Russ
That is a very clean scarph - good to see you getting some time at the bench.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Russ,
Fine carpentry.  The scaph joints and stantions look good.
Bob
Current build:  SS_ Mariefred
Stanchions are looking great Russ. It's almost a pity you can hardly see the joints ...
Carl
BobH:
Thanks for the kind words. Actually, the camera fools us slightly. Right after I glued that plank down, I went at with an emory board and worked a good deal of sawdust into that scarph joint. That makes it looks much better than it was.
Cap'n Bob:
Thanks. I am happy with the stanchions so far.
Carl:
Thanks. I am having fun making the scarph joints, even if they are not that prominent. Those covering boards will be painted anyway. I will know that the joints are there. :)
Russ
HI Russ,
I learn something every time I visit your log. Looks like you are back into the swing of building now which is good!
BFN
Cheers,
Hopeful aka David
“there is wisdom in many voices”
Completed: Sharpie Schooner (Midwest) Posted on kit build log.
Current: Sultana (MSW) Updating the build log and continuing on with the build
Next: Lady Nelson (Amati Victory)
Alfons:
Thanks. There is a lot of trial and error fitting with the margin planks, especially up forward.
I am also looking forward to the deck planking. However, there is a good bit of work to do before then. I need to complete the margin planking and the bulwarks stanchions. Then the cleats for the stanchions have to go in. Also, the hawse holes and the lips for the pipes have to go in. There will be a doubler on the hawse pipes on the inside of the bulwarks planking between the first stanchion and the knighthead. The chainplates and deadeyes need to be installed along with the railing. After that, the rubrail can go on the outer hull. Once that is all done, I can paint the hull, along with the inner bulwarks and the margin planks. Only after the inner bulwarks and margins have been painted can I plank the deck. I want to have the margins painted and the deck to be left natural.
Russ
Take your time!  I went the other way on mine and left the margin planks natural to match the deck.  I'm looking forward to seeing your painted version :)
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Augie:
This is a compromise on my part. Normally, the deck would be painted as well, although it might be a different color. Quite often they used white on the inner bulwarks and grey on the deck. I have used the white margins and natural deck on a model before and it looked good. I just cannot bring myself to hide the lines and subtle shades of the deck planking. :)
Russ
Russ,
Was able to take a minute and catch up with your build, as always ice clean work.
Curious about your scarfs. On your "MKIII" piece you ran your scarf from outboard to inboard, ie, the shorter end of the plank is outboard. When I did mine I went exactly opposite, mainly because that gave me the longest usable planks at the bow and just went with it for continuity. Do you know if there is a preferred direction or does it matter?
Sam
Current Build Constructo Enterprise
Sam:
Thanks.
I have seen these scarph joints done both ways and there is no specific reason why I did mine this way. This is one of those items that I would like to research more down here and see what I can discover.
Russ
John:
Thanks. I am fairly pleased with the piece. It could be better in places, but once it has been painted it will melt into place.
The lips are about 5/32" long while the opening is 3/32" long. The piece is about 1/32" thick. Very fiddly. I have made another for the port side that is very nearly a match for the starboard side.
Russ
Nice Russ, sometimes i have a difficult time sorting out the size of some of these parts. Close up photography creates the impression that so much of this model work is big, when it is not big at all.
Michael
Michael:
Thanks.
That is very true about size. There is very little context in photographs. When it is a component on the table, I can have a ruler there to give some scale, but in cases like this hawse pipe lip on the hull, it is difficult to get a sense of scale.
Russ
Russ,
You should be happy with that Hawse hole.  Very well done.
Bob
Bob:
Thanks. I repositioned it last night and it looks a bit better. I have also made the corresponding lip on the inside. Later today I will have a chance to get that installed as well.
Russ
Russ,
Don't ask me anything about sizes. I find it hard enough to recalculate everything to metric ... it turns me :wacko: However, what I see I like. Very much
Carl
Russ,
You stopped using AF measures in the US? LOL
Carl
