Hey guys ... I'm new here and wanted to try my hand at a wooden ship model. I cannot hope to complete anything as remarkable as the build logs I've seen but I want to try anyway and you've gotta start somewhere. I chose the Syren because I like her lines without regard for difficulty. I belonged to a yahoo group about model ship building around 20 years ago although I have no real experience building a wooden model. I did build a cross section of the USS Constitution back then but I can't say I knew what I was doing although I did learn a lot. I have started several other kits but got to hull planking and abandoned them. That was before forums (I even remember B&W TV) so I will rely on you guys for assistance in explaining things to me. I do have a fully equipped woodworking shop and experience mostly building small projects like boxes and chessboards although I have done a little furniture. I have also done some wood carving. I should apologize for the photos I will post. I lost my left leg so I am wheelchair bound now and unable to get better angles but I will do the best I can. I am retired now so time is available as long as I am not seeing that endless string of doctors.
I got started by gluing the rabbet strip to the bulkhead former and then the stem. From there I cut out the rabbet. I have never done that before so I hope I did it correctly. I used my scalpel to thin the deadwood area which actually was easier for me than the smaller cuts along the bottom of the bulkhead former.
Then I sanded as best I could making the transition as smooth as possible. That discoloration is a result of that sanding.
I am now beginning to attach the bulkheads. With a background in engineering I know that the foundation is critical for the entire project so I was careful to get things square. I started with the center area because the bulkheads are larger there so it is a little easier to get the square in place.
I have some leftover basswood blocks for carving that I intend to use for fillers. Cutting them on the tablesaw is next.
I didn't see any indication of where the masts will go so I marked one side of the BF from the plans as I will undoubtedly have to drill holes somewhere along the line. I am also undecided as to the platform for the ship when completed. I have a decent pair of brass pedestals. If I use those I will have to prepare the BF for the nuts and bolt holes along with reinforcement. That is a lot more work, of course, so I don't quite know what I want to do. Any suggestions?
Ken
Does anyone know an easier way to remove char? I have tried scraping with a razor blade, vinegar and pumice as well as sandpaper. The sandpaper seems to work best but even with a block there is the chance of rounding edges. Thanks
Ken
Been moving ahead with the Syren. I finished gluing in the bulkheads, making sure they were all square to the bulkhead former. I installed the keel and began fairing the bulkheads.
They were a bit unstable so I determined to add the filler blocks first before fairing any further.
Filler blocks are pretty simple using a mini table saw. They tend to be repeatable cuts since all bulkheads were squared to the BF upon glueup. I didn't have any particularly large pieces of filler to use - I have basswood available so I used that. That should be sufficient to stabilize the decking and the bulkheads I would think. We'll see as I progress ... if I need to add more I can do that.
One area that concerns me slightly is with the deadwood ...
The bulkheads extend below the bearding line that I cut slightly although this might not matter in that area - at least I hope I can work around any problems that might arise. But anyway, progress.
Thanks for the likes and for looking. :)
Ken
If you’re just removing char, then sand paper is good.  If you’re also beveling the edge, then a chisel works well.  You've picked the model with the best instructions you’ll ever find.  Plus, there are phenomenal build logs to study.  I hope it goes well for you.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
Thank you Matt ... I've seen a few of the logs which give me something to strive for anyway. I expect to do my best but have it a far cry from what I've seen. they also give me a great way to see how people approach various problems in a build.
Ken
Well, my first major screwup. In fairing the hull I found the stanchions at the top of the bulkheads were so fragile that I inadvertently broke and had to re-glue two of them while sanding. So I figured it was smarter to do the sills and lentils first so as to strengthen the stanchions then fairing would be easier and somewhat safer after that. So I proceeded to fit about 8 sills on the port side before I realized I had been gluing them with their tops at deck level - not their bases. So I have to unglue those now and fix that. More of an annoyance than a mistake but it sets me back a little. Live and learn ...
Ken
Just about everyone has done this at one time or another, some of us more than once...   its like a right of passage.
I agree with Justin.  This is more of a minor screw-up that you can easily recover from.  But you are right that the sills and lintels will help strengthen them going forward.  Some people have also used binder clips to reinforce them while you are fairing.  They can make the hypotenuse of a triangle between the flat top of the bulkhead and the upright.
Completed Builds:
Thanks guys. I was pretty active in the art world not too long ago and found the same basic thing there. We all make mistakes - especially at first - but nearly everything is fixable and you go forward wiser (at least hopefully so). I used to try to get that into my student's brains - patience is "the secret" in art as it in with any skill. You have to have patience with the creation - it takes time and you cannot rush it. Some parts take longer than others and you have to give each part equal attention or it will show in the end. And you also have to have patience with yourself because whatever the skill may be it is going to take time to master as well as allowing yourself to make mistakes along the way. The trick is not to repeat the mistakes (too often anyway :)) But being human we all do ...
Ken
More of the learning curve ... always the hard way it seems.I put a strake along the bottom of the sill line and then glued the filler sills even with that and let them dry. Next I cut a length of wood exactly the size of the gun ports to make gluing the lentils easier. Unfortunately the sill line was too high (AGAIN!) so I am now faced with removing the sills and replacing them at the right height. Lesson learned though ... the bulkheads were cut with a laser so presumably they are very nearly the correct height. Therefore starting at the top and working down ought to give me the correct sizes for the gun ports and associated filler blocks. It has given me a lot of practice with my table saw however so that is a plus. Anyway, slow going because I keep having to fix errors but this is a good time to make them as redoing things isn't so difficult now but accuracy will show as time goes along.
Anyway, I'm still moving forward albeit slowly ... so anyone watching shouldn't lose hope with me. I do tend to dread planking the hull as I have never got that far before. In fact I've never done so much small work in fitting pieces before so it's all new. Thanks for bearing with me. :)
Ken
Planking is definitely the major hill to climb when first starting out.   I would get really worked up over it and did cause me to abandon some very early projects.   What I learned is to use the right kind of glue (PVA) so you can back-track if needed more easily and to not let perfection get in the way of progress.   The nice thing about kits like Syren is that the hull is partially painted and then coppered, which means you can be a little more forgiving of mistakes as they will be more hidden.   Things like filler and sanding can make what looks to be terrible planking job much more acceptable to the eye.   Obviously it is important to TRY and do it correctly as best you can (so you will get better), but I would not to agonize over details as you go.
There is always a way to correct a problem, and we are all here to help out when you need it.   Ive always felt that my best and most useful tool is MSW.
Thanks guys ... no, no pictures just now. Being in a wheelchair hampers my ability to get decent angles - although I am going to attend the workshop next weekend on photography so that should help. I have a nice lightbox but, of course, the ship won't fit in that. I'll endeavor to get some photos this weekend though.
I have watched all the Occre videos with special attention to the planking so I have a bit more confidence. One of the biggest things to get right, it seems to me, is to put the first strake in the proper place. If you get that messed up the entire planking will be off to some degree. That is one reason I am having such a hard time getting the gun ports in the right place ... but perseverance is one of my stubborn parts so I will get it at least close. I seem to prefer learning the hard way but at least I do remember those lessons for next time. Thank goodness ... :}
Ken
Now I have a problem I don't know how to fix.The space between the lentils and sills isn't large enough for a gun port in all places. Lentils are about at the top of the bulkhead formers and the sills are even with the deck - more or less. I can't very well raise the lentils higher without rebuilding the bulkhead formers but if I lower the sills the guns will sit too high on the deck for the ports. I cut a piece of basswood exactly the size of the gunports to facilitate the uprights (it is shown in one of the photos) but it won't fit between the tops and bottoms of all the ports. What do I do now?
I waited for a time hoping to get some ideas here ... alas none were coming, so I put my mind to considering my dilemma. The bulkheads were laser cut so presumably they were close to accurate in height for framing the gun ports. My try at putting the sills in line basically with the deck resulted in uneven port openings which would have been disastrous for the final result so I stopped as I mentioned in my earlier post. So if the bulkheads were correctly cut I could reasonably leave the lentils glued along their tops. I had cut a length of scrap exactly the size of the gun ports so I removed all the sills and used that piece to glue the sills in place by placing it under the lentil and then simply pressing the sill against it until the glue took hold. I spent most of today in that pursuit although I still have a couple small sills to attach. I have also cut the vertical pieces of the gun port frames using my table saw so I am sure they are the same and will have at it with the vertical frames tomorrow or as soon as time allows. Unfortunately I did not get any photos today but will take the time to get some for my next post. The good news (from my point of view anyway) is that I am making headway again after getting stuck for a time. I do believe my method is going to give proper results. One fear I had was that the sills would be too low thereby removing the lower lip of the gun port so the gun could possibly simply slide out into the water which would not be realistic. From all that I can see, the sills appear to be slightly above the deck level which is more or less where they ought to be. So one major mistake (presumably) overcome and I can move on to discover new errors. Thanks for your patience in this ...
Ken
Im wondering first if you used the templates provided in the kit for laying-out the lintels?   That should have helped with some of the spacing.   As well, the area at the bow seems to be sweeping upward where spacing should be uniform stern to bow.   Cutting out the templates and comparing against your current state might help point to a few places where things are going wrong.
Thanks Justin. There may still be a bit of a rise in my lintels/sills near the bow although I did redo all the sills from the last photo group - I will have to check that out with the templates. I got started framing the gun ports from the bulkhead that has the vertical frame tightly against it - seemed a good place to start. Nothing is faired yet so lumber is different in width but that will all get sorted. It looks much more promising at this time (compared to where I was when I realized things were amiss).
Ken
From the pictures, the sills and lintels look much better! Great job!!
Edited by WalrusGuy
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Agreed!   Looking more like it should now.  Nice job identifying and correcting the problem.
Woohoo!  Another Syren build!  I'll follow along with interest!!!
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
OK ... another update. I spent a tiny amount of time (NOT) sanding but I am now pretty close to finished with that and framing the gun ports/sweeps. I have also faired the hull although I still need more filler blocks there. That shouldn't take too much time and then on to the stern framing. I know this is far from perfect and there may well be many mistakes in this so far, but it's the furthest I've come on a wooden ship. I have started several in the past but once I got the bulkheads done and sometimes the deck plate things went awry and I found myself abandoning the project and losing confidence. But I'm a pretty resilient fellow so here I am yet again with another attempt but this one has moved further along than ever before. :)
Sorry about the angles of the photos. Being in a wheelchair has a couple disadvantages one of which is setting up a photo can be very difficult and getting a decent angle can be nigh impossible. I did the best I could which I hope will be enough for folks to get an idea of how it's coming along.
One area that is causing me some trouble is on the inside of the gunports near the deck supports on the bulkheads. The sills extend down into that area but getting sandpaper along there is really tough. I was thinking of using a Dremel with a flat sander wheel - like a cutter but for sanding. If it should cut into the deck supports a little it won't matter but it is somewhat uneven down there and needs to be fixed before moving much further ahead or the planking will be uneven and lumpy. And I need to go after the ports and sweeps with a square edged file to square them all up before I think about planking them. That will take some time I think but it's important that the framing be as accurate as I can get it. Ah well ... one day at a time.
Thanks for looking,
Ken
Take a look at my build. I think that’s a problem for most folks. The way I did it (lifted from another Syren log) was use a self adhesive rotary (disc 5”) sanding pad 120grit.
if you peel off the adhesive from the back and double it on itself, it’s thick/stiff and a little malleable. You can also trim it with scissors so when you sand the inside bulkheads the sanding pad will ‘skip/slide’ over the frames as you sand from stem to stern near the deck.
Just one idea you might want to try.
Looking good!!!!
Edited by Overworked724
Thanks Patrick .. that sounds like what I was considering using.
In the meantime, I framed the stern and sanding it flush. There are gaps and some things aren't exactly square, but I think all will be well considering that it gets planked - and even that can be filled with filler if necessary. The rail section still needs flattening though and the gun ports need filing and squaring but ... headway ...
Edited by SparrowHawk7
I'm back although I doubt anyone missed me. I am a slow builder as my life tends to get in the way a lot. But I try to find time as regularly as possible to make more headway on the Syren. This log is likely going to end up as more of a what not to do than a tutorial on how to build her. Still I persevere and will continue to do so.
This was my first experience in bending wood. I know how to do it with large pieces for furniture but never did it will such small pieces. I ended up using a soldering iron and water as it just seemed easier but overall it was fairly simple and no problem at all. I broke one timber by trying to bend it too fast but once I got a feel for the wood it was very easy. In these photos I have cut out the areas for the gun ports and sweeps (on one side) but the edges have not been done so they are very rough. I expect it will just take some time to do but not be very difficult using a file/rasp. I may have to repaint the red in places but that is simple. There is one plank that got out of line and may need to be unglued and redone but the rest are about right. Just one more strake on the port side and the bulwarks will be planked on the outside and I can move on to the stern.
I got over my fear of bending/planking and actually find it fun and somewhat interesting. I am mostly interested in rigging and wish to try to do it as the actual lines were done in the period along with a ropewalk. To that end I got a copy of Steel's 1794 publication which requires some other references as the terminology is somewhat archaic. But I am really looking forward to being able to do that with the model although it is obviously a LONG way down the line.
I apologize for the poor quality of photos. I am unable to move to get a better angle due to my wheelchair so I have to show the mess of my work area and that glaring light. Please forgive me. And thanks for your patience and anybody who might be watching.
Ken
That’s coming along nicely!!!
I finished planking the hull this afternoon but no photos as it looks pretty rough. Once I get some sanding done it looks a lot better but the stern is sad. Still, it is fixable. The problem was the fairing of the bulkheads which I didn't do very well I'm afraid - it curves in to the deadwood too far down so the planking on the stern that I began doesn't fit any longer. Oh well .. that is fixable and although the ship will depart from correct lines, I think it will still work. And I was not honestly expecting my first build to come out perfectly anyway.
I made one rather major mistake and I could use some advice on hiding/fixing. The forward gun port on the port side I cut out on the wrong side of the bulkhead! I don't know that I can fix that without it being too obvious. I will obviously display the starboard side now, but I need to hide this mistake as best I can. Perhaps leaving the gun port closed and not put the canon in place is one option. Or ignoring the mistake and plunging ahead but that will make the mistake rather obvious. Plugging the hole and cutting it on the other side of the bulkhead might work but the plug will be rather obvious with the butts in a row. Maybe I can take off more of the planks and feather the patch in better. What do you guys think?
I am rather pleased with the progress so far even though it looks pretty rough ... but I've never got to this stage in another model build and I don't see any reason why I won't be able to complete this one. So that is a major plus. :)
Here's a photo I am not fond of but it shows the mistake clearly. Oops.
Ken
I think it's really looking well so far. One thing you could try with regards to the gun port being installed a bit off-center would be to make another gun port midway between the two and maybe make it symmetrical across both sides.  I'm really not certain what the other side looks like, but another thing to consider will be that once you have all the deck furniture and rigging up, that your display direction will probably be the best fix unless you want to rip off the bulkheads and start over with the correct alignment of the gun ports. Frankly taking off the bulkheads at this stage above the whales shouldn't give you too much difficulty. In truth it might give you an opportunity to do an even better job since you've already had some practice putting in the bulkheads and carving out the gun ports. It's a lot of work though, and I think so far your build is looking marvelous!
Thanks Patrick ... I fixed the problem correctly. I tore off 3 strakes from the bow to the gun port and just replaced them the right length. Wasn't near as hard as I had expected but it's drying now and looks much better.
I've been sanding up a storm with 80 grit but need some wood putty to fill in gaps. Getting there ...
Ken
Ken
Awesome!  I’d have done the same…I think you’ll be so much happier in the end. 👍🏽 Nice fix and looking forward to your next steps.
Got some photos at last. Overall I am rather pleased with the way this turned out although there are tons of errors. But it was my first time and she actually looks like a ship! I fixed the gun port issue and then discovered another ... instead of 10 ports per side I only cut 8! I may leave things as they are - but opening 4 more won't be that difficult. If I am going to do it now is the time. The planking was not as difficult as I had anticipated - not easy nor without errors, but I didn't go in expecting to finish her so with that as the litmus test, I did OK. I have tried planking with a number of kits and failed to the point of trashing the kit without finishing much of anything so I was rather expecting that outcome again. I had rather low expectations with the Syren ... There are some areas that are not very smooth and have dips but I know where I went wrong and it is mostly a matter of experience and skill which will come in time. Some of it will be covered by the coppering, of course, and some by paint. The bulwarks are OK so they will look decent with finish. There are some noticeable gaps between planks but I can live with that overall. The gun ports are not square yet and the sweeps are not all cut either.
Then we get to the stern. Sigh. It will work but not very well I'm afraid. Somehow I got the strakes askew and since they build upon one another the entire stern is off. I did not bend the strakes either so there is a bit of a gap under the top piece. I can live with that and a little wood putty but I do not think I can remove the lower strakes. I built up the areas under there and glued the timber in place firmly before trimming and sanding to shape. Removing might be too difficult and leave lots of small debris. A little of that askew illusion is due to the angle of the camera but it is off a little in reality. Personally I think the workman who framed and planked that area was drunk at the time.
So a bit more wood putty and sanding and I think she may do. The deadwood is too wide yet and needs to be sanded down a bit more but it's not bad. There are also a LOT more strakes on the stern than there should be but the general shape is correct. I didn't bend the planks far enough to firmly attach to the bulkheads and formers back there so they assumed that particular shape.  Somehow both sides were about the same so I went with that rather than tear everything off and start over - especially as I hadn't quite expected to finish planking the hull in the first place. This isn't a particularly good job I know, but I think I can live with it considering I believe now that I will be able to finish her. I will put it all up to practice and inexperience with beginner skills - just like I have always done in my art.
Here is an example of what a couple years made with my drawing ... I see no reason why building skills in wooden model ships should be much different. Time and practice and allowing myself the opportunity to make the mistakes as a beginner and learn from them. Thanks for watching. :)
Ken
