As the title says, this is my first boat build. I ordered the kit and received it just before Christmas. This is the latest kit, so should not have some if the issues of the older kit that have been well documented. Have been reading and researching. Really lucked out with this kit as there are a quite a few build logs. Has proven to be very valuable and interesting reading and viewing.
So far have put the frame together and have just installed the first plank.
Definitely need to get a PC with a big screen into the hobby room! Am not that great at taking photos but want to document the process as I go.
One question I have is about 'fairing". How do you know if you have sanded the frame enough? Have not really found anything that shows what the  fairing is trying to achieve. Be good to see a before and after comparison.
I spent a lot of time researching how to plank, and found some great articles and videos which helped enormously. Initially wasn't sure  if I needed to to get a plank bender but decided to at least start with soaking in hot water and then put it in place and clamp it down. This worked really well though I did take a week to get this first plank to the right shape!
I also decided to ignore the instructions in the kit for planking  as they use filler pieces and following the advice of many am attempting to plank according to the experts.
What I did discover with this first plank is how difficult it is to fix the plank at the bow. Very little area to bond the plank to the frame. I also found that I had to sand  the first two frames at the bow to get the plank to sit nicely against the keel. None of the logs I looked at seemed to mention this so I just hope that it was the right thing to do. I have also decided to plank all of the starboard side first. This way any mistakes can be hidden if I display the port side only. That is assuming I don't make to many mistakes on the port side!
Nice job on the frame!
You asked about fairing. Looking at the edges of the frames, I think you need to fair substantially more, especially near the bow and stern. Fairing does two things: first, it allows the planking to take a smooth curve without any lumps or low poinrs, and second, it angles the edge of the frame to match the shape of the planking there, so that the plank isn't just barely glued to a corner but can be properly glued with more surface area. Generally when fairing, you'll leave very little of the laser char on the edge of the frames (although you usually want to leave a little, as otherwise you may deviate from the frame shape). The best way to see if you've faired properly is with a batten--a long, thin, flexible strip of wood. Place the batten along the frames and check if it contacts all the frames, if any are too high and need to be sanded more, and if any are too low and need to be built up. Then repeat at different distances from the keel, covering the whole hull. I think that fairing more at the bow would give you more surface area to affix your plank, too.
Also, you mentioned that you're planning on planking first one side, then the other. I'd recommend instead placing a plank on each side in turn. Otherwise, if it's not balanced, the pressure of the planking can warp the underlying structure and twist the hull, which cannot be fixed later.
You're off to a good start, and this site has lots of resources and information, some a bit buried in other build logs. Looking forward to following along with your build!
G'day Peter,
I found this description on another site,
The goal of hull fairing is to bevel the edges of the bulkheads so that the hull planks lay flat.  If we didn’t do this, the planks would only hit the corners of the bulkheads.
The problem is it only tells a part of the story. The aim of fairing is to have a finished hull with nice flowing lines, without lumps bumps hollows or kinks.
Simply bevelling the frames without considering this only allows a greater gluing area, which although important, is only part of the story as I said.
Your plank (or batten) should sit naturally against the intermediate frames if held down a few frames apart.
Looking at your second pic you would probably have needed to sand the areas indicated below. But only enough to allow the plank to fit.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Thanks Craig and "Jacques". This helps. I didn't quite realise the need to bevel the frame but I think I can see now what the fairing is trying to achieve. Back to the sand paper again! That is definitely a good point about balancing the planking to stop any warping. Hadn't thought of that.
Will take these suggestions and see how well I can implement them. Be a few weeks now as I won't be near the model for a couple of weeks. Sigh!
Not a lot of progress lately as I have been away. Did manage to spend some time last week  on re-fairing, especially the bow frames. Tried to heed the advice provided. Think I understand a bit more about what was needed. Also noted after blowing up the images in the instructions just how much was needed on the first few frames. I didn't get a chance to take a pic as the hobby room has an infestation  that caused a need to  fumigate the room! However I did add the first plank to the port side before the fumigation. This sits much better than the starboard plank which I still need to fix properly at the bow.
No progress now until the end of March!
Peter, I suggest you watch Leo's (Sampson Boat Co) videos on YouTube.
Particularly episodes:
24 and 25 Lofting,
27, 28 and 29 Frames,
78 Lining out,
85 and 86 Planking,
91 and 92 More planking.
This will fill in some of your blanks and entertain you as well.
Craig.
Hi Craig, Wow! That is an amazing project with some fantastic video. I have been enthralled by what I have seen so far. It is fascinating to see that a lot of the techniques that are suggested in model making are actually used in building full size craft. Thanks for passing that on. Only trouble is I am hooked into watching the entire project 🙂
Seems that I need to get some thin batten material for assisting with fairing. Think that would help me a lot to get the right shape when fairing until I can work it out just by eyeballing (if I ever get that advanced!). I saw that other people have used the second planking material  from other models but given this is my first model just not sure where I can get something similar.
Really appreciate the link and comments.
Tks Peter
Been there, done that ;)
19004-NHMSBountyJollyBoatPartsList1.pdf-Page004of008s.png.3afc48e4d73386550fabb873926c82b2.png
I see lots of spare wood there. Just cut carefully.
Edit: I should expand on that. Get yourself a stainless steel ruler with a straight edge (officeworks has some cheepies, hold two together and check for no gaps, flip one end for end and check again, flip it sideways and repeat until you find a straight one, they're pretty good so the first one will probably work) glue some 400 grit wet and dry sandpaper to one side to prevent slipping. Cut with many very light cuts.
Edited by iMustBeCrazy
Craig.
Hi Craig, what a good idea. Already have a couple of quality stainless steel rulers, so can definitely add the sandpaper. Thanks for the tip!
Peter
May I suggest you take a look at my build log of this kit.  I know it is lengthy, especially for a kit of this level, but I believe there is some pretty good information for first time builders.  I went to the extent of going back to previous steps where I made mistakes after discovering them later on and provided warnings or advisory notes so you won't make the same mistakes I did.  They could be helpful for you.
Take care and be safe.
kev
Current Build:  HMS Bounty's Jolly Boat - Artesania Latina
On the shelf:  Oseberg #518 - Billing Boats
Thanks Kev. Appreciate you looking in on my log and your advice. I have read your log (and all the others that I could find!) and have gotten many useful tips and suggestions which will hopefully lessen some of the mistakes I will undoubtedly make along the way.
Cheers Peter
A wonderful thing to remember is that just about any mistake can be fixed/corrected.  The only deciding factors are if you want to do it, is it worth it to you and if you can afford it.  I decided to replank my hull because I just couldn't live with my first effort.  I did go ahead and work with what I had before I tore it off.  Fortunately the cost of more planking was minimal and now I have enough leftover planking for my next effort.  I have to say that my second effort came out much better.  My rudder on the other hand, as bad as it turned out, is something that I've decided to live with.  At the moment I'm rerigging it to take full advantage of the new line I got from Ben.  During the beginning of that process I found that I messed up my sail and kinda lost my steam to go on at that point in time.  When I get the feeling again I will fix my sail and hope the rigging anchors I created work.  If not, I'll figure something out.  Have fun and I'll be checking in now and then.
kev
Have been making some progress this week. After re-reading a lot of logs and watching quite a few videos, I "think" I now have a much better appreciation of what is entailed in fairing. I followed Kev's lead in generating a batten from some cardboard. Works a treat. Will make some more. It definitely helps in the fairing process and also where to lay the planks. I have now laid the garboard and broad strake planks on both the port and starboard sides. Have made  an error with the port broad strake (cut it too short! Oops!). Am hoping it will be fixable. It is not too bad. Have found that it is very hard to get the bend right at the bow and have little contact to glue to. Tried to use super glue but that still didn't hld. Might try adding a bonding pad which I have seen on other logs (Ken_2).
image.thumb.jpeg.8797eaf8d4af7cc3691dec52939f77df.jpegimage.thumb.jpeg.5061295a9b8387135a67b640f68d4aad.jpeg
While waiting for the glue to dry, thought I would start work on shaping the oars. Pretty happy with how they turned out, even though they aren't completely round. Still to be painted. Not sure what colour scheme I will use for them.
Nice progress, and great job on the oars, they look excellent!
It looks like you've done a lot of good work fairing the hull more than before. That said, I think you may run into trouble around the inner support pieces that the thwarts will rest on. It looks like the support is sticking out a ways beyond some of the frames, which will make planking there difficult unless the instructions say it's supposed to be that way for some reason. Sanding it down even with the frames now will probably save you a big headache later.
Also, how high up the bow do the planks extend? If they go too high up, it will be very hard to fit other planks against the stem.
Thanks. I was worried about how that support was sticking out. I have sanded it back already but now that you have mentioned it, I will sand it back even further so that it meets the frames.
I am a little worried about the bow, but have lined it out even though the plans don't do that. am narrowing the planks as they run to the bow (and stern) The plans show the topmost planks running to the bow and then when the stem has no more room they cut short the planks. Not ideal which is why I am trying to get all the planks to the stem if possible.
At least I am aware of this and will try to work through the issues. Running into these issues on this model is really helping my learning and teaching me how to remedy them or even better avoid them in the first place.
At the moment I am happy to moving ahead with planking 🙂
Cheers Peter
Edited by Peter S
Edited wrong post
Got another 2 planks installed (no pics yet). Going away for another few weeks so not much will be happening until I get back. Think I have a better handle on what I am doing. That is until I hit the next hurdle 🙂 Really enjoying the process and learning heaps. This really is a good model to start with as you are forced to learn a whole lot of techniques!
Had a short week being able to work in the dry dock again. slow progress as it takes 2 days for each plank. First day is getting the plank bent to the right shape and second day waiting for the glue to dry. Don't want to rush the project so whatever time it takes is what will happen. Have now installed the first 4 planks on each side and the top sheer plank.  It is definitely going to be  a challenge to clamp the planks towards the end. Also know that I will run out of room at the stem to fit all the planks so will be following the AL plans to manage that. Getting the planks fixed at the stem has been a struggle but getting a better handle on what to do now. I know that I will need to do some remedial work with filler once the planking is completed. Glad I decided to paint the hull for this first model! The learning process is steep but rewarding. Some pics below showing progress. Can see that the port garboard plank is sitting too high at the stem but hope by the time it is sanded back it will look
Edited by Peter S
Added pics to correct post
Well! It has been quite a while since my last post and so much as happened including selling the house!
Finally placed and glued the "whisky" plank today (though the whisky will have to wait until after dry July! Not good timing 🙂 )  Learnt so much in doing this planking. Some planks were really good and others are very ho-hum. The important thing is that I learnt heaps, had lots of fun and generally took my time. Typically each plank would take 2 days. First day was spent  trying to get it bent into the right shape. Mostly this was achieved by soaking the plank in hot water for 5 to 10 minutes and then fitting the plank to the frames. The hardest part was trying to hold the planks into the correct position with clamps and anything that I could find. This was not always as successful as I would have liked especially when there was little space to put a clamp in place. But I never used any pins and only ever used wood glue and not super glue. Once clamped left the plank to dry for 24 hours and then glued it in place. Found that I still needed to clamp whilst the glue dried but generally the plank had the correct shape.
Of course bending around the stem was challenging (as many have mentioned). As much as I wanted to plank the "proper way" as per Chuck's instructions, I really need to spile a number of planks but did not have the material to cut them out, only having the planking provided in the kit. So in the end I did need to put in a couple of  "filler" planks. These ended up working really well and was very pleased the results albeit not proper boat building! But it did teach me a whole lot of techniques on shaping planks to the shapes I needed.
Some pictures below. This first batch are some I tool a few weeks ago showing the planking progress
As you can see above I was also experimenting with using some wood filler, just to see how it works out.
As mentioned the main planking is now complete with sanding started. Seems like once I think it is nearly ready I realise that more sanding is needed. However it is starting to look a lot better.
Apologise for my photos. Am not good with the camera
Hi Peter!
I think you are doing a fantastic job! Especially for your first model.
Your picturs look great and I believe you have done a grear job planking your first hull.  I think you have gotten some excellent advice from othet members here.  For me, the real trick about planking a hull is making sure the bulkheads are faired properly.  This took me a while to figure out.
The only thing I wish some of these kits had, were more bulkheads to help with understanding the curve of the hull.
Anyway,  keep up the great work and I'm going to follow along!
Jeff
Current Builds - USF ConfederacyCheerful
Thanks Jeff. The advice has been great and extremely helpful. Agree about fairing. Took me quite a while to realise not only how important it is to do properly but also to figure out just what to do. Doing the planking shows what needs to be done and what should be done. Will hopefully put this newly gained knowledge into practice for the next model. But still have quite a bit to do on this one yet. The planking took a lot longer than I had anticipated but that's OK. As they say patience is the name of the game. Now it is sand and sand and sand again 🙂
Been a while since my last post but have been busy with a few outside projects, namely moving and packing up the house. Have now moved permanently to the South Coast of New South Wales and loving it!
Finished off the sanding of the hull and was reasonably happy with the result. Had decided (right from the beginning) that I would follow the AL painting scheme and had bout the relevant  AL paints, though as the stains were out of stock I have been purchasing what I need from the local hardware retailer. Fortunately I could get reasonably small batches. (I had been worried that I might have to get 500ml to 1000mls!)
Stained and varnished the upper hull as per the instructions. (Sorry no pics) Then marked the waterline. Found this to be a lot harder than anticipated. Found it difficult to get pencil marks on the varnish. Eventually marked and then taped the waterline. Sanded the lower hull to remove the stain and varnish and started applying the paint. Have so far applied around 10 coats of the AL white paint (using a paint brush). Am definitely not happy with quality, am finding it very thin and runny. Not sure if that should be expected but I just keep adding coats trying to get a consistent colour across the hull. Has anyone else experienced this or do most airbrush.
Has been a real learning curve with painting and think for the future I will look at the Vallejo paints as they seem to be popular and have good comments.
Adding all these coats has certainly slowed down progress as I really can't do too much more until the hull is finished. Will post some pics once I decide that have applied enough coats!
Edited by Peter S
Finally decided that I had applied enough coats and pulled off the masking tape. Unfortunately in doing so it has peeled away some of the varnish. Not happy about that. Will not use that masking tape again. Even though it was a reputable brand specifically designed for use in painting! Will attempt to apply another coat of varnish to see if that improves the look.
Think I have made a bit of mistake. I have stained and then varnished the top half of the hull before attaching the wales on either side. Am having a great deal of difficulty getting the wales to stick to the varnish. I have tried PVA and also CA gel but with no success to date. It seems that the varnish does not like to be adhered to! Any suggestions?
Hey Peter!
What i would try, would be to sand off the varnish where you want you want to glue the wale strips on.  Try not to sand too much, just enough to get the varnish off.  You can always restain/revarnish after placing the wales on, or also over and parts where you might sand thats not where the wales are.
I hope this helps!
Jeff
