  • 10 months later...
Hey Dave -
Thanks for looking in. The build is going slow. Life and stuff always seem to get in the way.
The heat index today should top at 112 here on the MS gulf coast so I think I'll stay in and work on upper shrouds.
- Kenneth
Yikes! Way to hot for me! Understand about life and stuff, happens to us all. 😁 Glad a fellow Rattlesnake builder is still around. 👍😀 STAY COOL!
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Upper shrouds. Man, these things are small.
I tried to add the metal hook and all but decided to make this way. Trying to solve that issue is another thing that put me so far behind.
Comments welcome - Kenneth
😳😁 Are the deadeyes loose enough to turn for alignment when it’s time to install? Actually, looks like you got them pretty aligned. 👍
Dave
I've been working on backstays. The plans call to use thimbles. The way I made them was to bore a hole into the end of a dowel then slice them off. When I used what I considered the appropriate size, they split. The instruction book said it's possible to hollow out a deadeye, but they split. What worked for me was to go up very little in size on the dowel and bore the smallest hole possible that would accept the rigging line. It took a while to sand them under magnification. They look a little oversized and a touch out of scale compared to the plans, but here they are:
391.jpg.a956b206c55aee0b72c308dd7d9a9fcd.jpg 393.jpg.8b5c5cc8fd23fd412d71dfe70565be34.jpg 395.jpg.6104c2154c24fc8c5fc3adde77e85821.jpg
This is how the plan looks:20220920_200937.jpg.0309a8796f5b0566f55e2c6786097b49.jpg
This is how my model looks:398.jpg.4d94eaf3cc7a4b2b4696d9af32c4fcc4.jpg
I have a bunch more thimbles to make and a few backstays to finish.
You might consider using brass tubing to make tiny thimbles. Obviously, the hole is already there. All you have to do is slice them off the tubing and paint. If you need to carve a groove on the outside perimeter of the thimble, place the ring on a tapered mandrel which will hold the ring tight while you file the groove.  Wood becomes very weak at that scale as you have found out, whereas the metal thimbles remain strong and won't break. At this scale it will be impossible for the viewer to know what material they are are made of. It's a model, not a reproduction,
Jon
Edited by JSGerson
Jon -
Thanks for the suggestion. I tried it and it worked. I used the rotary tool to cut small slices then painted and rigged them up.
I actually lowered the tool and tube into a cardboard box while wearing safety glasses to keep the micro-sized disks from flying away - or putting an eye out.
403.jpg.4f841f04a200b1516ec52c9d8ab7b769.jpg 404.jpg.0a43dc0d5b5ccce6660ea1622d1448fe.jpg
This is why I like this group. Excellent tips from very talented people with no criticism, just encouragement.
Ratlines are next.
Glad to be of help.
Working on upper ratlines.
In the photo above it seems I'm off a little from my lines, but when I pull the paper up close things are right-on.
Slow going but once I can sit for a while and get in a rhythm, it really moves along.
One thing that has helped is that I moved the model from my basement with no natural light to my sunroom with northern exposure. Here in the Gulf South I get plenty of indirect sunlight year-round.
I can see better and natural light improves my mood to tackle these tedious or what I preserve as difficult items.
I'll march on and complete the ratlines.
Go Man Go! (But not too fast) 😆 Looking good Ken! 👍😀
Dave
Looking good Ken. The lines look like they could use just a bit more tightening.
Jim
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
Milestone!!
All ratlines completed!
I've never worked on shrouds and ratlines like this before, so I really feel accomplished. It seems the more I did, the easier it got and better they appeared:
Now on to a few details and then gaff, boom, and spars. The light at the end of the tunnel is getting brighter.
Thanks Everyone for the Likes and comments.
I built and installed the 3 netting guard rails. I cut the heads off long straight pins and cut them to length. The netting is what my Admiral suggested from the craft store.20221222_101442.thumb.jpg.8a117482b68d71c8ee8b3116cf5197cc.jpg
These photos show how my ratlines improved from upper to lower.
I also have the gaff, boom, and spars cut to length from appropriately sized dowels.
I'll be working on those next.
Merry Christmas and a Happy New Year to All!
Comments welcome
- Kenneth
Looking good Ken! How did you get your plans with the red in them? 🙏🎄
Dave
Thanks, all for the likes.
Dave -
The Model Shipways kit I have came with 4 pages on 2 sheets of plans (front and back). This is the only page for rigging. They put the standing rigging in black and the running rigging in red.
This combination makes the one page really jumbled. Thank goodness others have built and logged this model before me and I can see how it's supposed to be.
And again, everyone have a great holiday season.
Work accomplished since last post:
Gaff and boom finished and rigged
I bought these very small beads for parrels. I emptied the container into a small bowl to take the photo with the label visible.
Mistake. I spent half the afternoon chasing the things across the table and floor trying to return them. They have no weight.
Gaff and boom installed:
The beads worked great, worth the trouble.
Spars are next, one mast at a time
Comments welcome
- Kenneth
Thanks, Rollingreen -
I've been trying to get these latest two spars installed, but every time I look at the plans it all seems to get more and more jumbled.
I find that if I read, then re-read, then study a little more, look up other builder's photos I almost know what to do.
Like I mentioned earlier, all rigging is on one page, so a little clarity is sacrificed. I feel like once I get the mizzen mast spars completed, the other two will fall right in.
I finally got the 2 mizzen spars on the model, and I hope I did it right:
I have all the other spars shaped and painted and ready to rig, but the plans have no place for the main lower yard lifts to attach. The only reference is this drawing at the top of the plans:
It says 'Lifts lead thro sheave in covel (cavel?) abreast mast and belays on its cleat'. What? I cannot find a meaning for covel or cavel.
The plans show the mizzen and fore, but not the main unless I'm missing something. If he means kevel, then it's not on the plans. But adding one would be easy enough.
Help and comments welcome - Kenneth
