John, you are rolling right along with this build. Beautiful job so far.
-Brian
Current Builds:        Completed Builds:
Mississippi River Towboat Caroline N.                                                    HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways
Side Cabins completed…
A bit of Micro Electrical work needed to repair where the Carpenters drilled a hole for the Hog Frame. Seems the wiring was cut on the underside of the boiler deck. Fortunately, the electrician was able to affect repairs and construction may resume. 😆
There’s always something…
Check out the special effects in the side cabin windows.
Back to cutting in Widows…
Cheers 🍻
Saloon Skylights…
The skylights on the hurricane deck were above the Grand Dinning Hall.
Skylight/Transom Windows framed out.
1/32” strips for molding…
Chandeliers hung inside the dinning hall. 😎
Almost ready for the Texas sub-Deck…
Cheers 🍻
Hog Chains…
To forestall hogging and sagging, since about 1850, the hulls of wooden river boats were held in shape by a system of wire trusses, called "hog chains". These were not chains at all, but rather iron rods 1 to 2.5 inches in diameter, which ran from strong points in the hull to vertical timbers, called "hog posts, which looked like masts, rising above the hull. Tension on the hog chains was adjusted through the use of turnbuckles. Generally the hog posts which carried the chains did not rise above the cabins on Mississippi River-style steamers, however here the hog posts are clearly visible rising above the superstructure of the Robert E Lee.
Should the hog-chains break, the hull would come out of tension, and start sagging on the ends. This was called being "hogged". In some cases the sagging on the ends would be so great that a boat's hull would break in half. Accidents such as running aground were the kind of things that could cause hog-chains to break.
Using brass wire to create the hog chains.
Starboard side Hog Chains installed. That was easy, NOT.  🤪
Port side up next… 🍻
Edited by John Ruy
21 hours ago, bobandlucy said:
I really  like the looks of this boat. . . particularly the supports for the overhanging portion of the second deck.
Those are part of the steel truss systems used to strengthen these massive Riverboats. Steam and steel, 1870 technologies.
Edited by John Ruy
Railings continued…
I have found the backside of blue masking tape to be the best clamping for these tiny builds. Gel CA glue is best to keep gluing minimal and not run on to the tape. Once the glue dries, I cut out the railing peel off the tape.
I am find Testors Flat White Enamel spray cans work best for painting this micro carpentry. 😆
Onwards… 🍻
Loving the progress John. Beautiful work.
-Brian
Hurricane Deck completed…
Trimmed up deck edge to mirror the starboard side.
Hurricane Deck stained and sealed with satin polyurethane.
Time to start thinking 🤔 about the railings and drapery.
Photo from a build log posted on Ships of scale… Robert E Lee built by Peter Voogt.
https://shipsofscale.com/sosforums/threads/paddle-steamer-robert-e-lee-scale-1-96-scratch-build-by-the-alan-l-bates-drawings-completed-build.5362/page-13
 Now we are talking about some serious micro carpentry 🔨 😆
Onwards 🍻
Edited by John Ruy
5 minutes ago, Altduck said:
Your Stairs look great installed in place.
Will you be adding guard railings around the deck openings?
Thanks, I worked on those stairs a long time. Yep, Railings lots of railings. 😆 Hopefully, I won’t go mad in the process. LOL 😂
Railings continued…
Used rubber cement to affix vertical posts to template.
Used  gel ca glue to attach horizontal rails.
Removed new frame frame from template.
Attached rail stanchions and trimmed.
Attached and shaped drapery.
Painted railing flat white, Stained and affixed rail cap. Attached rail section between Boiler deck and Hurricane deck.
Rinse and Repeat… 1 of 20 sections completed for the Boiler deck. I will need to build another 30 sections of rail only (no drapery) for the Hurricane and Texas decks.
Onwards 🍺
