Are you able to rig in your sleep by now, Rob? Beautiful work, as ever.
THAT is one skill, I have yet to master.  Actually, I focus on time management.  Each day, I get about an hour and a half to work like a madman.  So I have really spent time perfecting any repetitious processes....like painting and sheaving blocks....making eyebolts.....securing eyebolts to blocks, most importantly....establishing a good sequence to do all this.  Preparation and planning for the work cannot be overlooked.  Work inward out.  Prep and drill all the top fairleads, the tie sheaves in the masts and block/stay eyebolt holes.  Not to mention banding for stays and futtock shrouds.  Its a symphony.
My evening goal is to finish off the topgallant shrouds and begin the addition of the ratlines.
Again, thanks for the fine compliments and daily visits
Rob
Current build:
Finished build:
Current build(On hold):
Druxey,
"Sleep-rigging" what a concept! Now, imagine if you could do that and get a good night's rest at the same time.....
Actually I think Rob has just about perfected his masting and rigging technique to mastery level while still getting a decent night's sleep. Besides creating a museum masterpiece with an incredible level of detail, his assembly pace is nothing short of amazing.
Visiting this thread is always a pleasure, Rob! Obviously with such a vast quantity of rigging, time management and work flow becomes important.
Rob. The rigging is truly impressive. It must be either a labour of love or a penance. I do admire your dedication to the task and the structured way you approach it.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Druxey and Keith.
Finished up the rat lines.
Current build:
Finished build:
Now mounting the upper and lower topsail yards.
Current build:
Finished build:
Now the long task of adding blocks and rigging the yards and their furled sails.
It begins with the chain clews for the upper topsail yard.  Threading  chain is like threading a wet noodle through a straw.
Rob
Current build:
Finished build:
Rob, the magic of cameras is that we see images of your amazing progress instantly. That belies the amount to time and energy you put in, to make these pictures possible. As a teenager, I've done a small amount of plastic sailing ship model rigging (always scratch building, as their accompanying plans were unrealistically simplistic). I know to a degree, that to get the highly accurate results your model displays, involves hours of thoughtful fore planning and careful meticulous work. I just wanted to acknowledge that.
Edited by ClipperFan
additional information
Rob
When doing the chains for the Red Jacket, I first tied fine sewing thread to the chain, then stiffened the other end with CA glue. I think you will find it much easier.
Nic
  Rob,  I was antiquing with the Admiral recently and came by a turn-of-the-century clothes wringer ... just the sort that can be used in your ingenious method of embossing copper strips for ship hulls below the water line (shown in detail in your Great Republic log).  It had clamps for attaching to most table edges, a wooden frame with adjustable pressure leaf springs and the rollers were in good shape.  The price was $125 - which I thought reasonable ... but as I was examining the wringer closely, the Admiral thought I didn't need anything like that.  Whatever, these things are not 'fast movers' ...
Rob, in a similar idea to that offered by NIc, also try some very thin wire as a leader, as it is stiffer than thread.  It could be a single strand from the multi-core electrical wire but must be thin.  I use ni-chrome wire as it is a little stronger; I simply double it through the leading link of the chain - it is thin enough for for both ends of the wire to easily pass through the block , fairlead etc.
cheers
Pat
Nic
I run thin wire through the first link and then thread it through the block an such.  Just sometimes the chain will bind inside the block or sheave and I have to work gently to not break anything.
Note the wore at the end of the chain dangling.
Rob
Current build:
Finished build:
cheers
Pat
That is exactly what I described to Nic.
Rob
Current build:
Finished build:
2 hours ago, BANYAN said:
:) we must have crossed in the ether Rob - great minds think alike (well your's might be great at least).
cheers
Pat
Right.  The wire I use has to pass through a single link of 42lpi chain.   It’s pretty thin stuff.   Smaller then thread for sure.  Winding off a small motor.
Pat……your Victoria is amazing and a testament to you own expertise and skill.   Your great mind’s doing just fine.
Rob
Current build:
Finished build:
Wow....$125.  I found mine at a second hand store for $20.  Keep looking....and visit Ebay...sometimes they have them there.   All I know, is that the method I devised is the simplest and fasted way to make thousands of copper plates.....in no time...for the cheapest cost...too.
Rob
Current build:
Finished build:
 I have a brand new one still in the original box or what's left of the original box. I'm never going to use it.
Maybe Snug harbor would like to get in contact with you........?
Rob
Current build:
Finished build:
Just a quick update.   I’m taking a slight break for a few days.  The temps have been in the high nineties and my shop is not air conditioned.  I just don’t have the energy to endure the temps.  It just sucks the life out of me.  I just can’t endure it.  The house is air conditioned but not the shop.
Maybe this weekend or next week, I’ll ramp up again.
Rob
Current build:
Finished build:
Rob
Rob,
Priority no 1 is to take good care of the shipbuilding crew. After all, nobody else can fill in for you. Even Donald McKay knew that principal, as he treated his workers as extended family. Things have been so warm here in the Litchfield Hills of Western CT that the city has opened up emergency cooling centers. Take good care of yourself.
18 hours ago, ClipperFan said:
Rob,
Right.  Next week will be in the mid to high seventies...so we will get a reprieve.  Shoot...I cut down a dozen 10~4" trees yesterday with my son-n-law and stacked the trunks branches for chipping and it was 97deg.:wacko:
Work is possible outside....but in a hot room..........I'm dead.
Rob
Edited by rwiederrich
Current build:
Finished build:
Spent some time working the rigging.
Rob
Current build:
Finished build:
Added all the bunt lines to their insertions and will now run them through their blocks and down the mast.
Rob
Current build:
Finished build:
Finished up the lifts.
Here is a pic of the size of each eye hook for each lift.  They are 1/8” long.
Rob
Current build:
Finished build:
Finishing the day with the upper topsail down haul.
Rob
Current build:
Finished build:
Rob,
First, it's great to see you back in action on your beautiful Glory of the Seas model. I hope this means temps have moderated enough to allow you to comfortably work. I am still impressed with the amazing organizational skills you display in your disciplined rigging process. Seeing all those loose lines in the before picture and how it all is resolved in the after one drives home the point that such intricate rigging is not for the faint of heart!
5 hours ago, BANYAN said:
Nice work Rob, some significant progress.
cheers
Pat
Just have to add the sheets and I’ll be ready to step this bad boy in the hull.
Rob
Current build:
Finished build:
1 hour ago, ClipperFan said:
Rob,
I’m getting close to stepping the fore mast array.  And then mounting the main yard.
Shwuuuuuh…..I can’t believe I’m almost done with Glory of the Seas.   Just a few more tasks.
Rob
Current build:
Finished build:
