The potential for another brush with insanity. Another wonderful Flyhawk kit with lots of tiny details and extensive photo etch.
The kit comes with photo etch, metal gun barrels and some brass rod for the masts and some resin bollards.
The box is nicely packed with a lot of material and an illustrated card with a summary of the ship’s career.
I added the wooden deck but I think I will see if I can pull off a decent painted version first. It removes the long term worry about the wooden decks lifting at a later stage.
The photo etch is comprehensive and intricate. I’m not sure how much I will use. Some of the plastic pieces are well detailed and delicate and also have a better sense of three dimensions. Similarly the metal gun barrels. The metal barrels for the 13.5 inch and the 6 inch will definitely be used. I’m not so sure about the 3 inch and 3 pounder ones.
There looks like there will be plenty of areas to work on. The plastic is the usual Flyhawk crisply molded dark grey plastic. This should be a lot of fun.
Thanks for looking in.
Alan
Another excellent build to follow mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you OC. I think this will be quite a long build so I hope you enjoy it. The plastic details are lovely. The judgement will be with using the PE, the plastic is already quite good. At least this kit has the option to drop back to the plastic if the PE gets too difficult. With Derfflinger there was no alternative to the PE. So this kit has the PE instructions separately so you have to read two sets of instructions in parallel. I think I’m going to build up as much PE as I can before assembling the major elements.
alan
Wow, that is a lot of detail Alan, definitely following along on this one! 😁
Andrew
Completed (Kits):-
Alan, that looks like a nice kit down the memory lane of the 20th century.
Respectfully
10 hours ago, Canute said:
This kit looks loaded with detail, Alan. I, too, will be following.
Welcome Ken. Some of that detail looks a bit intricate. I’m busy reading and comparing the instructions for the plastic and the upgrade. If it’s “ measure twice and cut once” this definitely “ read the instructions ten times and glue once”
alan
The first hesitant steps into the build. The hull halves have been fitted to the waterline base. It took a bit of fiddling to get the two halves lined up properly on the base but by gluing the bows together and then inserting the base and gluing it up a short length at a time it went together fine and everything fitted together without gaps.
I’ve spent a fair amount of time working out the most effective build sequence. While I have been pondering I decided to tackle the metal gun barrels. I always get a bit nervous about this step. I find it hard to get the barrels correctly aligned after adding the metal ones. The plastic ones look quite good until you look at the brass ones so I took a deep breath and started snipping off the plastic ones. The 13.5 inch guns went quite well. A plastic barrel is shown for comparison
So I contemplated the barbette guns. Again the metal does look better so I did some irretrievable snipping
I used a dressmakers pin to mark the spot to drill and stop the drill skipping and after a few pin pricks I got them done. There are six flavors of barbette guns hence the numbered spots on the double sided tape. The brass barrel and the plastic ones are shown by the knife blade.
I decided that was the limit of my skill for this and decided to leave the 3 pounders well alone. They are tiny.
IMG_1748.thumb.jpeg.340e876db2100406d91c4570259a4a96.jpegIMG_1744.thumb.jpeg.dc83d445841e8550044f96d17ebafff2.jpeg
The plastic parts are numbers 4 and 5 on the sprue and the brass barrels are in the plastic bag. The triangle at top left is the tip of a #11 blade.
 first photo etch has been added. The doors for the barbettes are provided in two versions. I’m not sure quite what the difference is between them but the first one was duly added
Both sides are now complete and I added the first barbette
It does look nice enough to justify the extra work.
Slowly forward is going to be the nature of this build.
Thanks for looking in, the likes and all the kind comments.
Alan
Nice tidy  start  there Alan,   those barrels  and  the  PE  so add  to the  detail.
OC.
Current builds
Completed works.
Slow progress but plenty going on. I completed all the barbette doors and added the barbettes. In hindsight I should have installed the barbettes first and then added the photo etch doors over the top. Doing it the other way around meant it was difficult to line up the gun barrel and the locating features of the barbettes. However, given that the doors completely mask the barbettes the gun barrels can just be poked through the hole in the door and glued in place without bothering with the barbettes. So far I haven’t found a downside to this thought. You have to use the brass barrels with the doors, the plastic ones are too thick. With the guns sorted out I glued the roof in place and this bit is ready for some primer.
IMG_1759.thumb.jpeg.7dafd819c2734f5a6c5009b1316d84df.jpegIMG_1758.thumb.jpeg.af79f261d0343b4f607dba6a0033f2b1.jpegIMG_1757.thumb.jpeg.2d58b0c80b5d43735c8bb7a2335d54c8.jpeg
one reason things are moving slowly is the need to keep assessing how far to go before priming and painting. I started building some of the superstructure subassemblies.
Photo etch needs to be added, some like railings, ladders are a good thing but other bits really don’t add much detail and feel like PE for PE sake. I’m brooding over whether to replace the plastic support for the platforms with the PE. These are parts 38 on the fret. The plastic supports are over scale but are probably neater than I can achieve and I don’t see anyone turning up with calipers to get difficult about it. I’ll decide in the morning.
Thanks for looking in, the likes and comments
Alan
those are not barbettes for the 6in guns but casements. the barbettes are the bases for the 13.5in turrets to sit on. they are similar to what was on the American standard battleships with the New Mexico class being the last to have them in the hull but no guns installed.
Thanks for the correction. I had the feeling that barbette was wrong but casement didn’t occur to me.
alan
Close, but the word is “Casemate”.
Casement refers to the operating (opening) part of a window in your house.
Casemate is the armoured enclosure through which the guns can fire.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Andy
Thanks Andy, I knew I had heard of casements somewhere 😀
Now that I recall I seem to think fortifications had casemate walls and later casemates housing guns.
alan
I found a little courage this morning and cut the plastic supports off two of the platforms and added the tiny photo etch parts. It took all day to build them up with a few diversions to find the little triangles after they flicked off the tweezers. Oh and a three hour power cut.
At the end of the day they came out okay but I’m not sure it justifies the work.
IMG_1765.thumb.jpeg.2c7222eecb0fc973200924818648498b.jpegIMG_1762.thumb.jpeg.a9400d940ce90f868d47a93788ccab9b.jpegIMG_1761.thumb.jpeg.54f14655dc45c338220d4f1770371cb5.jpeg
There is one more to do but I’m thinking of passing on it and moving forward with some primer.
 Thanks for looking in, the likes and comments.
alan
Progress hit a bit of a roadblock. I had to order the hull grey, the Flyhawk guide calls for a darker grey than anything I have. Then I had to do taxes, vet visit, eye clinic visit and a trip to the dentist.
Anyway, the has arrived and the hull and superstructure were given several light coats to try to avoid a uniform color. The decks then got a coat to the Tamiya wood deck and then I used washes of burnt sienna and burnt umber oil paints. I like the result so far but I may add a thin black wash to pick out the details.
IMG_1781.thumb.jpeg.a8f5dada169dc2945a2b42cb354bb122.jpegIMG_1780.thumb.jpeg.bf0b3b5bbfab7f01bac2cba7b4ce8b8c.jpegIMG_1779.thumb.jpeg.02f38790b98abcd22590a1c77e4d3cf7.jpeg
Next up will be painting the linoleum decks and then back to the photo etch and a lot of railings.
Thanks for looking in and the likes and comments.
Alan
Picking this back up again at last. I started working down from the top of the bridge structure adding the photo etch railings and details while access is still easy.
It doesn’t look much but this was an afternoon’s work which did include losing and finding tiny bits of railings
IMG_1830.thumb.jpeg.74f1d9774b3145aa06699bbe38be5cfc.jpegIMG_1831.thumb.jpeg.a17f089e8ab826c7194ee1644be9a72f.jpeg
The Mig Ultra glue is getting a bit clumpy as I reach the bottom of the bottle possibly from repeated dilution to keep the consistency thin. Time for a new bottle.
Hopefully I’ll be making some progress again.
Thanks for looking in and for the likes and comments.
Alan
Well, the plan to work downwards with the superstructure came to an end as the railings and details filled out the work so far and left it with very few places to hold the assembly. So I built up the lower sections of the forward structure and added the bridge platforms already detailed. A nice morale boost too. Now there are more railings and ladders to add to the lower section. The bridge pylons are just a dry fit to see if everything lines up. It’s not perfect but it will work I think. Once those are fitted there is some highly fragile and complicated stuff to go on top.
IMG_1838.thumb.jpeg.8dbc2be0010867f1fd3b08b4517dbedb.jpegIMG_1839.thumb.jpeg.22082aa23584497738dabfc729364980.jpegIMG_1840.thumb.jpeg.73d7db8299b7d54e07dcc9467407235a.jpeg
Thanks for looking in, for the likes and comments.
alan
Alan, at that scale you are doing amazing! I am having a hard time at 1:350 scale.
Respectfully
Agreed, amazing - not sure with my shaking hands I could get the rails and ladders on the correct part at that scale! 😂
Andrew
Completed (Kits):-
Thank you Andrew. I need something solid to rest on when adding the railings and ladders. The pill containers are great for providing a solid handhold and keeping paws off the model but they also give me a brace when adding the delicate stuff.
alan
Another day in tiny world with apparently not much to show for it. Ladders and railings mostly. The Flyhawk PE instructions don’t show where the ladders go and luckily I reread the general kit instructions and realized that I needed to add several to the bridge decks. Unfortunately it was a bit late in places and adding the ladders was ticklish to say the least
one ladder drops from the second highest deck through a hole in the deck. On the deck below three ladders drop through the deck. The center one used up an hour or more because it had to be fed upwards from the deck below with very poor sight lines. Gently insert, drop, retrieve and repeat with the occasional variation of the ladder dropping and needing the flashlight and hands and knees treatment. I eventually got it in and now realize that the long ladder masks it completely. I suspect a lot of the will be obscured when the funnel is in place but think of the benefit to my soul.
I think I’m ready to fit the pylons and then move aft.
Thanks for looking in and for the likes and kind comments.
alan
Amazing  work Alan  -  looking  so good mate.
OC
Current builds
Completed works.
Well, we have a funnel now and the B turret is dry fitted for morale purposes. The pylons are fixed in place and went remarkably easily. The funnel was a major exercise. Flyhawk were very restrained in not wrapping it in fiddly PE, the problem was the fit. That long diagonal ladder at the back of the forward superstructure interferes with the funnel and I could not see a way to make any space so, after several attempts I had to settle for the ladder getting deformed. I think this may all be my fault, I think I have the upper bridge structure a little too far aft and that results in the foul. However I was correct, the ladder is almost completely hidden by the funnel. A ladder and a few bits of minor PE finished up the day.
I think it’s time to start working on the ships boats and the aft funnel  I have three ladders left so I hope the aft superstructure is not too populated with them.
Thanks for looking in, the likes and kind comments.
alan
