Not what you expected. Get out a little…
BTW, for the keen eyes out there, I’m passing oil drain time. More to life than technology.
Edited by Auger
Completed Builds: AL Bounty Jolly Boat, Constructo Enterprise (logs lost in the great crash)
Current Builds: Constructo Bounty, AL King of the Mississippi
Up next: undetermined
28 minutes ago, Bob Fraser said:
Nicely done!
Noticed the pins in the bottom of the uprights - they helped me a lot in keeping stuff fixed in place 😃
Cheers,
Thank you.
Yeah, I wanted to lash the barrels down vs. gluing them to the rack.
Speaking of passengers, starting to add more before oiling the decks to be sure the glue is dry. Pains me to show this now, and kind of a spoiler, but it has to be done.
Secret Service agents work closely with local law enforcement to ensure that the the visit of so-and-so with such-and-such on board the riverboat (use your imagination) goes according to plan. Once underway, passengers may find themselves in the presence of a known personality and have the chance at a selfie. But engineering has found a minor problem with propulsion (maybe torquing a couple critical nuts) which may delay the departure by a half hour. Meanwhile, the bridge crew just watches the show…
Edited by Auger
Typo
  • 1 year later...
I noticed that the upper bow railing kept rotating downwards under the weight of the metal balusters while installing it. So I added a little block under the center, just in front of the mast, which holds it all up nicely.
Forgive the sloppy glue here and there, I still have some sanding to do.
Edited by Auger
(spoiler) So, the trained eye will notice that I’ve been using 2mm x 2mm sapele wood in place of the 1.5mm x 3mm (about) kit laser cut wood for the rail bends. It’s what I have on hand so it’s what I’ve used. The layman generally won’t know the difference which sets you all apart.
Why? (Maybe I’ve said it before) The kit laser cut parts came up short in certain areas, so I abandoned the laser cut railing sheet all together early on. If you want the laser cut parts to work for you, don’t follow the instruction book in order, page by page. Work the railing posts from the top deck down in respect to the larger railing plan. I followed the instruction book page by page and found the flaw afterwards. Cut-out and lay the upper deck plan onto your upper deck build once entirely built and mark the railing posts from there-down. Then, work the railing posts top-down and outward from there (bumpers, etc.) Not bottom-up like in the booklet. Trust me. Ignore the railing posts in the book until you reach the top deck. Then work backwards top-down from there.
I really hope this helps someone. This is based upon the 20505 version. The 20515 version may be different.
Edited by Auger
Additional text
Ohhhhh, happy day! The last two rails are drying in the forms!
I love the build, don’t get me wrong, but sometimes there’s a sigh of relief when certain tasks are finally completed. Like building cannons. 🤪
Edited by Auger
