I also needed to make the waterway, the drawing shows a moulding but I went for a simple triangular section 1x1mm.
After cutting some 1x1mm square I made a simple sanding jig, the sides are at 45 degrees so that the section sits neatly  in place ready to have half of it width sanded away leaving a triangular section.
It gets very delicate, I managed to snap the first one I tried, then being much more gentle I managed to get two usable strips
Now to glue them in place
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
Waterways fixed in place,
cleaned up and added some detail to the stern I need a couple of bits of moulding to cover the ragged edges.
next job could be lining then gun ports.
As I no longer appear to be following Bills original here I am not going to add port lids, KISS
I think it will look better without them.
Question, can anyone tell me if there would have been scuppers on a cutter like this?
Tim
Current Builds :
I can find only one picture showing what are probably scuppers, none of the drawings show them.
However there must have been some kind of deck drainage.
It is possible that the bulwark planking had a gap at deck level but Lapwing/Speedy drawings show waterways so that's ruled out, which leaves scuppers.
Given the waterline, I would guess aft of the pumps possibly between the gun ports as below (tiny green dots).
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
That's what I thought, I will not be messing with this model to show it.
But there would have been an awful lot of water sloshing about on deck without any kind of drain.
Tim
Current Builds :
FWIW Chuck did include scuppers on Cheerful;
Aft, as shown in the painting above ( if those are scuppers ) wouldn't make much sense.
If I remember correctly, from some of the Cheerful logs, some builders chose not to model them.
I have seen several contemporary models that did not show them either.
I think it was one of those things that didn't show up on contemporary line drawings because they were taken for granted.
― Jimmy Buffett
On Hold:    Rattlesnake
1 hour ago, allanyed said:
contracts show the number of scuppers
Thanks Allan @allanyed what an amazing amount of detail we can call on from that period.
Interesting that the oar ports had their own lids
Tim
Current Builds :
They sometimes  had horseshoe shaped hinge plates and opened sideways versus vertically.  The first photo below is of a contemporary model of a fifth rate of 1689 at Preble Hall.  It is hard to tell but the second is a contemporary model of a 24 gun of 1745 from RMG and appears to have straight hinge plates, but they do open horizontally as well.
Allan
DSC01317.thumb.JPG.17b3e84c7cbb8a44524477b8c0bf15df.JPGSweepports24gun1745.thumb.jpg.d40ffa24e7c0880d9b741cf040ae13fc.jpg
Ok next question.
Just cut the rudder to shape but I can't find any reference on the drawings I have, to the rudder cross section or the cut away for the hinges ( name )?
@Thunder what did you do?
@allanyed are there any documents that give those dimensions?
thanks Tim
Current Builds :
That seems true of lots of things we build.
Tim
Current Builds :
Great question. Goodwin has drawings of the ports and hinges with dimensions on page 191.  I will try to post it when I get home.  From a contract.
OAR PORTS                 To make and hang all such Oar Ports as shown on the Draft Disposition of the Frame or as shall be directed.
Allan
Edited by allanyed
Ok next question.
thanks Tim
Here is the rudder from G Barlow's Cheerful.   I think the cutouts for the " pintles " can be interpolated fairly easy.
Some lines from the NMM.
― Jimmy Buffett
Hi Gregory
Thanks for that, it will certainly be enough for me to make mine.
Oh dear I seem to have done it again, I was going to line the gun ports, now suddenly I making the rudder. Focus, focus, focus
now I am here I will complete the rudder, pintles and gudgeons.
Thanks for all the help, advice and likes
Tim
Current Builds :
It all has to be done sometime and the brain needs a little vacation from time to time. Sometimes it needs a little ego boost (look what I did! type of thing).
The sternpost probably tapered (say 8 inches to 6 inches) and also the rudder (say 6 inches to 4 inches) and the rudder had a rounded leading edge (see shading on drawing).
Then again I might be wrong:
https://collections.rmg.co.uk/media/543/233/l0251.jpg
https://collections.rmg.co.uk/media/544/197/l0418_001.jpg
https://collections.rmg.co.uk/media/543/699/l0330_002.jpg
It seems the only tapering was from top to bottom. Add it to the list of things drawings don't show.
Edited by iMustBeCrazy
Craig.
This one's interesting, Study of a rudder lying on the shore 1835.
Craig.
Wow Thanks for all the research, the first one looks like it could be  an angled leading edge.
The drawing / painting looks more like a bevel than rounded.
I does look like a flat plank.
As this is no longer a model of any real cutter, I may use artistic licence here.
Personally I quite like the angled look, so I may just go with that.
Tim
Current Builds :
Hi Gregory,
Regarding English ships, the only dimensions for the sweep ports that I can find are in Goodwin's The Construction and Fitting of the English Man of War, (ISBN 0-87021-016-5,) page 191.  In his drawing the sweep port lid was 10 inches vertically by 12" horizontally and about 3" thick (the thickness of the planking?)  The horseshoe strap was 1.25" wide by 0.5" thick.
He also has a dimensioned drawing of a ventilation scuttle, the use of which started about 1778.  These were fitted in every other gunport lid on the lower decks until 1789 when they were incorporated into every gun port lid on the lower decks.  One of those things not often seen on models.
Allan
Tim
Hi Tim,
Mine had the leading edge angled for a third then the centre portion rounded if that makes sense. Rudder slightly tapers aft but only the lower, wider section. The top section is the same thickness through out. As shown, the rudder does not reach all the way down to the bottom of the keel, believe to try to prevent being unhinged if the ship touched the ground.
sorry for slow reply.
Adrian
Current Build(s):
Completed Builds:
Thanks Adrian @Thunder so very like the example that Craig @iMustBeCrazy showed us.
Tim
Current Builds :
Here is my first attempt at making a pintle.
I had some 0.8mm dia. copper wire which looks about the right size for the pin, amazingly when hammered flat it is also a good match for the straps.
When I have completed it I will black it with Liver of Sulphur as advised by Allen @allanyed
The parts are 'soft' soldered together with some good old lead based solder I have from years ago.
When I have decided on the final shape of the rudder I will remake it to suit the profile.
I am assuming the centre of the hinge should fall in the gap between the rudder and the sternpost?
This is fun.
Tim
Current Builds :
Hi Tim,
A bit late now, but for the future, the forward edge of the completed rudder was not flat.  If it was flat, the rudder could no be turned very much, if at all.   There is a bearding piece on the forward edge of the rudder that was made of elm and had angles of 30 degrees from about 1650 to 1720.   It was changed to 45 degree angles about 1720 to allow a wider turning arc when the rudder was hard over.   There was a bearding piece on the after edge of the stern post with similar angles.  (Peter Goodwin, The Construction and Fitting of the English Man of War, pp 129-30 ISBN 0-87021-016-5)  He also has a chart showing the dimensions.  Also, the rudder tapered, it was not the same thickness at the bottom as at the head.  The taper of the rudder  matches that of the stern post which can be found on the contemporary plans of Speedy 1828 at RMG Collections site.  It appears to taper from about 10 inches thick at the head down to about 6 to 7 inches at the keel.
Allan
Edited by allanyed
2 hours ago, allanyed said:
A bit late now
Never too late Allan
I have reshaped the leading edge of the rudder, not sure if the pintles work that shape?
still work to do on cleaning up and detailing, but it begins to look better thanks to the advice from @allanyed @iMustBeCrazy @druxey @Thunder
Current Builds :
That looks pretty good to me!
One small quibble.
Those pintle pins should not stand proud of the leading edge of the rudder .
Edited by Gregory
― Jimmy Buffett
Thanks Gregory @Gregory I really was not sure about the position. I will adjust the position.
Tim
Current Builds :
Here is the rudder just balanced in place, now I can see how much I need to move the pintle.
these photos do show warts and all, don't they
Tim
Edited by oakheart
Current Builds :
The rudder looks great!   The below is from The Construction and Fitting of the English Man of War, by Goodwin.   I am sure there were a few variations but this gives the idea on their shape.
Allan
