Mike,
Have you had a look at the builds here:  http://modelshipworld.com/index.php?/forum/51-msw-group-build-of-an-18th-century-longboat/ ???  The builds might answer your question.
I'd buy it, there a is ton of info on this build here on MSW.  I do not know how they rate the difficulty levels though.
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
Basically the planking....<ost folks will buy the kit because its not expensive and small and that alone doe not make it a beginner kit.  But often times they think that.   Planking a small boat hull like that is much harder than planking a larger hull.  The bends and angles required make spiling and shaping the planking a must.  This is something that beginner builders can not fudge.  Yes the hull is painted but you will see see the run of the planks inboard and using such thin planking material it doesnt leave much room for sanding out errors.   Filling any gaps may also be seen inboard.
Basically it is the proper planking expertise that makes it an advanced kit.  Especially at the small 1/4" scale.  That being said.  Its a great teaching tool to learn proper planking and with only a few strakes per side they can be ripped off and done over many times.  For example,  My local club is building the Pinnace kit and we are using it to teach more advanced planking techniques.  Some of our members have ripped off the planks three and four times.
You will learn how to properly shape a garboard strake and where to place its forward end.  Dont let it scare you.  Give it a try but if you have never planked a small boat like this before,  you should expect some new things to pop up while doing so.
Again...read all of the logs on this site as suggested.
Chuck
I Appreciate that, I would never attempt this build if I didn't have all the support. I'm looking forward to this project.I'm going to do my homework and study other builds before I ever even open the box.
Mike,
     Lots of help if you need it.  I am just finishing up my Longboat build and injoyed it very much.  Please do not hsitate to ask questions.
                Bob R.
San Diego Ship Modelers' Guild
USS Constitution Ship Modelers Guild
USS Constitution - Model Shipways - 1:76 scale.
18th Century Longboat - Model Shipways - 1:48 scale
Higaki Kaisen - Woody Joe - 1:72 scale
People assume that an advanced kit is one that takes 1000+ hours of construction time.  Wrong.  An advanced kit is one that challenges you with techniques you have not encountered before and the need for perfection in every piece installed.  There is no way to hide a poorly fitted plank on an open boat.  Although I replaced most of the wood provided (the basswood was so soft I thought it was balsa), I found this to be a thourougly enjoyable kit which could reasonably be finished in 100 hours.
Toni
Member IPMS
                           Utrecht-1742
Chuck
Edited by MikeB4
  • 3 years later...
On 27-12-2013 at 8:09 PM, mtaylor said:
Mike,
Hi everyone.
I know I am quoting an old post. I have my first boat on order and it is the 18th century longboat starter kit. I would love to read the build logs of the group build but I can not find them. The mentioned URL http://modelshipworld.com/index.php?/forum/51-msw-group-build-of-an-18th-century-longboat/ gives me an error. I found a forum section about archived items (see https://modelshipworld.com/index.php?/forum/59-general-info-about-group-projects-on-model-ship-world-and-past-groups-archived/ ) but there is only 1 topic.
Are the build logs still available and if so, can anyone give me a link?
Thank you!
Edit: please forget my newbie question. I tried some more searching and suddenly I have a whole list of build logs of the longboat. I must have done something wrong...
Edited by dekristof
my question is answered
All of the build logs have been moved to the "Build logs for kits" area.   The group was shut down long ago.  But all of the build logs remain.  Click here to see most of them after I did a search in that forum.
https://modelshipworld.com/index.php?/search/&q=longboat&type=forums_topic&nodes=10&search_in=titles&sortby=relevancy
