Sometimes I've done the same thing myself, but then excluded myself from that 'game'  as yourself and Captain Steve have.
What made you 'give up' ? you were on the right track ^_^
E
I thought Steve's remark was a hint, but I coudn't figure out what kind of hint.
Curiosity to the hint made me a sinner.....
Jan
okay here it goes.
A different change of pace from my usual offerings.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi,
I am pretty sure its the Royal Canadian Navy Joint Support Ship (JSS) but can't find an actual vessel name.
Cheers
Slog
Looks very much so, but...is that one already launched?
The order was granted june last year to Thyssen-Krupp....
Jan
Edited by amateur
Wow, you guys are homing in like a heat seeking missile, very impressive!!  I'll take any ship name or the name of the class, there are only a few in service.
Cheers,
Jason
In the shipyard:
I think we need a german name..
Jan
Hi Jan,
I believe it is known as Berlin class, 2 ships with an option of a third.  But still can't find a name for any of the individual ships.
Cheers
Slog
Slog, well done.  I'll pass the baton to you, that last what, maybe an hour :) .  Indeed it is the Berlin class, there are 3 in commission, Berlin, Frankfurt am Main and Bonn.  And yes, these ships will be used as the proposed basis for the Canadian Joint Support ship replacement.  Sorry David you got pipped at the post there.
Cheers,
Jason
In the shipyard:
Thanks Jason,
Sorry David.
This, I imagine will be to easy but here goes.
Usual flag and markings erased.
Cheers
Slog
Problem is that all those old pictures are coloured nowadays.
I'm pretty sure this is a WW-I hospital ship.
(couple of yesr ago we had all those red-white ships in the game at MSW-1)
Jan
Hi Jan,
WWII and yes a hospital ship.
Operated close to home and also played a part in a famous engagement.
Not sure if the photo is artificially coloured or not but the actual colours are correct;
"Article 5 of the tenth Hague Convention of 1907 ("Adaptation to Maritime War of the Principles of the Geneva Convention"); white hull with a green band interspersed by three red crosses on each flank of the hull, white superstructure, multiple large red crosses positioned so that the ship's status would be visible from both sea and air, and an identification number."
Cheers
Slog
Slog,
Not Vietnam War then....she just looks familiar to me.
Well done Andy.
Quite a history it's had.
Your turn.
Cheers
Slog
I believe its the Norwegian collier;
Storstad
after a collision with the Empress of Ireland which sank.
Cheers
Slog
Okay, here we go again.  Number covered over.
Cheers
Slog
Landing pad, a deck load and probably a tank deck, heavy derricks and bow doors probably hiding a ramp. The water moves around her like she is flat bottomed with shallow draft, so I would guess she is a type of ship built to do the same type of work as our LST's and can beach herself, retract herself after loading or unloading directly on a beach.
jud
Hi Jud,
I like your current train of thought.
Another hint; saw active service.
Slog
Hi Eamonn,
It is indeed the RFA Sir Galahad.
http://en.wikipedia.org/wiki/RFA_Sir_Galahad_(1966)
Cheers
Slog
