Chapter II. Spars and rigging
1. Blocks
To rig this clipper d'Argenteuil a certain amount of single blocks in three sizes is needed. There is no general inventory of the amount of each kind of blocks which will be used. That will become clear during the rigging, therefore I will make a dozen blocks of each size and kind. If there are more needed, I can always make some more later.
I start with making the sheaves for de blocks.
To make the single block, I start with a thin strip of mahogany.
I glue blocks of mahogany on it at equal intervals.
Above that comes another strip of mahogany.
The method is identical for double blocks, only a thin strip of mahogany veneer is added between the two parts.
Drilling holes for the shaft of the sheaves.
The next step is cutting individual blocks from the glued strips.
Now every block is filed into shape.
341a.JPG.2481e9c9f744cdf4d9e12155b61087fe.JPG, 342
The sheaves are placed in it with a copper shaft.
The last thing to do: file a groove for the noose.
Now I have a small supply of blocks of each size. They are about the same size as on the plan, but I can't manage to make them as thin.
Thank you very much for reading this log and for your likes and for your constructive comments.
Till soon!
Those are some excellent looking blocks!
No, I don't have preconceoptions about people. Your talent speaks otherwise.
By hard solder I meant silver solder and by soft solder, which I get is what you use is the type with a soldering iron and tin.
Thank you for showing your nice work!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Many thanks, Hakan and Roger.
Not much has happened in the workshop this week. Yesterday the whole family came to help eat the Christmas turkey, so most of the time was spent preparing the feast.
Now the dishes are done and I can look back at what was accomplished this week.
2. Cleats
I need also some cleats on the deck, on the bits and on the spars. I make them all at the same time to make them as uniform as possible. I may have a few too many, but that gives me the option to pick the best.
Just like for the blocks, I use mahogany to make the cleats.
roughly sawing the cleats.
Filing into shape.
After they are varnished.
Till soon!
On 12/26/2021 at 12:08 PM, wefalck said:
Nice job on the cleats ! How will they be attached, with brass pins ?
Thanks Ebenhard, I think I will simply glue them. I am by no means a gifted micromodeler like you are.
3. Bowsprit (jib boom)
The bowsprit is made of pine wood.
I start from a square piece.
I scrape it into an octagonal shape first ...
... and then sand it into round shape.
The very top of the bowsprit ends in a short thin part.
just behind that a slot is made in which the sheave for the jib traveler will be placed.
The bowsprit must be bent. So I wet it and place it in a simple jib for a few days to keep its curved shape.
The heel of the bowsprit ends in a tap ...
... which secures it in the bits.
The sheave to operate the jib traveler.
On top of the bowsprit comes a mouse cleat.
Till soon!
That is a seriously long bowsprit! 😮
Looking good GL. 🙂
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Interesting process for making the blocks, they turned out very well. What are the dimensions for the 3 sizes please?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Looking good GL. 🙂
Thank you Hakan,
Yes, it is very long. My model has already become almost twice as long. There will be also a boom that extends far behind the model.
Hi Keith,
The big blocks: 10 mm
The medium blocks: 8 mm
The small blocks: 6 mm
The blocks still have to be provided with a strop. For some it is rope and for others metal. I'm waiting for the rigging to put them on and varnish the blocks
Edited by G.L.
After the bowsprit is varnished and dry, it can be rigged.
In addition to the securing tap in the bits, the bowsprit is also held in place with a metal ring over the bow.
Before rigging the bowsprit, the jib traveler must first be made and placed.
The bowsprit is also supported by three pulley systems, one amidships, one on the port side and one on the starboard side. I suppose pulley systems are used here to allow for trimming the bowsprit for each regatta.
For the midship pulley system, a double block is placed just above the waterline on the bow.
a line with a noose over the top of the bowsprit and with a single block at the other end forms the second part of the pulley.
The rigging of the midship pulley.373.thumb.JPG.9f4dcf470bc6e7517f3ea3363fe75aeb.JPG
In addition to the midship pulley, the jib boom is also supported on the left and right by a pulley. The hoist is attached to the hull to an eye plate bolted to the wale.
Making the eye plate:
Rigging of the side pulleys:380.thumb.JPG.0185bbcbae7d6bd285aafb62375d7d37.JPG
Till soon!
These boats had indeed a very lofty rig. There is not a loft of wind here in the Paris region and in addition the Bassin d'Argenteuil is surrounded by high trees (e.g. poplars as can be seen on many of the Impressionists' paintings). Plus, the main westerly wind direction is blanketed by the range of wills to the South and West of the river. I gather that these hills also make the winds blowing downwards with eddies forming in the valley. The Northern side is mostly flat, but the Seine has cut into the old flood-plain a few metres. Overall not a good sailing range, but it was easily accessible from Paris.
While in later years 'real' yachts with quite deep keel were sailed on the Bassin, a boat with a drop-keel and 'live' ballast is more appropriate for a river, such as the Seine. This limits how high you can make the rig in order to not create a too big fulcrum - although a high rig might catch more wind in the valley. I gather that is is why they extended the length of the rig, in order to be able to set more sail. During races these boats needed quite a bit of live ballast. I seem to remember seeing photographs that showed four people on board, but I don't remember, whether sandbags were still used on the Clippers.
Nice 'iron'-work on the bowsprit, btw 👍
Quite a complicated bowsprit rig, very interesting. I'm not sure it is a boat for a squall?
Thank you for the block size details. I need to make many in 3 sizes
large 7mm,
medium 6mm,
small 5mm.
Looks like being a lot of fun but i will need to think about simplicity of production.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks for the compliment. Also nice to get some information about the sailing area from someone with local knowledge.
large 7mm,
medium 6mm,
small 5mm.
Thanks Keith. Knowing your sense of detail, your blocks will be more detailed than mine.
4. Mast
To make the mast, I first saw a square stick to the appropriate length. Here it stands in the tabernacle:
At the bottom of the mast step there are three slots in which the sheaves for the mast raising pulley come.
The mast is made in the same way as the jib boom. First I scrape it into an octagonal shape and then I sand it around.
The top of the mast narrows in two steps. I make the tapers using the lathe.
Fitting the mast in the tabernacle.
I sand the mast step around where the sheaves have to be placed.
The sheaves:
The mast, ready to be varnished. Two more sheaves are incorporated in the top and two mouse cleats have been fitted.
The mast on the model:392.thumb.JPG.5a74fec358dcdaf36a499fc821227af8.JPG
Till soon!
The mainsail is attached to the mast with slugs that run over a rail. To make the rail I solder two brass strips together. One with a flat profile on top and one with a square profile. It's hard to see in the picture but the drawing next to it shows what I mean.
The rail is then glued to the mast.
Making the slugs is another matter. For some of you that is a piece of cake, but first I had to think about the method to follow. Finally I solved it like this: I saw off one side of a brass square tube with the same internal dimension as the rail.
Then I knocked the raised edges of the tube flat around a strip like the rail.
Next I saw a slit in the slammed side.
I saw my slug profile into pieces and also make small brass rings.
When I solder both together, I have a slug.
A slug on the rail.
All slugs on the rail.
Till soon!
Nice brass work!
I hope your rail stays put on the mast. I would be a bit worried about differential thermal expansion of the metal and the wood, and about knocking it off by accident. Perhaps glueing it into a slot in the mast would have been more secure?
On 2/12/2022 at 6:35 PM, wefalck said:
Nice brass work!
Ebenhard,
You're probably right, but I don't have a precision milling machine to make a neat slot so I'm just trusting that the rail will only stay on the mast with glue.
On 2/12/2022 at 8:52 PM, jlefever said:
Nice metal work indeed! Jim
Thanks Jim.
Time to rig the mast.
Before rigging the mast, the pulley of the tabernacle must be rigged. The halyard for erecting the mast has already been split at the fixed part of the hoist and must now be passed through the sheaves at the bottom of the mast.433.thumb.JPG.b2f4a635bf2e32190749b90f9e077f1c.JPG
The mast is supported on both sides with two shrouds and dead eyes.
The dead eyes are tuned on the lathe from a piece of hard wood.404.thumb.JPG.fc17fbd65005ee7bd35a0fbb2e399ce8.JPG
I use my proven hinge method to drill the holes in the right places.410.thumb.JPG.4e455eff79fc43916598f23cfc9f4bb5.JPG
Making the strops
418.thumb.JPG.51f4d2911e2fed1d2697d3439b660ba2.JPG419.thumb.JPG.9ac43dc84e847536fd4e2d5c53db4139.JPG
Edited by G.L.
The part of the shrouds that goes around the masthead is served.422.thumb.JPG.bc3ae248becae23013e1c54d9c33cb01.JPG
I make a small spacer gadget to help me to keep the space between the dead eyes equal. Two small nails in the top dead eye avoids it twisting.425.thumb.JPG.34118553d686efc96a5bd0f74da85564.JPG
Now the lanyards go through the dead eyes
and that is the situation as it is now.
Till soon!
That's a clever drilling jig for the deadeyes 👍
I am actually quite surprised that such kind of boat still uses deadeyes. Given the quite close connection that the French yachtsmen had with those in the USA, I would have thought, that screws might have been used already. Or hearts and lanyards. Deadeyes look rather 'rustic' on such a boat.
Edited by wefalck
Well I also think turnbuckles seem more normal for this type of boat than dead eyes. There are no dead eyes to be seen in the 19th century paintings of the Seine sailors either, but these are mostly impressionistic paintings in which no details can be seen. Frankly, I'm glad there are dead eyes on the plan because turnbuckles seem much harder to make to me.
I just had a look at the images that I had collected for my series of articles in our quarterly DAS LOGBUCH and there are one or two photographs taken by Gutstav Caillebotte's brother that show a Clipper reasonably close and it looks indeed that they used small deadeyes ...
5. Pins
Before continuing on the spars I want to make the pins first. The pins are made of a brass rod over which a brass tube of half the length is soldered.437.thumb.JPG.c2239deead7b85922be6537955c8ed8c.JPG
The tube becomes the handle and is filed into shape with different files (not only this big one).439.thumb.JPG.e1bc2ddbda148d7ce6d04b573b7af457.JPG
In this photo you can see the three successive steps from left to right.440.thumb.JPG.b1dc709a3bf718f81bc11d98817d323d.JPG
Edited by G.L.
6. Gunter
The clipper d'Argenteuil is rigged with a Houari sail, so the gaff is very steep. I believe the correct English term is 'gunter'.442.thumb.JPG.79f0bb0459f04342c2b11699249d4ab1.JPG
The gunter is also lifted along the mast rail. The gooseneck of the gunter fits in a special slug on top of the sail slugs. Making this slug correctly and in detail is a bit beyond my metal skills. I still managed to make something that didn't differ noticeably from what it should be.443.thumb.JPG.65cf2274b68bd871ae6fb648742bc590.JPG
To make the gooseneck I use some telescopic brass tubes that I solder together.447.thumb.JPG.693cc7305b8152428f13f30112d9d34d.JPG
I then file them conically or the lathe.449.thumb.JPG.b05f04236edd8e94ec2412820bf5f844.JPG
There is a slit at the top and bottom. Sawing the slot.450.thumb.JPG.abb33822a8657efbf203d566e507dcf3.JPG
All the parts of the gunter goose neck.453.thumb.JPG.2d19b7c56333bfe4033717f786e5b344.JPG
When the gunter is raised on the mast, it is held upright by a metal violin block that runs along a guide rope.455.jpg.01b3fc43ace63d6fa5f3d8b6a986a5e7.jpg
The hoisted gunter.
Till soon!
Looking good !
As you have a lathe, I am wondering, why you build up the goose-neck for the sliding gunter from tube-sections, rather than boring and turning it from a piece of round brass?
Very interesting boat GL and very nicely done so far! It was a pleasure to catch up. Looking forward to the rest of the journey, it will be interesting to see how the rigging will be laid out
Vaddoc
This is a difficult subject: light structural members, and long thin spars and you're doing a great job.
I am wondering if these racing machines were "dry sailed" - kept out of the water when not in use.  This was common back in the day of wooden dinghies to keep weight to a minimum.  If so, that would account for the mast that could be lowered.  On the other hand, a planked wooden boat will leak badly if allowed  to dry out.
Roger
