Has anyone come up with a great push stick for a hobby table saw? I just started trying to make gratings and and it's kind of tight. When you get down to cutting .020" planks and .040x .040" strips it starts to get dicey as to whether you keep all your fingers. My fence is 1/4" high so that may be one thing I can change. The table is about 12" long so ripping anything less than 6" means that the wood is right in the corner between the fence and the table. Is a consumable push stick maybe the best way to go? Any thoughts?
Oh, I just remembered the Byrnes saw post at the top of the page. I'll go read that now.
Pencils.  Use the eraser against the wood.  It grips better than wood on wood.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Pencils are great as has been mentioned above.  I also use chopsticks (buy them by the bag) and just notch the end that will be pushing the wood.
While on the subject, I have made small featherboards from tongue depressor/lolly-pop sticks, they are invaluable on the fiddly bits.
The medical grade tongue depressors in my stash seem to be made from pretty good wood.
STAY SAFE
current builds:
What ever push stick you make sure to keep your fingers away as far as possible!
EDITED OUT GRAPHIC PHOTO, ADMIN
Edited by James H
removed gory photo.
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
