I have decided to build a Ship in a Lightbulb. I have rigged a base to light up using parts from a cheap LED flashlight. The base is an old light fixture. the LEDs push into the light socket which is wired to the flashlights battery pack and on/off button, I have also added a sheet of thin plywood stained with some redwood stain. Sadly during the process of making the base I broke the lightbulb there is still enough of the bulb left for me to be able to size and make the model but I cannot use it in the finished product because it has a large hole in the side, incandescent lightbulbs are hard to get in California but I think I can get a halogen that will work.
     I am thinking of making the HMS Sophie from Master and Commander by Patric O-Brian.
Lextin.
"I have no special talent. I am only passionately curious." - Albert Einstein.
Nice start on what looks like a fun project.  I like the lighting.  What ship do you plan to build?
Bob
Current build:  SS_ Mariefred
Incandescents are hard to find? I have them lying around the house here. You can buy them for pennies apiece at the grocery store, hardware store, walmart etc. Interesting how things can be common in one place and rare as hen's teeth in another. I would ship you a few but they likely wouldn't arrive in much better condition than the one you already have....
Wish you luck and gooooooooood eyes
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Lextin,
What type of bulb do you need? Shape and wattage, I have a stockpile of some clear incandescents I was saving for a rainy day and I'll see if I have anything that will help.  :)
Sailor1**,
They've practically outlawed incandescent lights down here in the States.
WOW a full rigged ship in a light bulb. That's going to be some project. Looking forward to seeing your progress.
S.os
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Mark I will try go get into town and get a halogen bulb that should work, I just changed out several of them for a friend abought a week ago I wish I would of had the foresight to take one of the old ones. For now I will start the planning for the model.
Lextin.
I started work on the ship which is going to be HMS Sophie from Master and Commander by Patric O-Brian. The hull is made from some fine grained softwood I had left over from a previous project, the bulwarks are made from card.
   The HMS Sophie changed paint schemes throughout the book so I chose the one that I could make with the paint that I had.
Lextin.
Absolutly great!!!
My carpetmonster adapted to laminate flooring!
GK - Modellbau No. 2002 a little boat 680 after E.Paris  - PoF 1/50
AL 18021 Scottish Maid the 1st Aberdeen Clipper 1839 - PoB 1/76 (?)
Dream: a hullmodel of the 66 55/95 tons US-Revenue drop-keel Cutter 1/2"=1ft, plans by H.I.Chapelle
Looks good.  She's going to look great in the light bulb.
I have not done much work on the Sophie but felt that I needed to post an update so you you guys don't think that I abandoned the project. Since my last post I did some work on the rigging and got a new lightbulb.
    I wont be working on the Shopie for a wile as I am making a SIB for a relative right now.
Lextin.
I got some more work done on the Sophie. I prepped the new lightbulb and cut the threaded portion shorter so it would fit in the base with the LEDs behind it then I made the sea from non hardening modeling clay. I made the sails from paper then painted them white a slightly off white color. I still need to add some finishing touches then I will bottle it.
Lextin.
She's looking good.
Bob
Looks great, Lextin.
Congratulations, Lextin.  One sweet looking SIB .
