This will be my first journey into the DARK SIDE! I am collecting drawings, profiles, pictures so I can start drawing my plans. I shall use Cap N Bob's build as my guide. I took the first big plunge by buying a Dremel Scroll Saw. Now that I've set the saw up, I have to practice cutting precision curved cuts with it. At least I have tons of left over material from past builds to practice.
Hipexec
:10_1_10:
Good luck Rich. Scroll saws take a bit of mastering so don't get put off by your initial attempts.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Now I have some basic info for drawing up scale plans for my Spray build. The pics below give me the shape and position of the basic ship.
Looking forward to following your Spray build.  Impressive computer modeling skills there too!   Just started the Bluejacket Shipcrafters kit myself, and am interested in other's builds of this icon boat.
As luck would have it....I obtained an old Laughing Whale Spray kit from an estate sale. It was date stamped 1999. The kit has been opened and whatever parts that are in there have been tampered with, but the most important part is I now have detailed scaled plans to make any missing parts as I create my own version of Slocum's Spray
I did some work (actually a lot) on my semi scratch version of the Spray. I used the keel from the Laughing Whale kit with slight mods and than made scratch built ribs using the shape from the plans. Since this will be a version of Slocum's Spray whereby you will be able to see inside the whole ship, from Slocum's sleeping-reading quarters to below deck storage, to his galley, to the sail locker.  Theses pics are just dry fitted in place and need some adjustments. BTW the wood n this kit is pretty old, so I shall be buying much of what I need on line. Any suggestions?
:dancetl6:
Edited by HIPEXEC
Here's a pic of the scratch built ribs I made. They will be planked on both sides, inside and hull side so looks don't matter, only shape and strength.
I'm still dry fitting and adjusting the frames before cinching anything permanently. So far all the internal space I need seems perfect. Sleeping quarters, galley, storage areas are all the correct size. It's the old adage, measure twice...cut once!
I must say that building a ship without plans is very interesting. First of all I'm building this ship from the inside out first. Never did that before. I find it interesting when I build a part and don't like it to just rip it out and start over. Scratch building can be fun as well as challenging.
On 11/15/2020 at 10:30 AM, Josh Williamson said:
Nice work Rich!  Really enjoying seeing this come together.
-Josh
Thanks. It's a challenge but fun. A lot of hit or miss.
Scratch building is great! I didn't like what the gunwals looked like from the deck up, so I sawed, cut and ground all of it off! I'll redesign it after I finished planking the hull which I have started.
Hi Rich.  Had no idea you were doing this, looks good so far.
You asked a while back about where to get wood, did you ever get an answer?  If not, what size and type of wood are you looking for?  If you want basswood I have a bunch of different sizes.  If you are looking for more hardwoods, tell me what you are looking for and I can see if I have or can cut what you might need.
I found that planking over frames instead of bulkheads is very different. The hollow frames tend to break or crush if too much pressure is applied when bending planks. I had to repair broken frames several times. I had to do a lot more pre-soaking and pre-bending to get this model planked. 🤪
Edited by HIPEXEC
Rich,
If you are breaking the frames, you could consider gluing temporary beams between the sides of the frames to brace them, or even place a temporary riband (or just a plank) along the inside of the frames.   Use PVA so you can just use alcohol to release them later, or use something soft like basswood and just cut them off and sand when no longer needed!
