Greetings,
I'm currently building BlueJackets 80' ELCO PT Boat and I'm getting close to the point where I'll have to decide how to paint the hull.  I was wonderng if anyone had strong feelings for Model Master Enamle over Acrylic or vice versa.  I ordered the standard gray paint kit rather than the Pacific Green, I assumed I would get Acrylic paint, instead they provided Enamle. :mellow:
Thank,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Good question. I like you will be waiting to see what people say. I know Chuck has a lot of experience with different types of paint maybe he will be of some help with this question.
Wacko
Joe :D
Go MSW :) :)
Count me in on being interested in a education for this subject. I used Testors and Model Master enamel for my first build. I disliked having to use solvents to clean up so I'm trying water based acrylics for my current build.
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
George W Washburn - 1890 Tugboat
Future Builds
18th Century Longboat by MS
HM Cutter Cheerful
Wappen Von Hamburg by Corel
If your not making mistakes, your not challenging yourself – my life has been full of challenges :)
Same as Larry. Mostly I am using acrylic paint, because it's (for me) much easier to clean up (and breathe, mainly when using an airbrush). Only problems seems to me with metal colours like copper, gold etc. Now I'm sitting here and listening to other experiences :-)
Ok, you guys have me leaning in the direction of Acrylic paint.  Now my next question is, should I use a sanding sealer on the wood before I add the primer coat?  :mellow:
Tim
Tim
Future Build:
Completed Builds:
Member:
I have been doing models for years (not wood mind you , very new to that) but plastics etc.  In my opinion, acrylics are the best bang for the buck.
Enamels have the  benefit of drying quite hard.  However, drying time tends to be longer, just by their nature they tend to have a powerful odor, and clean up can be a pain and cost money as you need special cleaning agents to properly clean your brushes - which in turn has a pretty strong odor.   They do thin well, and do airbrush well however...
Acrylics are much more user friendly.   They have a much quicker drying/curing time,  they higher quality paints tend to self level quite well (Model Master Acryls,  Polly-S, Humbrol to name a few) and they can clean up with soap and water.   They also airbursh equally well and can be thinned with water (although not the best) or alcohol, windex etc.  They also tend to be more resistant to orange peeling.   A drawback however is that because they do dry fast you want to be careful about working the paint to much;  a few strokes is usuall all you need, too much and it will begin drying and clumping.   You will in most cases want to seal acryclis when done with some kind of finish,  but in most cases that is good practice regardless of enamel, stain or acrylics.
Cost wise I think they tend to be comperable so no real benefit there.   Back in the day you had much more selection in enamels over acrylics, especially with metallics;  however advancements over the years in acrylics really have produced some very nice metallic formulas.
Blending paints,  acrylics blend very well even across brands.   Enamels sometimes can have some issues mixing brands depending on the carrier/base they use.    Also if you mix types,  make sure you don't put enamels over acrylics unless the acrylic is completely dry and even then don't work it to much - you run the risk of lifting the acrylic with the enamel.
Hope that helps a bit;  again just my opinion but over the years I have really moved towards acrylics and really havn't looked back :)   They just are much more versatile and friendly and don't smell anywhere near as bad :P
Enjoy!!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Thanks Adam, your input is very helpful.
In respect to Tim's question on sealer and primer, what do you suggest? On my first and only build, I only used primer on metal and the resin hull. Should I prime all bare wood?
I used wood sealer on a few parts where I wanted the pores filled to get a very smooth surface. Is this the right application for sealer??
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
Future Builds
HM Cutter Cheerful
I remember the good old days using Humbrol paints on my plastic models. It used to cover brilliantly, even dark colours would cover easily in one coat. Nowadays there is no lead in paint so its very watery compared to the old paint with lead. Its a three coat finish to get decent coverage. I think acrylic is the way to go these days.
Yes, in the "good all days" I also used Humbrol Enamel, they were much better than all enamel colors I can now buy here in Germany. Don't know what happened. And so my decision to go for acrylic colors was an easy one.
As to a question above. Sometimes I do a clear coat on wood before using the colors, mainly when drawing straigt lines like waterlines etc. because it lessens the chance of leaking the color. Don't use too much color on wood, the structure should not be overcoated by colore.
I used to use Floquil years ago.  But now I use acrylics.  I like the easy clean up.  As for airbushing just remember that acrylics dry very fast and will clog your aribrush if you do not clean it every now and then as you use it.
David B
Edited by dgbot
I have used sanding sealer before painting and it works out very well.  Believe it or not, I found a sanding sealer at Michaels that works well.  Have also used a primer before painting metal fittings and this worked out fairly well.  Just my two cents.  Also agree with the above comments recommending acrylic paints.
Dave :) :)
Acrylics for the airbrush and enamels for brushing. Acrylics tend to set too fast, particularly when you have to paint around 'obstacles' etc. Everything has to be fine after the first few brush-strokes, otherwise the acrylics start to set and you get streaks.
Most acrilicss need an appropiate base coat for coverage and bring out the color better.
For bronze and gold I use a brown  base color. For steel, iron and silver a black base color.
Thanks for the info there are plenty of Michaels around Chicago.
David B
Edited by dgbot
I have good results with acrylic. But for some reason red does not cover well at all and I find that I have to use more than the usual two coats.  I have experienced this with various brands.
Henry
Laissez le bon temps rouler !
  • 2 months later...
David B
When using airbrush and acrylics how do u thin them and what is the ratio
Ahoy Mates :D
I prefer enamels for these reasons
Better coverage: Less coats mean more detail. Not as important if you airbrush, very important if you hand brush. The paint flows better too.
Better durability: I tend to handle these parts more then when doing plastics. With water based paints a clear coat is required to protect the finish and when brush painting it results in another heavy coat softening more detail. Enamels do not require a clear coat.
Better color: This might just be me but I find enamel has a much richer color.
Don’t get me wrong, I use Acrylics whenever possible. Painting bare wood, doing effects over enamels just to name a few but if you are only looking to own one type, I would recommend enamel.
Used properly the fumes are very minimal. If the project is big then they can be an issue and proper steps should be taken.
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
I use acrylics almost exclusively. They are easy to clean up. I get mine from Hobby Lobby. They sell a vast variety of artist's acrylics in tubes for 50 cents or so. They last forever. I thin and/or mix them as needed. I put on very thin coats and build them up, sanding in between as needed. You can get as deep a color as you like.
Good paint work takes time and cannot be rushed. The more care you take in the beginning, the better it looks in the end.
Russ
Ahoy Russ
Do you use these on the metal parts too
I have been experimenting with the "Winsor & Newton" Water mixable oil paint to color wood with very good results. .
  J.Pett
I try to avoid painting metal. I usually chemically tone metal. However, I know that you can use primers on metal parts, but this also adds to the build up of paint that hide details. Chemical toners will not hide any details.
Bluejacket Shipcrafters sells Brass Brown and Brass Black toners and both of them work very well. They also sell a product to tone Britannia metal pieces.
I have heard great things about Winsor & Newton. I think Chuck might use that product on his models. The main thing to look at is to get some paint that is finely ground. That makes for a better paint job at scale.
Russ
Edited by russ
    A little up front disclosure:  Me and paint don't get along real well.  I prefer to use natural wood and only paint when I have to.  I have experimented with (and used almost exclusively on my SULTANA) India ink.  I have also used colored wood dyes.
    That having been said, I like acrylic because it allows (in my experience) more color variations.  By using the artist acrylics thinned with water you can get more earth tones and toned down colors rather than the very bright colors you get with many enamels.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Popeye,
    Try Badger paints.  Used normally for airbrushing, they can also be brushed on.  I found the reds cover quite well.  I originally got mine online...getting several colors of red since I didn't know if I could trust the color chart.  (I have subsequently opted for caboose red.  Santa Fe red isn't bad either.)  Recently, I found our local model train store carries it as well.  :-)
Chuck Seiler
Have to say I never quite get the finish I want with enamel, unless it's 3 or more coats. Mostly I have now got acrylic, just as Thom said " easy to clean up"
Regards, Scott
Completed builds:
Awaiting construction:
Thanks Chuck.  I'll look into Badger paints.  I'm currently painting the interior bulwarks of my Soliel Royal.  I have three coats on it now and it's nowhere near covering the blue plastic they are molded from.  The red paint seems to go on like a wash, unlike any other color I have used.
Henry
What red do you use ? Some reds are made up from dyes, rather than pigments. So whatever you do, they are more washes than solid coats of paint. This is not a question of manufacturer or enamel vs. acrylic, but a question of the ingredients used.
I am currently using Testor's  Model Master acrylic #4630 Red.  I have also tried Model Expo's #MS 4802-B Gun Red.  It goes on a bit thicker but still has poor coverage.
Henry
I'm on the third coat now and the blue molded plastic is still showing through.  Multiple coats are not really a problem because there is no surface detail to hide, but it's just a pain in the a## to have to paint so many coats.
Henry
Henry:
It has been quite a while since I painted plastic, so I am not sure what the issue might be. If the paint is thick enough, it ought to cover better than that. I have had good results using thin coats on wood and that is why I asked the question. Good luck with it. I hope you can get better results.
Russ
