On 12/13/2020 at 10:51 AM, Eugenio Treviño said:
Hi friends !!!
This is just the second time I work with wood, but the first time to work with pressed wood.
The breakhead bulkhead is made out of this material. Because I decided not to use paint I decided to go with a kind of dry brush technique with pastel color powder to  weather it.
This is the result. Do you like it? Any comment or suggestion?
Best regards,
Great work! I'm way behind where you are. I'm building the same kit. I was wondering about that press wood stuff that's included in the kit. How do you cut those pieces out? Do you leave it attached to the cardboard, or is it removed some how? I appreciate any help you could give. Keep up the great work.
Best regards,  Robert.
Robert:
I started hating the pressed wood pieces. It is a fragile material, difficult to cut and finish correctly. I broke several. I learned a little bit late that if you wet them, you can mold them much better.
But now, with the experience I got, I think it is not so bad.
The cardboard is layered. In most of the pieces I left the inner layer and applied glue over it. In others, I sanded out all the cardboard (see picks), and in 2 of them, pieces 54 and 79, I covered the cardboard side with Tanganyika wood. Piece 79 because I am not using paint and the cardboard side is visible (see pick) and number 54 to ad strength because it is very fragile.
I cut the pieces with knife, but the result is far from good in the molding stripes (see pick).
Taking time and not being in a rush is very important. I think that with your experience working with wood, it is going to be much more easier.
If in the future you have specific questions let me know.
Best regards.
Eugenio.
On 1/14/2021 at 12:22 PM, Shipyard sid said:
Truly excellent work, beep it up. David
David, thank you very much for your kind words!!!
I continued the work on the stern galleries and the figure head. I liked the old wood finish and the glass effect on the windows.
Best regards to all and...
Here are the picks!!!
Friends:
Some more work done.
Polyurethane varnish on the stern area and some work on the upper deck.
I decided not to use the gilded rope provided for the stern galleries ornaments, and instead I used a dark brown one, to avoid a “flashy” look.
Here are the picks !!!
Edited by Eugenio Treviño
Excellent work, as always...
I'm taking some time off, as I got my hands full with painting and redecorating my new home.
I just have a few minutes from time to time to add some planks.
On 1/23/2021 at 11:24 AM, Rach10199 said:
I like that you've kept the natural wood. 👌Beautifully detailed work!
Rach, thank you very much!
Nicolas, thanks and congratulations on your new home!!!
I spent some fun time drilling the holes for the timber heads. First time to do something like this.
Here is the pick !!!
Best regards.
Hi everybody:
Some more work in the stern area. I installed the rudder chain and the lanterns.
The chain provided in the kit is completely out of scale. I may change it later for a more accurate one.
The lanterns provided were modified in size and painted to be a little bit more realistic.
Best regards.
Nice work Eugenio, your latterns look really good, as does the stern. I agree about the chains, they do look oversize.
Cheers
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Cheers
Richard thank you very much. I am very happy realizing that I am getting closer to finish the second stage of the build. But that also scares me, because I have no idea of how to face the rigging!!! But with the help of this forum I am sure I will do a decent job.
Some more work in the decks was done. Rigging and placing all the cannons and some other details.
I am not completely satisfied with the stair’s hand rails and with all brass pieces in general. They are too “flashy”. Maybe some weathering would help. I will consider that.
You're making wonderful progress Eugenio, you must be happy with how the Victory is going.
Richard
Current builds:
Completed builds:
Harpy by Vanguard
On 2/12/2021 at 9:11 AM, Roberts Orca said:
I think your choosing to let the natural beauty of the wood show through is beautiful. It's a fine piece of craftsmanship. Congratulations my friend. Job well done. 😍🙂
Richard, Robert, thank you so much for your kind words.
Today I worked on the hammock’s netting.
I used a surgical gauze, weathered it with instant coffee (I think the final color matches the wood tone nicely), cut it to shape and insert it in place using the brass wire for the rail as a big needle threading it all.
I think the result is good enough.
I also worked in some other deck pieces. I am getting closer to finish this second big stage, before the masts and rigging.
We got some snow tonight. Rare for Monterrey!
Best regards.
Hi my friends!!!
Today I finished installing the side ladders. I just need to apply varnish.
A few things more and I will be ready for installing the channels and start with the mast and rigging.
Here is the pick!
Best regards.
I have installed the starboard mizzen channel.
A tricky job but, thanks to Pythagoras, I could installed the supports on the first try and it feels really solid in place.
Now I can tell my oldest daughter that you do use math in real life!
The vertical strakes were also set. Now I have several pieces ready for varnishing.
Here are the picks!
Best regards.
