4 minutes ago, ECK said:
Thanks. I use Vallejo flat red followed by a coat of satin poly. It is the color Chris uses in his models.
I used the same Red colour on my Indy and I will also use it on my Adder build. It looks really nice.
Glenn (UK)
Well hull basically done. Hammock netting will go in at the very end as I always bend/break them while I am doing the rigging.
 I also put some tackle on the carronades and fully rigged the 24 pounders (a real pain , fortunately only 2. Use 2.5 mm double and 2 mm single blocks).
IMG_8685.thumb.jpeg.c2127d52554098e7c9d9b02b0338b8cf.jpegIMG_8686.thumb.jpeg.881c439cfc815b332b84a09359851833.jpegIMG_8688.thumb.jpeg.1dd876e4e4b3af1be019b8c171701101.jpegIMG_8689.thumb.jpeg.e446c8be7ee027181ec8eef563ce6a06.jpegIMG_8690.thumb.jpeg.2b794bf755d63a2945440b3c2579abf3.jpegIMG_8691.thumb.jpeg.d6938469985c0cbf731db3baf277d91b.jpegIMG_8692.thumb.jpeg.3dfc9dde65917d0235b10aac825a04d8.jpegIMG_8696.thumb.jpeg.5d99967c72967beebd76e6c987ffdb22.jpegIMG_8695.thumb.jpeg.6ea7555fd55c7d8b39fdfadaccbbaea0.jpegIMG_8693.thumb.jpeg.43cf98542d3592cbd2ebd6d676243019.jpegIMG_8687.thumb.jpeg.87633a34bad84e800d86da2a62168f1e.jpegIMG_8698.thumb.jpeg.7e64ad316ea119f84bc10ca2ec2501bf.jpegIMG_8697.thumb.jpeg.eb55c1ccb647fe6af147275e1a07e4aa.jpegIMG_8699.thumb.jpeg.72ac160c0636bc94a3f5db7e084bb09c.jpeg
Here is Adder's smasher next to the maindeck ones on Indy
And 24 pounder here compared to Sherbournes's main guns
Very smart build, making me look forward to starting mine!  Those 24 pounders do dwarf Sherbourne’s guns!
Andrew
Completed (Kits):-
Started on lower masts.
First Dowel cut to length:
Then taped off lower area to be carved
Placed in vice and long side filed down 1 mm
IMG_8711.thumb.jpeg.e18860844a58fc8e2cbb7620130cd4c7.jpegIMG_8712.thumb.jpeg.0296de11644d7685ad77058225a46059.jpeg
Next marked off upper area, rotated 90 degrees and filled upper area ( with one side flat keeps things straight in vice)
IMG_8713.thumb.jpeg.28b6ac302b40e4b3d047d66ab08fb1c5.jpegIMG_8714.thumb.jpeg.98236a0416f8f0969c3b8e0053ec43ed.jpeg
Kept rotating to finish then trimmed tip for cap
IMG_8715.thumb.jpeg.770457a82a5bd4deb2b6864e22c4befc.jpegIMG_8716.thumb.jpeg.a3c07ed0270ebffe6d7d46ec1902e17f.jpegIMG_8717.thumb.jpeg.17fa3dd9644b5817d8255911a2bf9191.jpegIMG_8719.thumb.jpeg.c89dcc4ee2f7fdc4637799c2251aa57b.jpegIMG_8720.thumb.jpeg.61ace54de6c3bd647729353c5c0fcc17.jpeg
Thanks. My 15th build so learned a few tricks especially once I joined the form and saw the great wokr/tips from others.  You may noticed that I splurged and bought pear blocks for a more realistic look. Since I started building with real looking blocks, I find the final product just looks better although not obvious until you get closer to the model.
Have pinned the yards to the mast and done some of the jeers and tyes. Will remove bowsprit until after shrouds done as just gets in the way.I do this part now when access is much easier than after when the shrouds are in place
IMG_8767.thumb.jpeg.9850f09c48f5db33a2f494e454cf8c9a.jpegIMG_8768.thumb.jpeg.eab83c47509a50fa6c89717514bc8176.jpegIMG_8769.thumb.jpeg.612b9fe9b03efe5c9cec758cd6d16c67.jpegIMG_8770.thumb.jpeg.36addade0da002f145fae66e5941f1a5.jpegIMG_8772.thumb.jpeg.89a2705eeae01d89ace9caaa73ed4e2b.jpegIMG_8771.thumb.jpeg.43b59822c48e85a57701562797b3e3b8.jpeg
I use vallejo flat red, what Chris recommends on his ships. I soak and shape the inner forward bulkheads and let dry overnight. I then spray paint them and what ever else I can prior to installation. I find spraying leaves more of the detailed engraving visible compared to a thicker brush coating. Once in place I then paint a light layer of matt ploy.
Recommendations on a descent quality air brush for modeling? Is the polyurethane also sprayed on (or does "paint a light layer" mean use a paintbrush)? I had also seen some posts where someone recommended that the wood be treated before painting. (Complete novice here.)
What do you do with the exposed wood (say on the hull or the deck or other parts that aren't painted)? Do you use a light stain (wouldn't a stain be rubbed on, not sprayed)? Do you use polyurethane on them? (Again, sorry, complete novice.)
Edited by palmerit
I brush on the poly especially over the bare wood It helps as if you accidentally get some paint on the bare area easier to scrape off if the poly is underneath. I also got this combo airbrush and venthood set. For most of the pieces the hood works well.For the white of the hull I use a lot of tape and mat combo spray can of  primer and paint. I got the airbrush on amazon
Well, another completed. Fun project with challenge being the very rounded prow.
IMG_8852.thumb.jpeg.7cc3b5b02561a6aa61be7cbc4f4fbc8d.jpegIMG_8863.thumb.jpeg.3d4a453c796588f67cfb37f8fee29bc6.jpegIMG_8862.thumb.jpeg.1512ba7c2ab92d0e435cf58fef406093.jpegIMG_8861.thumb.jpeg.dcac1abde535fe78612dd603d7e9fdb4.jpegIMG_8860.thumb.jpeg.3bfbb6c92fd14e37e9a7ac32760f4b68.jpegIMG_8859.thumb.jpeg.2fb06b4c91561649de2656d49ed604a8.jpegIMG_8858.thumb.jpeg.3096f68eaf5451042f79031f217ad01c.jpegIMG_8857.thumb.jpeg.7471ff5f9b415a54f4966bf5f25cc5fd.jpegIMG_8856.thumb.jpeg.132e601cc9b13fededeb88e7dfcf6548.jpegIMG_8855.thumb.jpeg.ed49638eb48fb3fa6b2a0b1ae8214938.jpegIMG_8854.thumb.jpeg.91a0825fb754f86cafed8a7b7cf63560.jpegIMG_8853.thumb.jpeg.fc34ab0f0f360afdd18254e39afeb6ec.jpegIMG_8864.thumb.jpeg.4e5522762d9145b02df11eea67173e78.jpegIMG_8865.thumb.jpeg.e21bdd9c6b7327d240bf81f9ac4b67c0.jpegIMG_8866.thumb.jpeg.17a2a9bc83952543d8035b9e80dfab99.jpegIMG_8867.thumb.jpeg.365d102511e0244e457bec30310026bf.jpeg
Note the lowered center boards
IMG_8869.thumb.jpeg.e7ce4b33c66f268e6d912ad557e5c925.jpegIMG_8874.thumb.jpeg.ed0bbcbd5a67d0d9ed2a19a802e71092.jpegIMG_8872.thumb.jpeg.0afb6ed1a3b3e7b01aac82a8b3551e5f.jpeg
Now for the next project, unfortunately I think I have done all of Vanguard's projects that are not similar to each other. I like doing larger vessels. So until Chris can get the 1:64 Victory somehow, I will do one of his older projects from Amati. I am interested in doing a mortar ship ever since I read about their use in my youth in the C.S Forrester Hornblower series book The Commodore where Hornblower uses a mortar ship in the Baltic.
Wow.  Another fantastic model.  I am amazed at the quality of your builds given the speed at which you build them.  You accomplish in two months what would take me two years with incredible results.
Well done. She looks super. I told you that you’d overtake me. I’m not far behind, last few rigging lines to add and then just the anchors!
Dan
Current Build: Sherbourne (Vanguard Models, 1:64)
Previous Builds (All Vanguard Models 1:64):
Fishing Boats: Fifie, Nisha, ZuluSaucy JackErycinaRanger
Warships (and Yacht): HMS AlertGrecianHM Gun Brig Adder, Duchess of Kingston Yacht
Waiting to be Built: Speedy (Vanguard Models, 1:64)
19 hours ago, Craigie65 said:
Lovely, well done!
And on to the next, you need to let everyone into your secret for finding so much shipyard time!
The secret is an empty nest but no grand kids yet !
Watch out for those anchors, they are a bit delicate. It is the only issue I find with the laser printed ones.
Thanks I will do!
Dan
