility   quick  shots  in the  kitchen.
OC.
Current builds
Completed works.
Link to comment
So  I had a  go  at some  wool  smoke  -   I  added  a  small   blob - ball type   bit  on the  breech  and   tried a bit  coming out of the muzzle,   but I wasn't  convinced  as it just  looked like  wool,  so  I  removed  the  muzzle  bit  but also had to  cut away  the  bayonet  (not a  problem as  some  did not have their bayonets  fixed)   I also  cut away  at the  smoke  on the  breech  till there was only the smallest  bit  left,   this  is  about as far  as  I would  go   -  just cant make it  life like.
OC.
Current builds
Completed works.
Link to comment
It’s lovely to see the figures again. They really are terrific. The smoke is tricky, the breech smoke looks great in the first picture but not so impressive from the other side. I’m sort of following along here because I have sea spray in my future and I think smoke and spray are extremely difficult things to model. It’s probably easier modeling a cannon battery firing than the delicate musket smoke
Alan
Link to comment
15 minutes ago, Haliburton said:
Hi O.C. I like the look of it out of the muzzle in the photo - can you share a picture of it coming out of the breech?  Sometimes we are our own worst critics
I probably  worded  it wrongly  -  meant  the  pan  by the  striker  near  his  face,   there  is  also just  the slightest hint of smoke  coming out of the barrel.
OC.
Current builds
Completed works.
Link to comment
Alan
You are  so   correct Alan,   its  such  a  difficult  thing  to  look  realistic, I may   leave  that  one   out  and  just  attach  all the  other  figures  I  am working on.
OC.
Current builds
Completed works.
Link to comment
OC.
I see it now O.C.  I really should keep my glasses handy! 🤓
Currently building:
HM Yacht Chatham - 1:64 - Caldercraft
Link to comment
I have  been  thinking (steady  boy)   I will    have  some  figures  in my stash  that will  be left over   from my  build,  I  could  do a  couple  of small   dio's   with  what I  have  -  possibly   a  Scots  Grey  (Union  Brigade)   running from a  French  Polish  Lancer,   and   even  a   French  Imperial  Guard   facing off  aganst  the  Britsh  Guards.
OC.
Current builds
Completed works.
Link to comment
Evening all,   right  some more  progress  today  -  I   cut away the  bases  on a bout  Ten figures  then  placed them  on the  roadway  and  orchard  then took a  few  pics  (some  with  flash  in darker  conditions)
OC.
Current builds
Completed works.
Link to comment
I did a  count  -  I have  nearly  a  Hundread  figures   in my  dio   so far   with about another   Fifty  or  so   still  to  add,  not  to  bad   considering the  space  I have   3ft  by  2ft.
OC.
Current builds
Completed works.
Link to comment
3 hours ago, king derelict said:
Amazing. That’s going to look realistically crowded
alan
Thank you so much Alan.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
