Here is my first build log of my second overall attempt at ship building
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
This was the first tricky part as the instructions have you bend the plank over the side of the deck and the battan.  It was very thin balsa wood so I did it in two sections, top first, then I pinned the bottom to the battan once the top part was set.  After that there is some trimming and the some sanding to the fit the bottom part, the next phase.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Here is where I have a serious issue.  The second lower section is about 150% bigger than needed and needs to be attached very specifically, I am stuck on this part.  Note the pictures, the instructions have you fit it on against the keel, ending at the transom and the forward bulkhead.  Also, it seems to twist from one end to the other and needs to be trimmed down, but where I am puzzled.
 This is where any advice would be awesome!
Edited by cdogg
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Also I will note that have ignored the transom for right now, I will deal with that later as I think I can do a few mods to it.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
It's been a while since I built this kit, but I do remember having difficulty with that lower plank.  As I recall, the amount of bending at the front was particular severe.  I believe i got around the problem by making an approximately one inch long cut in the plank parallel to the keel and about half-way up the the front edge.  Once the plank was glued and dried, I filled and sanded the resulting small gap in the plank.
Thanks Chris!  I will try that.
I don't want to break the balsa plank but regardless I need to trim it down but I can't figure out how to measure it previous to the modification.  This definitely seems like the hardest part of the kit.  I am pondering making each side into 4 planks instead but I worry about the angling up front.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Casey,
Here's another way:
Grab some cardstock and trace out what you have for the large piece of wood.. then carefully fit it to the hull, trimming as necessary.  When the fit if perfect, copy that template to the wood.  Try the template on the other side and see what needs fitting.  When done, carefully cut out the wood and leave some meat on it.  Then carefully, sand and fit.
Great idea Mark, I will try that out.  Thanks!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
I'm building a Smack right now. Here's how I did it:
Soak the balsa in a 50/50 mix  of amonia and water (15 min).
The side of the balsa that goes against the keel does not need trimming.
Use the 1/16th strip that you glued along the keel in a previous step as your foundation.
Fit the balsa against this strip snugged up to the keel (it should be quite pliable after being soaked).
Play around with it until you find the correct placement then glue it to the keel strip (rabbet), the bulwarks and the batten strip -in that order.
Carefully place some rubber bands around the model to keep the curve while it dries.
Now you can trim the other 3 sides.
Pete
Hi Casey,
    if you go here.....  http://modelshipworld.com/index.php?/topic/1221-muscongus-lobster-smack-by-teleman-midwest-124/page-1 you can see what I did... Hope this helps you out a little...
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
Pete, that sounds like good technique I will try as well.  My question about that is how soaked does the balsa get?  Does it turn into a wet paper or more like a card stock?  I haven't tried amonia yet, only rubbing alcohol with basswood.
Cap'n - Awesome, I really needed to see a good picture of how the bottom should look.
I have been out of town this week for various stuff, cannot wait to get back to the build on Saturday!
Thanks again to all for your advice!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
After 15 min or so in the ammonia solution the balsa just gets "bendy" not limp. What I mean is when you form it to the curve of the bulkhead it does not have the tendency to split along the grain that unsoaked balsa does.
Pete
Cool, I am planning to get this done tomorrow, I will post how it goes, thanks
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Well, got the hull squared away. Now to add the balsa blocks up front and soon I will moving it the deck
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Thanks again to all who offered advice for the hull. I made card stock patterns, fitted them, then soaked them in alcohol for 15 minutes and they slid right in!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Ugh, 12 days since my last update.  I am painting in the first layer of paint tonight and have almost finished the hull.  Will add pictures.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
For the last week my boat has sat dormant due to my work schedule.  I managed to almost get the hull done and now it awaits paint.  I must admit I am terrified of ruining this boat with the wrong color scheme but alas it is my first attempt at painting a wood ship.  Below I have applied sealer to it, which did a great job of blending in the wood filler and smoothing out the hull for paint.
Edited by cdogg
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Here is my latest needed fix.  Somehow I measured everything great but the crack is there.  Should I fill it with wood glue and paint over?  I was also think about placing a 1/8 x 1/16 basswood strip over it and staining that section.  The hatch door will be there so the basswood strip may need to be creative.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Casey,
Your smack is looking really good!
From experience, one good thing about paint, is if you don’t like the color, you can always repaint!  Lots of info about painting has been posted on MSW.  My two cents:  Invest in a good set of paint brushes and Tamiya tape.  Paint is cheap, so experiment painting on some scrap wood first, especially masking!
As for the gap between the cabin wall and deck.  Did you ‘dry fit’ the deck before installing?  The deck should have butted tight against the cabin bulkhead and cockpit bulkhead.  As for the fix, you’re on the right track.  The simplest fix is to use a filler piece of wood to fill the gap.  Keep the filler as small as possible, same color and spaced evenly on both sides of the hatch door.
Keep up the good work and enjoy!
Dee Dee
Edited by Dee_Dee
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
thanks Dee Dee.  I did dry fit it.  I think what happened was I got so obsessed with getting the bowsprit and hull lined up a may have moved it so this happened, didn't notice until I was too late.
I will go with the wood bits, post some pics later today
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Here is the painted version with the first side lining.  I used stain on the 3/32 piece, the 1/32 was too thin.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Well, almost done with the hull.  Decided to mix it up a bit, changed the side paneling to 3/32 basswood and stained it American Oak.  Jury is still out on the transom, somehow I always end up modding that.  Paint job wasn't great but it was my first attempt.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
The open holes for windows just seemed wrong, so I cut out some plastic pieces from a opened glue package and made some windows.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Front end needs some magic yet.  Also, I my last post I showed a decent sized gap on the location where the hatches go.  One piece of mahogany seemed to fix that.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Between the two boards I have a glaring issue that I am open to suggestion on how to fix.  I might use mahogany dust to fill it in, if any one has any cool ideas please let me know.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Casey -
Nice choice on the colors.  They look good together.  You are also doing a very nice job fixing those little gotcha's as they arise.
Not sure if you can close that gap in the rail by gluing and clamping or if there is some other answer.  Hopefully someone with more experience than me will chime in!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thanks Wayne, was very hesitant about the paint but it worked out ok. I started detailing yesterday, best part of the ship building process!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
looks good cdogg, Great idea for the windows, I was actually looking for  brass porthole's but all I could find are round one's and I like the oval opening's so I will probably use your Idea. I will be starting my Lobster smack soon. Great job
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thanks Pete. I just got a new workspace built today, getting back to boat this weekend. I am going to rig it in the next few days. Still undecided on the front end. It's a fun build once you get past that weird balsa hull section. I have tons of advice based off mistakes made, haha.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Right on cdogg, I was looking at the instructions and the parts, I was curious do you have photos of the weird balsa section ? is it the bow pieces? it looks strange how that goes together
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
