I have a set of chisels and would like add some palm gouges and would really appreciate suggestions.   I'm a novice here, so I don't know if I should buy individual tools or a set?  Also would appreciate specifics on which set or individual tools.  Right now I'm building a kit, but have plans to continue to scratch building with hardwoods.  I tend to purchase good quality tools so I was thinking of Pfeil or similar tools as appropriate ones.
Thanks for your help!
Jeff
aka HobbyMill
Current Build: Constitution
Jack
Current buildUS Constellation
Hi Everyone and thanks for your replies.
Vahur, Thanks, I did see the thread on the Russian micro carving set started by Druxey and that was what got me interested in some additional tools and I may pursue that route.  Does anyone know if they are still available?
Jim, thanks for taking the time from your busy schedule to respond.  Great to see a pic of your Conny and your wonderful workmanship.  I've often wondered if you had continued that build.  If you wouldn't mind letting us know which ones that you use the most, that would be really helpful.  I'm tempted for both sets, but if you mainly use only 1/2 of them then that might be a little pricey at my skill level.
Jack and Hsae, thank you for helping out!  A lot of information for me to digest and I really appreciate your taking the time to help a novice.
Thanks,
Jeff
aka HobbyMill
Jeff,
The size of the chisel is determined by the job it is being used for.
Dockyard micro chisels are a size for decorative carvings - usually 17 century and first half of the 18th century.
For larger jobs there are FlesCut and UL Ramelson.
FlexCut are not difficult to find.
Mountain Woodcarvers  sells both Dockyard and Ramelson.
This company is having a sale on factory seconds from Dockyard.
UL Ramelson has a web site and individual chisels are available there.
It is a pain to wait and frustrating not to have what you need , when you need it.  The economical way would to get to a task, guess the size and shape of chisel needed and buy just those.  This advice that I cannot practice myself,
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Here's the response from Larson:
Hey ~ those are the manufacture part numbers  ~  I'll add our numbers to your list  ~ if you need anything further ~please let me know.
5303-10  1mm wide  512-0310
5306-10  1 mm wide 512-0610
5301-15  1.5 mm wide 512-0115
5311-05  .5 mm wide 512-1105
5339-15  1.5 mm wide 512-3915
5311-10  1 mm wide -512-1110
BTW the above is what is included in this set:  https://twocherriesusa.com/product/micro-carving-tool-set-of-6-octagonal-hornbeam-handle/
Thanks Jim!
Edited by Boatsinc2000
Jeff
aka HobbyMill
