I then proceeded to install the keel strips and chine strips.  I was a bit confused as to how much to fair the bow end of theses strips as later in the instructions the stem was to be attached after the sheet planking was installed. After the side planks and the bottom planks were attached I then realized I didn't fair them correctly.  I had to use some wood fill to lessen the gaps on the stem.  I did not take any phots  the fairing was off when attaching the stem.
Making of the Toe Rail was interesting.  The instructions said to cut a piece of scrap basswood 3" X 3/32" glue 220 grit sandpaper to it then lay the Toe Rail between to pieces of wood and sand the notches at the appropriate locations. ( Going to have to file this technic away in my brain for future builds)
Needing some advice on seizing for the shrouds on blocks.  I've tied knots then wrapped the seizing around and around but it then
it collapse around the shroud. Not sure how to make them?
Edited by Sparky21
There is a picture in this comment for the method that I frequently use: https://modelshipworld.com/topic/22920-hm-cutter-alert-by-vthokiee-finished-vanguard-models-164/?do=findComment&comment=745423
It isn't the most accurate but it works well.
