egkb
HM Schooner Ballahoo by egkb - Caldercraft - 1:64 Scale - First Proper Wood Build
Hi All,
This is my first proper wooden boat build, I say proper because some time ago I began building the Bounty from those magazines that came every week (you may be familiar with them) and though she turned out reasonable enough (I'm about 80% complete, just the Rigging to finish) the instructions (there was no 'plan', just text with photos) left a lot to be desired and makes even the simplest task awkward.
Last Summer I came across MSW and having read and followed many build logs I decided to buy a proper kit, in fact I bought 3 over the past few months! Sherbourne, Convulsion & Ballahoo all at 1:64 and all Smallish Vessels (This is just a personal preference)
Anyhoo, I have decided to do Ballahoo first, and possibly stagger the others over the coming months.
(The first time I opened the box and was hit by that pleasant wood smell, reminded me of those old wooden pencil cases from school :)  Oh! and it was great to unfold 'actual' plans too!)
Right lets begin..
Whilst the Keel and Bulkheads were still in their 'Matrix' (or whatever the wooden surround is called) I oriented the Matrix to the appropriate instruction sheet (in the Booklet) and numbered each piece, as some of those bulkheads may end up in the wrong slots on the Plywood Keel (am sure it would be easy to spot, but why take the chance)
I then removed the Ply Keel and all the Bulkheads using a Jewellers Saw (tried using a craft knife but ended up having to apply pressure, which didn't sound like a great idea) All items once freed got a light sanding and were then 'Dry' Fitted (see Photos) So Far So Good..
I shall cut a Rabbet and Bearding Line etc (as per Jim Smits and his Ballahoo) though the Plans/Instructions do not call for them, it seems logical when you take the Ply Keel dimensions and 2 layers of Planks into consideration.
Should anyone wish to offer advice, please feel free to do so.. it all helps and I would be very grateful.
Take Care
Eamonn
Edited by egkb
Share this post
Link to post
Share on other sites
Thanks for checking in guys and for the Likes, it really does give encouragement!
Nigel, I will be attempting them all, but staggered by a few weeks or so. Admittedly there may be a bit of a gap at the beginning so that I can get my head around things (and it is a Cold Build Room too at this time of year :)
Thanks Again Folks
Eamonn
Share this post
Link to post
Greetings Eamonn,
Glad to see another Ballahoo on the stocks. I started mine just after Christmas but have been struck down with a bit of a stomach bug and am taking some time to get over it, penalty of old age I expect.
One thing I did notice is that the #2 bulkhead on mine stopped a little short of the bearding line so I've had to beef it up a bit. Have you noticed any similar problem?
I must ask; in your photos are the B/heads glued in place or are they dry fitted?
I ask because I am planning on 1st planking before attaching the keel proper and have and bevelled the false keel for the rabbet. Now I wonder if I will be able to get an accurate fit later after 1st planking. What's your plan?
Patrick M.
Share this post
Link to post
Hi Eamonn
Congratulations on starting your build log which I will follow with great interest, the very best of luck.
Regards
Glyn
Share this post
Link to post
Thanks for stopping by Glyn (perhaps I'll have the beginnings of a Convulsion in the coming weeks) :)
Hi Patrick, My bulkheads were only dry-fitted and have been removed from the Ply Keel at present so that I can begin bevelling, they will be re-fitted (again 'Dry') to establish Bearding lines etc. It is too soon for me to notice any shortfalls in the bulkheads as this was purely a fit test, though I suspect I will fit the Walnut Keel (after cutting/filing a Rabbet) but will leave off the Rudder Post till much later. So she will be planked with the Keel in place! (I have just had a quick look at the photo (above) showing No.2 B/Head and it seems to be a little high also, will have to give this area a serious examining when they go back on!)
Having said all that, I planked my Bounty (both layers) before fitting Keel, Rudder Post and 'Bow' Piece, I used walnut coloured filler to take care of any gaps and you would need to look very closely at these areas to spot the 'filler' (Bounty is coated using Danish Oil, put on with a cloth) If you plan on painting the Hull then you really shouldn't have a problem (besides you would probably have to turn her upside down to notice any filled errors, and even then it would be next to impossible :)
Thanks again Guys
Eamonn
Share this post
Link to post
Off to a nice start - mind if I follow as well?  I am partial to schooners, just like the lines and simplicity!
Share this post
Link to post
No worries Wayne, I've been following your Emma C.. Talk about pleasing lines on a boat!! I think there will be one in my future (hopefully a distributor will set up this side of the pond, unfortunately they are expensive to have shipped over !)
Take Care
Eamonn
Share this post
Link to post
Hi Eamonn,
The Ballahoo has become a very popular build and on my list for a future build!
Your photos show you're off to a good start and I will be following!
Cheers!
Dee Dee
Edited by Dee_Dee
Share this post
Link to post
Thanks Dee Dee and Jim for dropping by, remember if you have any advice then please don't hesitate to put me right (this goes for all ye folks out there too) :)
Next up is a spot of bulkhead bevelling, then Rabbeting & Bearding (Then contacting Caldercraft for replacement parts 'cos I made a mess of things :) )
Eamonn
Share this post
Link to post
Small Update:
I now have the Bulkheads sitting flush with the top of the 'False' keel (ie at their correct depth) and have begun to draw the Rabbet/Bearding line.
Patrick (Ganymede) Bulkhead No 2 does indeed seen to sit a few mm higher than the others (at the bottom that is, nearest the Rabbet area) I cut out the 4 Plank Termination Patterns (part No's. 13 & 14) and dry fitted them, showing that B/Head 2 is higher, not sure yet what action I'll take as I haven't shaped that area yet ie bevelled the Bulk Heads,  I'll ask Jim if he encountered any similar issues.
Eamonn
Share this post
Link to post
Another small update: Bulkheads are now roughly bevelled to the correct shape. and I have the beginnings of a Rabbet in place and a Bearding line in place, am trying to decide whether Bow and Stern Filler Blocks will be needed (I had planned on putting them in but not so sure they are required now! will have to see) normal filler blocks filler blocks will be put in place between the B/Heads.
That's All For Now Folks.
Eamonn
BTW.. Does anybody have any passing thoughts re the Bow & Stern Filler Blocks? (it is a very small area to fill  on these boats!)
Share this post
Link to post
I certainly found the bow and stern filler blocks useful for the planking in those areas. I don't think I could have done without them.
Tony
Share this post
Link to post
Thanks for stopping by Nigel and for the advice.
Remember to shout out if you see me about to make gaff.. :) (unless of course I actually am making a Gaff for the boat! :) )
Eamonn
Share this post
Link to post
Makes perfect sense Nigel, in fact I am at that point right now, I had marked in the Rabbet and was looking at where the Bulkheads lower parts sit in relation to where said Rabbet should go (along the join of the false keel former and the actual keel piece) compared to where it actually fits! (Parts of the Rabbet seem like it should be a few mill higher, particularly at the first 3 B/Heads near the bow)
I'll follow your advice in this and leave off the Keel Pieces until later, then carve the Rabbet based on the result!
I think I'm ok at the stern re Bearding Line and Rabbet there as it needed to be thinned regardless, the bow was the thing that made me stop and think (then up popped your advice :).. result!)
Eamonn
Share this post
Link to post
Thanks for stopping by Lawrence, I figured the planks would be wafer thin without it, especially at the stern where there was only about .5mm per side difference between the 'false' keel former and the stern post ! (double planked into .5 mm hmmmm that is seriously thin :) )
Eamonn
Share this post
Link to post
And Another Update, featuring Real Life Actual Photos This Time.. I'm really spoiling ye all  :)
Anyhoo..
I fixed up a building board and clamped the keel between two pair of 90 degree angles, would recommend getting these in line with each other least you induce a 'nice' bend in the keel!!
This let me set the keel down Level and Perpendicular with the board and allowed me to glue fit two bulkheads in place. I dry fitted another Bulkhead at the stern (B/Head No. 10, I think) which enabled me to put the deck in place (centred) to help align the 2 glued B/H's (the Red Clamp is just to keep the deck piece flush with the Keel)
I will let the glue set before continuing with the B/H's.
Question Time :)  (See Arrow on 2nd Image)
I notice that the 'aft most' outside edges of the B/H's sit out from the Deck piece slightly by 1 or 2 mm (Remembering the 'fore' parts are only roughly bevelled at this stage) as things stand this would leave a gap where the Bulwarks will meet the deck at a later stage ! Deck planking would of course solve this, but my Question is.. Should I sand these bulkheads flush with the deck?  I know that the 'fore' corner/edge of these B/H's is to be bevelled properly, but should I sand the rear corner/edges too (just the top 1 or 2 cm's where the Bulwarks would go, these 'Horns' are to be removed later anyhow) ?
Hope that question makes sense.
btw, the 2 bulkheads are fairly level with each other (perhaps 1mm or so out) it's just my photography that isn't 'level'.. :)
Take Care Folks.
Eamonn
Edited by egkb
Share this post
Link to post
Thanks Andy, I haven't looked that far ahead yet (re planking inside the Bulwark) but I'm pretty sure there is.  I have just put a couple more B/H's in place and they sit nicely with the deck so I think you've nailed it in that it isn't something to worry about. Besides a few delicate taps with a sledgehammer should cure it.. ahem :huh:
Thanks for the advice and for looking in at the build.
Eamonn
Edit.. Hi Nigel, just spotted your post after I had done this one.. shouldn't be too hard to sand down if it proves to be an issue, we are only talking a mm or so, as Andy says, may be nothing to worry about!
Edited by egkb
Share this post
Link to post
Hi Lawrence, is that the illusive 'Rabbet' or am I picking you up wrong? if it is the Rabbet then 'Yup' that is exactly what I'll be doing later (following Nigel's advice in an earlier post) he recommends to do the first layer of planking before cutting the Rabbet, that way you can see exactly where it goes, and before attaching the Keel sections to make sanding this first layer easier.
Have I picked you up right, or have I shoot off down a wrong turning? :)
Actually on re reading your post I think I did take that 'wrong turning' and am now driving in the opposite direction :)
Eamonn
Edit.. Would I be a pain to ask if you have any pictures?
Edited by egkb
Share this post
Link to post
Ok Then, all Bulkheads in place and glue is setting as we speak.  That last one was a bit of a faf.. (No. 11, it isn't supported like the others but perches on the end of the keel former) I didn't use wood glue on this one but an 2 part epoxy, for extra security.
Don't have any photos as that last B/Head is being held in place by a system of elastic bands, a clamp AND a Tape Measure (don't ask :) )  Will Post some tomorrow though!
Next up the Filler Blocks at the Bow & Stern, most likely will put small blocks in place between all other Bulk Heads to keep things rigid as I finish bevelling.
All The Best
Eamonn
Edited by egkb
Share this post
Link to post
Thanks J.. I was just over at your Build a moment ago :)
Eamonn
Did I mention that I love the Emma, I'm not sure if I did... ahem ahem :P
Share this post
Link to post
Just some photos of the latest additions (to go with my Post No. 32 above).. All the Bulkheads are glued in position, the deck is only 'dry-fitted' to assist in aligning the B/Heads.
In the Stern on shot, you may just be able to make out the 'thinning' of the Keel where the Stern Post will go to assist later planking (it is the beginnings of the Rabbet) but following great advice I haven't extended the Rabbet forward, this won't be done until 2nd planking (Thanks again to all those who are helping me along, it is much appreciated!)
Sláinte,
Eamonn
Edited by egkb
Share this post
Link to post
Thanks Nigel & Wayne, Yea!, so far so good.. famous last words eh! right up there with General Sedgwick commenting on his men ducking for cover.. "They couldn't hit an elephant at this dist..."   (oft mis quoted I know but, sounds soooo much better ^_^ )
Take Care Guys,
Eamonn
Share this post
Link to post
Hi Eamonn
That grove that I was telling you about on the bow stem to receive the hull planking. I did not have a picture of my own so I borrowed this one from a scratch schooner builder, it show just what I was trying to tell you,    Enjoy.
Regards   Lawrence
This picture is amazing, not only because it is a beautiful boat being hand-built, but it is... in the person's kitchen!  I sense a very, very dedicated and tolerant partner lurking somewhere out of frame!
cheers
--cb
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
