So I took advice from you guys and made a build log, so far I managed to build a stand because I still dont have the right tools for the ship, and I really dont want to mess it up. Anyways I dont have a waterline marker yet, so should I start building the keel or plank it first?
Edited by AmateurModelBuilder
Nice job on the stand, I'm looking forward to following along!
Do the instructions say to mark the waterline so early on in the build because you'll be using it as a guide to attach a part? As for a waterline marker, if you search the site for "waterline" you'll see a lot of methods that people have set up waterline markers that may inspire you.
I ve read the instrunctions, and they dont use the waterline as a guide, but the first page tells me to paint the part below the waterline with varnish.
Just started building the keel today, Ive followed the instructions and cut pieces to the picture, and when I assembled the keel there was this rather large hole on the stern of the ship. I didnt glue the together keel, and I need sugestions on how to fill that hole
Got to say, they don't give the best of instructions.
I have the Cutty Sark under way and had to use a lot of filler and shaping to get the lines looking anywhere near right.
(Stopped for now as life got in the way but will continue soon I hope.)
Use the photo of the ship on the box front to see what you may need to do.
Looks like a lot of filling and shaping to get the lines in the photo.
Bob
Current build Cutty Sark, Mini Mamoli
Finished  King of the Mississippi
No trees were harmed by this message, but an awful lot of electrons were put out.
What Mamoli is looking for you to do is trace out a pattern like I have made in red, then use strip wood pieced together like I have indicated in blue, where you would then trace the pattern to give you a shape to fit over the bow and stern without any gaps.
You may want to use  more pieces than they have shown in the instructions in order to easier make a curve.
If this is still a problem for you and I may be able to put together a little demo with some wood.
― Jimmy Buffett
On Hold:    Rattlesnake
Good luck with the keel! Is there a reason you made a new build log, though?
Hello, Gregory was exactly right.  Below is a photo of my mini-Mamoli Nina.   The keel parts are glued into the pre-drilled groove all the way along the keel.  Since the keel will be painted below the waterline, it doesn't really matter what pattern of pieces you cobble together down there as long as they are all snug in the groove, and against each other.  It also helps to install pieces which stick out too far as well, so the entire keel/stem can be sanded down as one unit after the glue dries.
Alan
Its been a while since I posted but, I managed to build and sand the keel and plank the deck. As for those holes in the keel I filled them with scrap wood and just sanded it to fit in the groove, it may not look the best but couple coats of primer and paint will hide it. Now im wondering: do I varnish the deck first, and varnish should I use, because there are a lot of components that will be glued on the deck or do I continue building the ship and varnish the deck later?
Deck and the sides are finally finished, I primed the hull and glued on all the strips that went on the bulwarks. So the first page of the instructions is finished, and now comes probably the most involved part of the kit, adding structures to the deck.
The entire deck is finished, barrels are tied down, I glued down the cabin and storage openings, I painted the inside of bulwarks, and added the anchor. The paint on the hull is a bit messy because of the masking tape I used, but I think it looks alright, this is my first kit after all. Right now all its left is to make a rudder, the mast and connect the sail. Also I need some sugestions on which wood coating should I use since the wood for the whole sail rig is really light, and if I leave it like that its going to look ugly.
11 hours ago, SiriusVoyager said:
That is a nice looking little model.  Good detail on the deck.  As far as the wood covering, is your goal to darken the mast?
Yes, the wood its made of is really light, and if I place it like that it will ruin the model, so I need to darken it.
I would say either buy a wood stain that you like or you can use thinned acrylic paint as a poor man’s stain.  If you have burnt umber as a color that is a good place to start. You can mix colors as needed and find recipes online for different color mixtures. Once you get the color you like add equal parts water (or acrylic paint thinner depending on the paint) to the paint then treat it like any other stain. Apply it with a brush, let sit for 5-20 seconds, then wipe off with a paper towel. The longer you let it sit, the darker it will be.  Make sure to test it on scrap first to ensure that you like how it looks.
  - Eric
Current build:
  • 5 months later...
So I finally finished it. I actually finished it this summer, but I forgot to publish it,  im happy with how the model turned out. I used brown acrylic paint to darken the masts, I just diluted it with some water. But now I have a dillema, should I build a solid hull ship again or a plank on plank one. I really like Bounty launch from Occre because its advertised for beginners, its in my budget and its a large model for just 70€, I want to start out on this one because in the future I really want to build Coca from Amati and Llaut and Sloup from Correl.
Nice work, very well done!
If you haven't already looked, you might want to check out existing build logs--I know there are some for the Bounty Launch and the Sloup, at least. They might give you an idea of particular challenges of each.
