Hello everyone, it's time for yet another build log of the Model Shipways Grand Banks Dory!
This is my first ever model boat/ship, and I'm coming at this with precisely zero woodworking experience, so hopefully I am the target audience for this kit. My long-term goal is to work my way up to Vanguard Models' Speedy, so to that end I got the Model Shipways 3 kit learning set to get me on the road to a more complex ship.
To any experience builders who may read this build log - I welcome any feedback at all! If you spot that I'm doing something stupid that I seem oblivious of don't feel bad about letting me know - I'm here to learn a skill that's totally new to me and any feedback (including critical feedback) would be very helpful :).
To start with, I took an inventory of all of the listed parts. Since this was the 3 kit set, this also came with tools and paints. All of the listed wood parts were there including an extra strip of 1/8" basswood. The tool set was missing the sandpaper and the chisel blades, but it did come with some pliers, clippers, a pair of (not very good) files, and a pin vice drill and bits, none of which were listed which was nice.
It was a bit shocking feeling just how thin the plank sheets are. It's one thing to read a number like 1/32" and another entirely to feel it in your hands. I'm afraid it'll snap if I look at it wrong!
Gluing the bottom together was pretty straightforward. Oddly the two side pieces didn't have a full set of laser markings and the ones that are there look like they were done by hand, but this didn't interfere with the assembly.
The bottom cleats were also straightforward. Since the kit didn't come with sandpaper I had to make due with what I had lying around. The instructions suggest to use 150 and 220 grit sandpaper. I only had 120 (which seemed too course) and 220, so I stuck with 220 for everything. At first I was worried this would only be good for finishing and not for removing material, but after using it to shorten the cleats to the proper length and bevel them I wonder what you would even want the 150 for. This wood is so soft that the 220 made quick work of shortening the cleats and I found it was easy to accidentally over-bevel with even just a couple of back-and-forths. For the two cleats on the ends where the angle of the bottom's side is most extreme I figured I would try to match that angle as a way to practice beveling to an intentional angle.
Attaching the stem and transom assembly was a bit trickier. It was hard to figure out a good way to make sure they were truly even with the center line of the boat. I did my best using the straight lines on my cutting mat as a guide and to my eye they look correct, but I do slightly worry that since I didn't use any kind of jig to ensure straightness, any imperceptible deviations may be magnified later in the build.
With the transom assembly, though, I worry I may have already made a mistake. I lined up the stern knee with the marks on the boat's bottom just as I did with the transom, but doing so resulted in a bit of an overhang where the knee/transom stick out a bit past the point of the bottom. Looking ahead in the instructions I see that a photo shows their stern knee glued very close to the rearmost bottom cleat leaving no overhang, so I am considering breaking out the isopropyl and redoing this step. But on the other hand, a quick survey of build logs shows at least a couple that appear to have done the same thing I did with no apparent problem. Any thoughts on if it's worth trying to remove this glue and redo this?
At the moment the bottom is sitting in the bender. Later today I'll start working on the frames while I decide whether or not I want to redo the transom.
Edited by Galkar
Updating title to indicate finished status
Current build:
Norwegian Sailing Pram
Completed Builds:
Grand Banks Dory
This was my first model kit and brings back some good memories.
I think I redid my knees several times until I was happy with them. It's so nice being able to re-do a glued joint, and I take advantage of it regularly 🙂
i had a lot of fun with that model too.
In progress
Lady Eleanor by JIm M - Vanguard Models - 1:64
On hold
Norwegian Sailing Pram - Model Shipways
18th Century Merchant half hull planking - NRG
On the shelf
Muscongus Bay Lobster Smack - Model Shipways
Peterborough Canoe  - Midwest Products/Model Shipways
Batelina - MarisStella
Junco China - Disarmodel
Completed
Model Shipways Lowell Grand Banks
Grand Bank Dory - Midwest Products/Model Shipways
Having the transom too far aft may come back to bite you. The planks may fall short at either bow or stern. I'd go for the isopropanol for a do-over. It won't hurt a bit!
Kudos to you for starting out with the 3-kit shipwright's set.  I think this is one of the best ways to begin building wooden ship models.  You will always remember your first wooden model.  Don't worry about the mis-glued stem or stern.  If you are using PVA (Elmer's white glue or Titebond yellow glue) which I hope you are, mis-glued parts can be un-glued using isopropyl alcohol.  Take your time and use a brush and eventually they will come free.
There is nothing on a wooden ship model (except perhaps catching on fire) that cannot be un-done or a new part made from scrap from the kit.  Consider making some sanding sticks using different grits of sandpaper.  Always use a backing of some sort, I use and re-use popsicle sticks and the free paint stirring sticks from the local home improvement store.
Check out the many excellent build logs on MSW.  Although the instructions are well done IMHO, there are a few areas that are unclear.  See how other modelers have dealt with these issues when they arise.
Most importantly, enjoy the journey and don't be afraid to make this model your own.  There is no rule that says that your model has to be ochre and green.
I'd like to follow your build if you don't mind.
Wawona59
John
Current Project:
Wawona Lumber Schooner
Yeah I think I will. Even if it ends up not being necessary here it's probably good practice to try this regluing process now when it should be fairly easy.
Thank you for the encouragement! And of course, feel free to follow. I welcome any feedback at all!
Current build:
Completed Builds:
Grand Banks Dory
Nice start, I'm looking forward to following along on this build!
I did end up detaching and re-gluing the stern knee from the bottom. This ended up being a much more difficult process than I expected. I thought the 99% IPA would make fairly quick work of the glue, but after about 10 minutes of constantly flooding the join with IPA it was still completely solid. The only way I was eventually able to get it off was to gradually worry an xacto knife blade in between the two pieces and very slowly cut through the glue. This worked well enough here because there was easy lateral access to the seam between the two pieces, but I have no idea how I would do this in the future on a join where I don't have that kind of access.
Next big step was to assemble all of the frames. I wanted to use the included plans as a template as suggested to make sure I had the two halves of each frame properly lined up, but unfortunately the plans were not quite printed to scale. Luckily the instructions are available online so I was able to print them out scaled up slightly. In another build log I saw a suggestion to tape down the cross-piece, and this helped a lot.
Attaching the frames to the build board was no problem, they all fit snugly with no need for sanding or shims.
When it came time to attach the transom holder, though, it was way too far back to be able to properly hold it. (Ironically if I had left the transom assembly the way I had originally glued it I think it would have worked.) If I installed the holder as suggested the transom would have been halfway up the diagonal slot and way above and not even close to the two side blocks. To fix this I sanded down the bottom front of the holder piece, put a shim behind it to force it forward, and glued the two side blocks much further up. I didn't take a photo before my modifications to show how it was off, but here is how it looks afterwards:
Next step is to glue the bottom to the frames. I'm not really sure how to ensure that I have it properly centered side-to-side on the frames. It's a bit tricky to eyeball because of the asymmetry on the frames. I'll check through some of the other logs to see if I can find anything, or just eyeball it if I can't.
Edited by Galkar
added bit of info I initially forgot
Current build:
Completed Builds:
Grand Banks Dory
In my experience the isopropyl doesn't completely dissolve the glue, but it does soften it from rock-hard to a thick sticky paste and then I can carefully pry the pieces apart. Sometimes the hard part is getting the alcohol to reach the glue.
I had this same problem with the transom knee alignment.  It seemed to workout ok with my model, but I think you will be glad that you moved it.  Great start with your Dory.
  - Eric
I've got the first garboard plank glued and the second one clamped for bending at the moment, but looking ahead I'm a bit confused about how the beveling should for the broad and sheer planks. The instructions mention these needing a bevel on their inner side, but only mention giving them the rolling bevel at the ends, and not the same full bevel along the whole length of the inner side. Is this correct? If the only bevel on the inner side is done at the fore and aft ends, then for most of the length of the boat the outer bevel of the plank beneath would be overlapped by a flat, unbeveled plank. It seems like adding the half-width bevel along the full length of the inner side would make for a smoother join there (while still leaving a visible overlap).
Anyone who has built this boat, do you remember how this part went for you? I haven't yet found any mention of this in the 5 or 6 build logs I've looked through today.
Current build:
Completed Builds:
Grand Banks Dory
On the inner side, the lower edge of the plank should only be rolling beveled at the bow and stern.  It should be full thickness for the bulk of its length.  This allows the planks to lie flush at the bow and stern.  The overlap for most of the length should be full thickness. This gives the clinker appearance and was probably important for holding fasteners when building full sized boats.
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
Doing these bevels at the ends means that the two planks are flush (without a gap) at the bow and stern ends - if they were just overlapping and full thickness, there would be a small gap (and being a boat, you wouldn't want that gap). Along the length of the boat, yeah they overlap (clinker appearance) but there is no gap between them. It's only at the end (where they run up to the bow and stern pieces) that there would be a gap if they were left unbeveled. If you next do the Norwegian Pram, which I'm working on now, you do a rabbet cut at either end of the plank for a similar reason - not doing so would leave a small gap. I don't think I fully understood why I was doing the bevel when I built the Dory. I didn't fully understand the reason for the rabbet either when building the Pram, but then as I thought about it and played with the pieces a bit, it made sense. And then when I did the rabbet on one plank and compared it to the one without (holding them to the stern end) I could see that the one with the rabbet fit snug without much gap and the one without the rabbet had a gap. I wonder if they just had a rolling bevel on the Dory because it is a little bit more challenging to make a rabbet, so they included that in the second model, the Pram.
Edited by palmerit
This project hasn't been abandoned, I've just been away from it for a bit due to some travel and holiday stuff. But I'm back now with an update!
I've finished planking the boat and have removed it from the frame. I'm mostly happy with how that went. There were some struggles and a couple of mistakes, but nothing catastrophic. I appreciate the suggestions in the previous two posts, although by that time I had already added the first broad plank and decided to bevel the full length of the inner side. I knew that was probably not the technically correct thing to do but I figured worst case scenario it wouldn't really cause any issue and would give me some more beveling practice, and in the end I do think it may have helped a bit.
The first mistake I made was that I accidentally snapped the corner off of one of the garboards while doing a little bit of sanding. Once I get some wood filler this should be easy to fix, but I was still pretty annoyed at myself. Good lesson about carelessness!
The two garboards went on pretty easily, but when it came to the broad and sheer planks those were much trickier. I don't know if I somehow attached the frame to the build board poorly or something, but when it came time to bend and then glue the broad and sheer planks, it was very hard to get them properly aligned. I could get 90% of it lined up with the previous plank just fine, but always the last segment towards the front would deviate significantly almost as if there wasn't enough of a pre-cut curve in the piece. Some aggressive handling and rubber banding/clamping during the bending stage did help with this a bit, but still there's a noticeable gap of 1-2mm between the etched beveling mark and the edge of the next plank in some places.
Another issue I had was that getting the broad and sheer planks to make good contact with the actual frame for gluing was a bit difficult in some places as the planks tended to only want to touch at the edge farthest from where they overlapped the previous plank. This wasn't too hard to solve by pressing hard on the planks after gluing, but it did mean that I had to spend a decent amount of time holding the planks with my fingers since in a couple of places I couldn't get the rubber bands to hold tightly enough. This is exactly what I was worried about and wanted to pre-address with the full-length inner bevel, and I imagine this problem would have only been worse if I hadn't done that. Fortunately this doesn't seem to have interfered with the overlapping "clinker" appearance of the planks. On the topic of beveling, though, I had mixed success with the rolling bevel producing a flush meeting at the stem and transom, so the boat looks a bit rough there.
Nevertheless, the planks are all glued and the boat is removed from the build board. There's still some sanding/filling and general cleanup that needs to be done before moving on to the details, but it's very satisfying to see the basic structure of the boat completed. One other piece of trouble I had which can be easily seen in the below photos is that I found it very hard to clean up errant glue when gluing the planks. Partly this was just because it always felt like a race against time getting the rubber bands on and everything clamped after the glue was applied but before it began to set and often by the time I was satisfied that everything was secure, the glue was already to a point where it didn't respond well to a wet brush. But even if that hadn't been an issue, the other problem was that once you put the second of a pair of planks on it becomes very difficult to even look between the build board and the attached planks to spot any errant glue inside the boat, let alone get at it with a brush. I'm not really sure how I could have done that better, but I'm guessing it shouldn't be too hard to clean up after the fact.
Pleased with the alignment after the garboard and broad planks:
Although you can see there's also a bit of a gap where the starboard garboard meets the transom, so that will also require some wood filler.
Clamping the final sheer plank:
The boat after being removed from the build board but before really cleaning it up:
I'm excited to be back to work on this project!
Current build:
Completed Builds:
Grand Banks Dory
Since the model will be painted, I would glue the piece back on that broke off or glue a piece of scrap wood on the edge.  Once the glue is thoroughly dry, you can carefully sand it to match the unbroken side.  This is what I like about working with wood.
Ryland
               - Nautical Research Guild
FYI, you may find it helpful to remove the laser burn before assembling, especially on parts that will be painted. It's more difficult to paint over the laser burn and get color consistency.
It's finished! (Mostly.) I actually tried to write an update before it was completed but couldn't seem to upload any images to the forum at that time, so this will be all the rest of the log together. I also had a couple of marathon work sessions at the end and got in the zone enough that I forgot to take many incremental pictures, so I won't have the best illustrative photos here.
After my last post, I was able to install the side cleats, seat risers, side bands, and gunwales without too much trouble. The first significant issue I ran into was that the breast hook supplied with the kit was noticeably significantly smaller than the one in the photos included in the instructions, to the point where it didn't even come close to filling the gap between the gunwales:
Fortunately some wood filler and some sanding seemed to do the trick:
I also noticed around this time that my stem does not rise as high out of the front of the boat as on other boats I've seen in the instructions and in other build logs. I have no idea why this is. I didn't sand it down significantly, and I thought I did a pretty good job of seating the planks where they should at the stem. Maybe this is an artifact of my having attached the side bands too high at the bow, as that seems to have eaten up most of what little protrusion there was. Oh well, it won't cause any problems for the structure of this model.
For the gunwales and side bands, I think I may not have properly understood how they were meant to sit all in relation to the sheer plank. I thought I did a good job sanding them all level across the width of the boat as checked by a set square, but I ended up having a bit of trouble later on when attaching the cap rails.
Before moving on to glue those, though, it was time to paint the boat which turned out to be the worst part of the process yet. I started by priming with a rattle can grey primer. I thought I might be able to save some time by painting the boat using my airbrush, but this turned out to be a bit of a nightmare. The paint supplied with the kit instantly clogged my airbrush worse than I've ever experienced, and did so again after a thorough clean and thinning it down even more. I was able to get it to spray on my third try, but only by thinning it down so much that it seemed to be just getting the boat wet just as much as it was applying any meaningful color (and it still eventually clogged the brush). I suppose I shouldn't be terribly surprised that the included paints aren't particularly high quality. Maybe next time I would be better off trying to color match using my existing paint collection.
Coming out of the attempt at airbrushing I had a grey boat with some patchy yellow ochre applied:
After this I switched to using a brush which, while not frustrating like the airbrush, was very tedious. I had to apply 3 or 4 coats to get something like an even application, and even still I can see a bit of patchiness if I look. I did also try to do a bit of sanding as the grain was very noticeably raised, but I gave that up pretty quickly when I realized I just didn't have a good way of sanding the rough, highly visible but hard to reach nooks inside the boat such as between the frames and the bottom cleats. This is something I would love to hear some advice on if anyone has any. This is also just generally an area where I clearly need to develop some more patience, but I really wanted to get back to the actual building.
Eventually though it was all painted:
Next step was to attach the cap rails. This didn't go super great as the way I had aligned the gunwale/sheer plank/side bands meant that the cap rails had a bit of a twist in the first 1.5 inches or so, as well as a gap above the gunwale for roughly that length. It didn't seem hugely noticeable though and addressing it would have required some pretty aggressive sanding down at the front of the boat, so I left it as is.
Also this step made me very glad that I switched from the yellow wood glue that came with the kit to plain Elmer's white glue. I had mentioned very early in this log that I had had quite a lot of trouble using alcohol to remove a glued piece and this happened again while trying to use alcohol to soften and clean up some excess glue that ended up on the inside of the planks in preparation for painting. I kept those spots flooded with alcohol for ages and it made almost no difference in softening it and eventually I had to use a chisel knife to just shave it away while still almost rock hard. After this I decided to not use that again and switch to white glue, and I'm glad I did.
While gluing the front of the second cap rail, I clamped it manually with my fingers but let it go too soon and it popped up, leaving some columns of dried glue attaching it to the hull:
It would have been awful to try to release this to try again if I had wood glue and I'm sure I would have broken the cap rail in the process. With the white glue though it was no problem and I was easily able to get it cleaned up and glued down again.
At this point I was very excited as, even though it wasn't finished yet, it pretty much looked like a completed boat if you squint. I added the thwarts even though they still needed to be properly fitted:
There's a bit of unevenness in the alignment of the cap rails as I had some trouble clamping them along the length in a way that didn't pull them either inwards or outwards, but I'm still pretty happy with it.
At this point, I still needed to fill the gap above the breast hook, touch of the cap rail paint, fit the thwarts, shape the oars, round cut and attach the thole pins, and attach the beckets. This is where I completely forgot to take any more pictures, so unfortunately it will just be descriptions from here.
Filling the gap where the two cap rails met was easy enough to do with some filler and sanding, after which it all painted up very nicely.
Fitting the thwarts was also straightforward, just needed to sand a couple of them down a bit.
Shaping the oars though was not fun at all and made me pine for the better days of painting. Maybe I should have followed one of the suggestions from the instructions and tried starting with whittling the oar blades, but I have no confidence in my whittling abilities so elected to do it all with sanding. This was extremely tedious and made my arm a bit sore with all the back and forth. And unlike painting, it wasn't something I could do while also watching some TV or something since I had to be constantly paying attention to make sure I kept things symmetrical and didn't over-sand them. I'm very pleased with how they turned out but it was, in the end, the worst part of the experience of building this boat. Rounding the length of the oars was much more enjoyable. I did have some trouble getting them to have a properly circular cross-section and each one is a bit more ellipsoidal, but I doubt anyone would notice unless they picked one up to examine it.
The thole pins were a mixed bag of success. For the first 2/3 of the length of the wood strip I did a fantastic job if I do say so myself of getting a nice cylindrical round finish. After that though I completely fell apart for some reason and just could not for the life of me sand it evenly. I'm very glad that it came with more length than was needed though as in the end I was able to mostly piece together a decent set of pins.
The last item to truly finish this kit is the beckets. I tried to install these, but the provided scale rope is just too large for the holes in the transom/sheer plank, and none of the drill bits for my pin vise drill are large enough to properly widen the hole. Maybe I'll try using the smallest bit from my power drill. On the other hand, some of the thread for rigging included with the Norwegian Sailing Pram kit seems like it may be a good size so I'm thinking I may see if there's any leftover after I'm finished with that kit that I could use. In either case, while I decide how to handle that, I'm considering this kit "finished".
I had a great time working on this kit. Clearly I need to develop some more patience when it comes to painting and shaping oars, but otherwise it was a very satisfying experience building this boat. There are certainly some aspects of I that I see could have been done better, but I don't think there are any major mistakes so overall I'm quite happy with how it turned out. Next up is the Norwegian Sailing Pram, and I'm very excited to build my first kit with a sail and rigging!
Current build:
Completed Builds:
Grand Banks Dory
Congratulations on finishing your Dory.  You did a good job on building this model.  It looks so clean and crisp.
Ryland
Very nicely done, especially for your first build! Definitely a result to be proud of.
Your Dory came out great!  Congratulations on finishing!
Great looking model.  Congrats on finishing it.
I'm looking forward to following the sailing pram build.
Robert Chenoweth
In the research department:
Nothing at this time.
She a keeper  that's for sure. Congratulations  nicely done.   :cheers:
                   WASA
                   USRC Harriet Lane
I'm about to start on my own dory and, as a preliminary step, I'm working my way through all the wonderful build logs for the kit that are on this site. (50 scribbled notes taken for transfer to the instruction book!) Before I begin work at 1:24, perhaps a note on full-size practice won't be too out of place here, as Galkar's log is so recent:
In a "normal" lapstrake ("clinker" in the UK) hull, with curved sections, the strakes are bevelled amidships (besides where they approach the stem) to accommodate the curve while providing enough faying surface, between one strake and the next, for the clenches to pass and to give a watertight seal. The lands (the flat surfaces where the stakes project beyond the ones below) end up being narrower than the thickness of the planks used, with the narrowing depending on the curvature of the hull section and hence the amount of bevelling required.
Bank dories are different. With their slab sides, no bevelling is needed to achieve however wide an overlap might be desired. However, the original purpose of the design was to produce stackable boats that could be stowed in the limited space on a schooner's deck. In that role, wide lands would get beaten around and likely jam inside the next dory in the stack. The solution is the "dory lap", in which both strakes are bevelled through most of their width, leaving almost no land at all. In his reconstruction drawing, Chapelle shows an almost flush joint but real dories do have lands -- narrow ones, and far narrower than plank-thickness, but they are there. In 1:24, they might not be visible at all. However, reproducing a dory lap at that scale would be beyond challenging. (Scratch building, I'd rather go for a single piece, substituting for the three strakes, then scribe to hint at the laps.)
Still, to anyone familiar with the full-size prototype, meaning pretty much anyone here in Nova Scotia, the broad lands of the Model Shipways model look off. Nothing wrong with that: Models cannot truly be full-scale reality shrunken down. But if anyone wants to bevel their strakes and reduce the prominence of the lands a bit, I'd say go right ahead.
Trevor
Good points, Trevor. However, there are compromises on a beginners' level kit. However, if a model-maker can add those refinements to their dory, that would lift the model into another class!
Trevor
Thank you for the context - this makes me glad I did bevel mine :)
And good luck on your own dory!
Current build:
Completed Builds:
Grand Banks Dory
Thanks! I doubt that I will post a build log. (Better men than I, and at least one lady, have posted already.) But I hope to have something to show in the finished-models section, one day.
Meanwhile, you posted above:
"The last item to truly finish this kit is the beckets. I tried to install these, but the provided scale rope is just too large for the holes in the transom/sheer plank, and none of the drill bits for my pin vise drill are large enough to properly widen the hole. Maybe I'll try using the smallest bit from my power drill. On the other hand, some of the thread for rigging included with the Norwegian Sailing Pram kit seems like it may be a good size so I'm thinking I may see if there's any leftover after I'm finished with that kit that I could use."
I've been looking at the photos that Frederick William Wallace took aboard Nova Scotian schooners in the years before 1914. Some show the beckets quite clearly and they were made of surprisingly thick rope. It's hard to scale off the images but it looks like six lengths laid side by side would be about as wide as the top of the dory's transom -- which is pretty much as thick as the stuff that ModelExpo provided with my kit. (Maybe they do know what they are doing?) So the correct response for an accurate scale model seems to be drilling out the holes, rather than finding thinner cordage. It will look weird and clunky but, if that's how it was done back in the day ...
I could only guess at why such heavy stuff was used. Lifting a loaded dory, with the shroud tackles simply hooked to the beckets (no iron thimbles seized in, not even twine serving on the beckets) would have been a brutal way to treat the rope. Maybe men had learnt to compensate by using something thick enough to take the wear and tear.
However, if ModelExpo have got the rope thickness right, they are completely wrong on the rigging of the beckets. Every image I can find (Captain Collins' drawings from the 1880s, as well as later photos) shows the stern becket with its knots on the outside of the transom and its loop in the dory (or emerging in the dory, but often tossed casually over the transom, out of the way). That makes sense, as a vertical lift would lead cleanly to the inboard face of the sloping transom, not outboard.
I've been trying to discern what knots were used but I can't. My guess is a wall-and-crown on each end of the length of rope. To my shame, I've never managed to tie one of those in full-scale and I'm not going to try in 1:24! At that scale, fudging the end of the rope into a vague blob might give a better appearance than an overhand knot.
As for the bow becket: All the illustrations I can find show the loop emerging forward of the boat, with any knots inboard. (The reverse of ModelExpo's instructions.) That becket was not only used for lifting but also had the painter attached. My guess (and the one photo I can find seems consistent, though the detail is hard to discern) is that the becket was a continuous loop, made with a short splice that lay against the inboard face of the stem -- thus effectively transferring towing forces from the painter to the main structure of the dory, not to the planks and thence to the nails holding those to the stem.
If you want to include a painter, as well as beckets, some photos suggest an eye splice in one end of it, then the painter tag-hitched to the foremost point on the becket by passing the free end through its eye splice. However, other images suggest more of a gouty mess where the two ropes were joined, so a sheet bend with the short end frayed out and then glued into a lump might look very realistic, while saving a lot of heartache !
Trevor
When I wrote the above note, I had carefully read Captain Collins' details of the gear on a dory prepared for the halibut fishery (meaning a 15ft dory, as represented in the Model Shipways kit). Searching further for missing information, I see that he specified the stern becket of a dory used in saltbanking for cod as made of "3 feet of 2-inch rope". What he termed the "painter" (but which presumably included the loop forming a becket) as made from "5 fathoms of 2-inch manilla rope". I don't doubt that the same applied to the slightly larger halibut dories (though missed out during editing of what seems to have been a time-constrained report).
Given the date (published 1887), my expectation was that rope size was specified as circumference (as in the UK still, when given in Imperial units) but 2-inch circumference would mean 16mm diameter. That might be enough for a dory becket if made of Dacron but not in manilla. Thus, Collins must have meant 2-inch diameter (as in the US and Canada today), meaning 2.1mm at 1:24 scale -- which is very close to the size of the line supplied with my dory kit.
For anyone interested in following up, I've quoted those dimensions from:
G.B.Goode (ed.) "The Fisheries and Fishery Industries of the United States", Section V, Volume 1. The accompanying illustrations were bound as a separate volume.
The whole multi-volume work by Goode and his co-authors is still (after 140 years) by far the best, most comprehensive account of any nation's fisheries ever produced -- with details right down to, for example, the number of draft horses kept in Gloucester for hauling boxes of iced halibut to the railroad station! Indeed, that work has very rarely, if ever, been equalled for any single fishery anywhere. It is well worth consulting when modelling a North American fishing boat of the mid- to late-19th Century. And, courtesy of the generosity of the US government, it is available on line for free.
Trevor
