31 minutes ago, ClipperFan said:
Rob, these overall scenes are my favorites. You can really get a sense of how not one inch of space was wasted on these sailing merchant vessels. My guess is that a Chicken Coop would have been mounted on the forward hatch before the Foremast. This is just so exciting to see develop, it's like your creating a museum piece heirloom for the ages!
I might even consider that.    Donating her to a deserving honoring museum.   Interesting notion.
Rob
Current build:
Finished build:
Current build(On hold):
Rob
Rob, mark my words. By the time you complete her lofty masts, powerful spars and intricate rigging like the 1877 scene of her at the San Francisco Wharf, she will indeed be a stunning Museum piece for the ages. Can't you just imagine her sitting serenely in front of the sole remaining "GLORY of the SEAS" nameboard? It could start a whole new generation rediscovering McKay's final magnificent Clipper!
Edited by ClipperFan
Grammar correction
If the Logistics could be worked out,  I might consider such an adventure.
Lots of logistics would need to be worked out for such an endeavor.   It would be nice to have a small gallery of images and artifacts and her scale model.
A wonderful thing to think about.
Rob
Current build:
Finished build:
Rob
Rob, I hear you. You will have put an incredible amount of time and effort into your project by then. I don't even know if I would want to part with such a beautiful model by then. If you did though. I'm sure the logistics could be worked out.
For me, it is not the time spent...I enjoy every minute making it and I did with all my other builds.  It is, the significance of her reproduction, so history can at least have a model example of what she most likely appeared like.  It would be for historical significance that I would donate her to a qualified deserving museum.
Rob
Current build:
Finished build:
23 hours ago, rwiederrich said:
During her 1877 image she had all composite masts.....so composite it will be.
Rob
Looking forward to seeing your construction technique.
It'll be fun...I have 2 approaches, so we'll see which one I go for.  Still working out the processes for each to determine which will take up my time.
Rob
Edited by rwiederrich
Current build:
Finished build:
Worked on the main fife rail and pumps and flywheels.
Rob
Current build:
Finished build:
Tying down boats.
Rob
Current build:
Finished build:
13 hours ago, Ian_Grant said:
Rob, did you make those pump crank wheels?
I salvaged them from another parts kit.
I fashioned the pumps and mechanical items.
I try to use whatever and from wherever I can to achieve my goals.  It's the end product that counts.
I didn't make the boats(though I covered them), I didn't scribe the decking or house material, I didn't cast or solder the anchors.
I believe everything and anything(Preferably if it is already engineered), can be repurposed and will be utilized....because when all is said and done, it is the end product...a fine scaled, detailed model that is the goal.  How I got there, is not part of the judging criteria.
Rob
Current build:
Finished build:
For the inquisitive.  Here is a crude drawing of the technique I will employ in making my composite masts.
I'll begin with square stock...prep the ends to be received by the lathe.
Then run through the table saw to cut out the corners as indicated...
Glue back into those cutouts the spacers for each band cut to scale width.
Then placing the entire thing  into the lathe and turning to scale diameter for the particular mast.
Repeat for each mast.
Once turned....I will paint the recesses white...(replace in lathe to sand and clean up), varnish(tung oil) the rest and apply the bands, which will be painted red.
I think this will produce convincing lower masts
Current build:
Finished build:
Worked on finishing up the boat tie downs and adding the 3 boat skids on the long cabin.   Had to cut out the spacing for the edging to make it like the prototype.
Rob
Current build:
Finished build:
Now onto the forward hatchway and adding more detail to the forecastle, namely the iron rail.
Rob
Current build:
Finished build:
Just now, Tony Hunt said:
It's looking really good Rob. Very shippy!
Remembering my first build of her as she was originally built causes me to marvel at how busy her decks have become since she became experienced and a full fledged working cargo carrier.
Thanks for the fine comment.
Rob
Current build:
Finished build:
Rob, thanks for sharing your creative process.
Rob
Rob, this is really demonstrating how every spare inch of space was utilized on sailing Merchant vessels. Again, I believe this is shaping up to being your best most intricate modeling effort yet. This is getting more and more exciting daily.
Finished up more details, like adding the steam donkey stack and the heating pot chimney.  Plus I added the bits for the howser  mooring holes.
Rob
Current build:
Finished build:
Making the foremast fife rail.
Rob
Current build:
Finished build:
Rob, being on the East Coast, it seems damn near impossible but some day, when she's fully rigged, I would love to see your Museum piece in person. I am sure she will be quite imposing.
Grammar correction
Forward/forecastle rail.
Rob
Current build:
Finished build:
A few more pics with more added details.
Rob
Current build:
Finished build:
A few more details and the forward hatchway.
Rob
Current build:
Finished build:
16 minutes ago, Vladimir_Wairoa said:
Beautiful hatch Rob. amazing.
Thank Vlad.
Just a few more details to add, like the long house boat straps, the bell, the addition of the third small green dingy on the boys house.
Then I’ll focus on the lower masts.
Rob
Current build:
Finished build:
Rob, the forecastle rail is a nice touch. One I've never seen before on a McKay Clipper but which makes total sense from a safety factor. It looks like it's a wooden cross bar attached to iron stanchions. By the way, do you think maybe the center of this rail might be where the ship's bell might have been located?
If you look closely, you can see a metal stanchioned rail on the forecastle in the boy image.
Rob
Current build:
Finished build:
Rob
Rob, very perceptive of you to find those. When I enlarged that image, I also saw the distinct shape of a ship's bell apparently mounted to the rear of the Foremast just above the long House behind it. To me, that's sort of an awkward position for one but it sure looks like a bell to me. I can see the metal stanchions you refer to, but it looks like two sets of wires rigged across them. One runs across the top and another runs just slightly above midway. More confusing still, is that the wires appear to run completely across the forecastle rear with no break for ladders. Speaking of which, I see lower Bulwarks on the Port side, with three equal sets of long rectangular moldings and a bearded sailor crouching down just to the right of them but no visible ladders. Do you think it's possible the crew might have moved them to work on the deck?
