Hi everyone, I started scratch build of a Columbus Santa Maria according to an Anatomy of the ship book by Xavier Pastor. It seamed to me it would not be a too difficult job since I have a book and just need to follow it, but there was equally time spent on thinking of how to build something or deciding in what way to build since plans have decent amount of inaccuracies and lack of details. IMG_20201228_140506.thumb.jpg.afa9f79b2cdab69e61152a8d7037073c.jpgIMG_20201227_173114.thumb.jpg.82146a31d8a33e9451e8bf7b641ea01d.jpg
Gusar,
    Please define 'inaccuracies'.  Since there is no record of the details of the Santa Maria, there is alot of leeway in the building process.
    The build looks good so far.  What other builds have you done?
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Hi Chuck,
I will list some of inaccuracies or mistakes I found. 20231006_132728.thumb.jpg.62bc97aa2673a2712d1e1bbaf067c7d8.jpg
When you compare body plan with sheer and half-breadth plan and measure everything this what you get. This is in milimeters. I took that sheer and half-breadth plan are more accurate.
Screenshot2023-10-06134233.png.4826ac5f81048c787b898f0bc0872504.pngScreenshot2023-10-06134309.png.100719bda6efca139b9f44e20af9f597.png
One ladder not two.
Had to add the this for main yard hoisting.
Cleats are on wrong places, found out later when started putting the shrouds
Absolutely no cleats for fastening all the ropes, also lack of better explanation of how forecastle is constructed.
Screenshot2023-10-06134535.png.63ffb7cf296173fdf43612d77718999e.pngScreenshot2023-10-06134700.png.7da8a0dd10885714971d3650f4f8bcd9.pngTwo different fore stay versionsScreenshot2023-10-06134642.png.6abe9b88d4a39d9aa53eed056aac3d69.png
Spritsail is too large, spritsail on the previous picture is better
This framing is not in an alignment with other plans, so much correction is need if you want to make admiralty model or just to match visible frames with other plans.
There are some other mistakes I can't remember now, for example anchor is too big for the scale so adjustments are needed. Much care is to be taken studying plans before starting the build. I don't have so much experience so i didn't see all of this in advance.
On 10/5/2023 at 7:21 PM, Chuck Seiler said:
Gusar,
I did two Adriatic Trabaccolo, and one fishing boat.
That's  some very nice work, I only wish.
    :cheers:
On the build table :
Pegasus  -Amati-1:64
On hold:
Astrolabe 1812 - Manuta-1:50
I see, the inaccuracies are within the plan itself.
Very true.  It is very frustrating when you have what appears to be a good set of plans, but AFTER you start working on it you find the various parts of the plan are not reconciled with each other.  I guess learning that, and learning what things you need to verify early on are part of the 'gaining experience' process.
Looking good so far.
Edited by Chuck Seiler
mis spelling
Chuck Seiler
Very impressive work. I've tried a couple of models built on a plug and always found difficulty in getting the two halves exactly the same. You seem to have succeeded admirably. And you've done a superb job on the (difficult) rounded stern. Very precise work.
Steven
Steven
Two halves were nothing comparing to rounded stern :) it could have been better, but next time it will be.
Thank you all for kind words here is continuation of the work.
20211220_132524.thumb.jpg.b5b43291ceabf765204d9aa16c81e33e.jpg20211220_132512.thumb.jpg.28d1af02cdf3e6c3edff55d02b61963a.jpg20220102_184027.thumb.jpg.de02e3d5869b877d17a956c41e768373.jpg20220102_184020.thumb.jpg.74fd7401fb46cb0ed3420d668cce4fd9.jpg20220102_184557.thumb.jpg.492ec58c21a922d7a045853da081ea10.jpg20220102_184605.thumb.jpg.329c9bec3d438a56cb2d6d0c071dd0cd.jpg
20220117_114959.thumb.jpg.c059a9de1b8d1bbb955cdff1c5cfb1df.jpg20220117_115002.thumb.jpg.f2883d85a2cc0ef9f59ca7c4d11f3738.jpg20220118_141352.thumb.jpg.2c8cd9d8f48ddefdabe4cb89cc78cb81.jpg20220117_114948.thumb.jpg.8b18833d98d68c77afebec70211cde50.jpg20220117_145029.thumb.jpg.924a3f3048d15447ca826420fed5a9a2.jpg20220117_145231.thumb.jpg.0ba19ef0dd5acce4fd535a17a1eb0f97.jpg20220118_141336.thumb.jpg.9f5d391cb5fe2118f58cbdadd65d800e.jpg20220120_153202.thumb.jpg.c3ab1cdf8dc83671c99de840214cd7b0.jpg20220120_153240.thumb.jpg.f51fb026a0d1fbebb99a23f6c527c052.jpg20220120_153251.thumb.jpg.6d5b928fcc5addb7615b3753289f2f76.jpg20220123_114520.thumb.jpg.dca0d4293b4fdc09752dbcae2d36640d.jpg20220123_114529.thumb.jpg.580b5f02db779f4763d3b1b33c237d56.jpg20220123_114554.thumb.jpg.0ea4311daa91663107e991b63454b883.jpg20220124_131947.thumb.jpg.7249b3ac25374f3a2df5c88048409344.jpg20220124_132003.thumb.jpg.86f29094eda25ce7501301c81202cd62.jpg
Edited by Gusar
I’ve never had much interest in the Columbus ships; probably a result of having seen too many really bad replicas and models.  You, however, have produced a stunning model that in my opinion nicely captures the essence of what a late Fifteenth Century Nao might have looked like.
Your hull construction technique is unique and innovative
Well done!
Roger
Very nice.  What wood are you using for planking and doors, etc?
Chuck Seiler
Well done!
Roger
Hi Roger,
I was really thinking a lot about how to capture this essence as you said. Looking at many contemporary pictures to try decide which colour to go for. The wood I use is pear stained with two colours dark walnut and redish walnut. First I would put redish one and then quickly applied dark one so wood can soak bit of both. That is why colour is not uniform you will see more on later pictures.
Hull construction method I took from russian master Michael Bezverhny.
Today is Columbus day, so ironically, it's a great time to work on your Santa Maria model. I assume you are using the Mataro Nave as a reference? It looks like you took a significant amount of features and replicated them on your model, which is probably a good decision.
Gusar
Just tuned in and I admire your model a lot.   Did the Spanish use belaying pins in the 15th century?  They are shown in your fifth row of photos in post #20.  The British did not use them until well into the 18th century so I am curious about this  as I am studying a 17th century Spanish vessel at this time and cannot find information based on contemporary sources that indicate they were used,
Thanks
Allan
Edited by allanyed
On 11/2/2023 at 1:12 AM, allanyed said:
Gusar
Thanks
Allan
Hi Allan,
I am not sure if Spanish used belaying pins in the 15.ct. In the book there are no pins drawn in Santa Maria plans only in Pinta plans. Also I saw on the SM replica in Palos de frontera there are belaying pins so I put them. I also tried to find out about this question long while ago, I think I found somewhere that the use of pins started in Mediterranean first. Need to check again.  Screenshot2023-11-18215338.png.9b067cae3e1fd5f268848f1138865dc9.pngScreenshot2023-11-18215923.png.ae03a20edac756e41da70c2f843a65ec.png
I have books about Spanish galleons in the 17.century if you need some help with your study I can check them.
