I have started a nice easy "Non-ship" build while I am waiting for the garage to warm up and I can return to making sawdust with my HMS Sparkler build.  My health has not been brilliant this last couple of months, so being out in the cold garage is not appealing at the moment.
I got this one off FleaBay reasonably priced and intend to build in OOB with the exception of some P.E. seatbelts.  This might be something of a quick build, as I have started it this weekend gone and it is just flying together -just what the Doctor ordered! 😁
I have built Airfix's 1/72 version of this and there are many similarities between the kits, and both go together well.  I won't say anything about the Defiant, as a great discussion on the Defiant was included in Andy's @realworkingsailorexcellent build log of the 1/72 version here:-
https://modelshipworld.com/topic/33924-boulton-paul-defiant-mk-1-nf-by-realworkingsailor-finished-airfix-172/#comment-965615
I'm going to finish mine in the colours of No.2 (Army Cooperation) Squadron, based at Hatfield Woodhouse, South Yorkshire in September 1940, for no other reason it was based in my home County of Yorkshire and the squadron code "KO" were the maiden initials of the Admiral!
A few pictures of the kit contents and the progress made on the cockpit.  I have now moved on to the mini-kit of the gun turret.
Edited by AJohnson
Andrew
Completed (Kits):-
I have a card model version of this aircraft, but I don't have a molded canopy or turret for it. Scratch-building those bits looks a very daunting task!
If you have never read the novel Piece of Cake by Derek Robinson (I recommend it), one of the central characters meets his end in a Defiant. I won't disclose exactly how -- you'll have to read the book!
I'll second Chris's recommendation. I've been fascinated with the Battle of Britain, ever since I was a young 2nd Lieutenant. There's also a video of this book.I watched in on our Public Broadcasting Network. Seems they played many British programs
Ken
Started: MS Bounty Longboat,
Next instalment, completed the gun turret structure, this was a fun bit of the build and consisted of about 20 parts on its own.  Shame it is all black and buried in the aft cockpit , so most of it will be hidden.  The turret glazing is only temporary and I will probably use the optional glazing that has the doors open, so you can see at least a little of the interior.
The fuselage and wings went together no problem and only a little filler required around the wheel wells and wing roots.  Everything has had its first coat of primer, (AK rattle can) just a few small areas to sort before pre-shading and then painting starts.  While that is underway I will also set-to masking the clear parts and assembling the undercarriage.
Thanks for looking in.
Andrew
Completed (Kits):-
The Derek Robinson books are great, possibly unsettlingly realistic. A Good Clean Fight set in the Western Desert is probably my favorite
alan
On 2/5/2025 at 1:06 AM, king derelict said:
Lovely work on the turret Andrew. It looks really great and a huge improvement on my attempt at the Airfix Defiant in 1/72 nearly sixty years ago.😁
alan
Thanks Alan, the turret is finished and I couldn't resist dry fitting it into the tub for a sneak preview. 🤓
Painting up next, final sanding and filling done and some panel-line pre shading.  I had a minor disaster and near flirtation with the carpet monster when one of the undercarriage struts pinged-off into the ether, only to be found by standing on it!  😖  All fixed now though. 😁
Thanks all for looking in.
Andrew
Completed (Kits):-
Hi all , thanks for the likes and dropping by.  Painting has begun.  I used Colourcoats enamels and thinners, masking with paper masks and tape cut to the required pattern.  This needs all to harden for gloss varnish for the decals and washes.  Progressing the remaining parts so this should come together fairly quickly from now on, a nice simple build!  😁
Andrew
Completed (Kits):-
Thank you for the likes and comments.  This one is finished! :cheers: - a nice easy build to recharge the model making batteries with.  I applied some panel line washes and a bit of weathering, nothing too drastic, then a coat of Matt varnish and added the canopy parts.  Last batch of pictures, for those interested.
Now, do I need one more "Non ship" build before plunging back into the "S" bit of  "MSW" ?  :pirate41:
Edited by AJohnson
Andrew
Completed (Kits):-
Just looking at that image gives me feelings of claustrophobia. The poor gunners had a terrible loss rate compared to even the hapless pilots of the Defiant. Think that picture hints at why, the suit seems designed to snag on everything possible inside the turret! :o
Andrew
Completed (Kits):-
Well done Andrew. A very nice model of this strange fighter. I guess that the Bristol F.2 Fighter might be in its genealogic line.
Best regards,
Dan
