Looking mighty fine OC. Great dusty colour!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thank you Edward.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
4 hours ago, Canute said:
Nicely done dusty effects, OC.
Thank you Ken.
OC.
Current builds
Completed works.
15 minutes ago, marktiedens said:
Nice work - those close-ups look like a real tank👍.
Thank you kindly Mark.
OC.
Current builds
Completed works.
1 hour ago, Backer said:
very well done.
Nice tracks and wheels.
Thank you kindly Patrick.
OC.
Current builds
Completed works.
Evening all  - yep its been raining so you can tell that means time at the bench,   so  I  decided to attach the side skirt on the side where the track is on, after fitting this I was able to make and  fit the rear  mud guard, this was then painted a few coats of Nato Black  the  dry brushed White  to make it look nice and dusty,   then I did the same to the front guard  - same  paint/dry brushing, then I made up one of the thermal housings then painted/wash and dry brushed  before fitting.
Starting to look quite busy.
OC.
Current builds
Completed works.
17 minutes ago, Canute said:
Suitably grimy, OC. Looks good.
Thanks Ken.
How's the eye?
OC.
Current builds
Completed works.
Improving daily. I go to the Ophthalmologist for my second post op today. Doc says I'll meed readers for fine work. That's fine by me. Used my Optivisor for the detail work (up close and personal) yesterday.
Ken
Started: MS Bounty Longboat,
Thats good news Ken  - so pleased for you mate.
OC.
Current builds
Completed works.
Evening all,   a bit more progress this evenening  -  I firstly found out I had foregotten to put on the hub caps on the wheels - it was a bit of a pain as some of then where partly obscured by the side skirt,  it wasn'y much of an ordeal though,  next was part of the rear cage  - this was painted  while still on part of the spru, it was then dry brushed  and fitted.
OC.
Current builds
Completed works.
Really coming on OC!
That's good news Ken 🤓
Current builds;
Completed:
1 hour ago, Canute said:
Thanks, Edward.
Slat armor around the engine compartment, huh? Interesting blend.
Indeed mate,   that's what makes the Chally 2  TES version so distinctive, it has side's and Three sections around the back.
OC.
Current builds
Completed works.
10 hours ago, Canute said:
Thanks, Edward.
Yep, RPG protection, distort the warheads penetration flame before it touches the hull...
Challenger II Iraq 2003.... (on the rear hull and turret)
M-1 Abrams had it covering their rears for a while in Iraq as well....
The Germans in WWII were the first to use it to counter the bazooka, and found it more effective than solid skirts but much more difficult to manufacture...
From the Germans, the Russians adopted it to counter the improved Panzerfaust's they began encountering in '44.... It's a very effective shield against hollow charge warheads....
Been around for a long time, simple but very effective.....
Edited by Egilman
Quote:
She's looking good brother, almost ready to go into battle.....
Quote:
And cheap. I read somewhere that these were made from captured beds .
I've read the same reports from several sources as well....
Quote:
Thank you kindly EG,    hope things are turning for the better your end my friend.
OC.
Current builds
Completed works.
OC.
Oh the truth is the truth brother.... things are stabilizing here...
Collecting info on Tanks right now, (mostly M1 Abrams) and considering my next build.... recharging as we speak..... {chuckle} I have five cans of paint coming in mail, Nato Black, Green & Brown with a little armor sand thrown in for good measure....
Something simpler....
Quote:
Evening all,  well I  have only spent a small bit of time on the Chally  as the weather last  couple of days has been too nice,  also  we took our little princess back to the vets  - she has been signed off and they don't need to see her any more  - the  scar is healing well  with just a tiny bit of swelling (quite normal) they said, so yesterday we were all sitting in our back yard.
In the evening I decided to carry on with the costume jewellery  bangle  - I mean other track, same procedure with the links  but this time it was made in just a few hours  - it will next require painting/weathering before fitting.
No pics as it looks the same as the other one.
Getting there.
OC.
Current builds
Completed works.
Hi all,    I am currently working on the remaining track  - change of tack this time with the paintwork  -  I brushed the Nato Black all over them first - gave them a couple of coats  - then after a quick blast with my advanced  heat application tool  (gonna name it  a  Hair Dryer)  I then started painting the outside edge links - in betweens  and teeth  - currently working on it still.
OC.
Current builds
Completed works.
Tracks finished and fitted.
OC.
Current builds
Completed works.
6 minutes ago, Canute said:
Turned out nicely, OC.
Thank you Ken,   a bit tedious  and boring doing all those links  but worth it I feel  as the combinations of the weathering  brings the details out.
OC.
Current builds
Completed works.
