Fascinating work, indeed
Do you allow me to share on FB your photos with shipmodeller group I am member ?
Nenad,
as Long as there is no commercial use gained out of it, I have no objections with you passing photos on to your modeller freinds.
Nils
Current builds
-Lightship Elbe 1
Completed
MAN>>>>>>>>>I love how you do that....never get tired of seeing it!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
thats very encouraging to get such nice comment....
Nils
Current builds
-Lightship Elbe 1
Completed
Bad spelling I meant to say create.
David B
David,
the plating I do (cut equal pieces)from a 100mm wide coil of 0,125mm thick alu-tape (self adhesive). The glue side is protected by a film that is pulled off from the rear side, just before the cut in shape and ponced plates are put in Position.
The single plates are layed on a rubber plate with the shiny side down and then ponced from the rear side (without removing the glue protection film ) by using a handle with an spanned in toothwheel made of an old mantel clockwork. It depends on the width of the toothwheel how many toothrows can be arranged next to one another on the individual toothwheel ( 1 row riviting.... up to 3 row riviting, etc.)
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Build log part 13
Time to get primer and paint started...
dull White resin based primer is brushed on
the rudder has been plated as well, but the prop is too small in diam.
found this one at a web-shop, and modified it a bit, cut off the eye and drill a M3 thread into the hub
figure is 1:87 (H0) scale)
here and the next pics the White Portion is only primered
Build log part 14 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 14
Starting to do parts of the masts
plattforms for the lower tops (multifold soldering Piece)
These will be slipped on to the mast and later secured in Position by a pin
handrails at rearside of plattforms
chocolate Brown Color at poop and forecastle upper portions
anchorchain portholes mounted
other porthole openings drilled but no inserts yet
White paint on...
Build log part 15 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 15
togallant platforms
Connection to cap and spars (on the two mainmasts)
alignment checks before soldering parts together
the lower top is moved to the correct Position, then secured with a pin to the mast
Mast rail shoe that goes to the appropriate yardrack
set of uncompleted masts and jib boom
some paint touch ups done, now ready for inserting portholes (bulls eyes)
Build log part 16 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
great masting!   you enjoy making them from brass......is there  an advantage to it?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
when I started using brass I took the following Advantages out of it...
- tapering done by staggering appr. tube diam. (no endless taper-sanding etc.)
- soldering provides stronger joining than wooden equivelant
- to my experience with the rigging it is quicker than with Wooden parts
- as I am using wire chord for the static rig, I can set shrouds, stays backstays, etc. well stiff without distorting the masts, when stays and backstays-stresses are equally balanced
- a disadvantage would be the weight compared with wood, but that is not relevant for a stand model that is put on a stabil stand. I pay much Attention for securing the standbolts (removable but safely) to the model
Nils
Current builds
-Lightship Elbe 1
Completed
As always your work is beautiful.  One day I hope to build in brass like that.
Bob
Current build:  SS_ Mariefred
Bob
Thank you Bob
I would`nt dare modeling my HMS Pegasus or any other 18th century ship with brass masts and -Yards....
Nils
Current builds
-Lightship Elbe 1
Completed
I agree.  Most of the boats I build need to be wood.  But there are times for brass, and metal ships need brass.  My HOGA would have been much better in brass.
Bob
sounds logical........I can also agree that there is a time line for when a metal mast could be used.   adds so much to the build as far as detail goes........much smoother finish too  :)     thanks for giving us the finer points! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Build log part 16
roller for Yard hoisting / lowering chain (in mid mast)
bulls eyes inserted
checking mast angles and alignment
Fitting for taking up the chainplate (anchoring for the lower top shrouds)
top spars with access- ladder and devices for antenna and nav light attachments
belaying Points in deck area
Build log part 17 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 17
getting all the eyelets soldered on
stations for hight-fixed and vertical-moveable yards
underside of topgallant platform
masttop and slide rail for royal-yard
underside of lower top platform
Radar Station protection Cage on foremast
fog horn within protection as well
Build log part 18 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 18
foremast
one of the two main lower Yards with twinjackstays attached
Yard mounted to its place
Stern decoration with nameplate, and hometown badge (Kiel)
Build log part 19 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
David,
the masts,yards gaff booms, and jib boom after cleaning and primering are painted with water soluble acrylic Basis paint (Color RAL 1017 Safran yellow), the parts get White tipped Ends
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, your metal work is simply superb (as is all of your other work). Thank you for posting logs of your completed models.
It's a whole new experience to see a ship model grow at such a fast pace. Maybe I should also publish my build log only after my Cutty Sark model is ready. On the other hand, you then would have to wait till 2020 (or beyond) and not everyone might still be around then. After all, I started researching her in the nineteen fifties...
Lou
Lou,
fortunately having a digital camera at Hand for some years already, it was possible to document the building sequences for three ships one by one, and this long before I knew of this MSW Forum. Now I am very happy to share my experience with others, before the pics lay idle in the files "drawers" of my PC.
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 19
scetche for rigging mainmast
and for foremast
scetch for Yard (one of many)
impressions for masts and Yards after painting
Build log part 20 to follow....
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 20
scetch for Yard / block tackle at mast
preparing for soldering jackstays to the lower yard
on the next model I would`nt do the footrope (horses) holders this way, They would touch the yard tangentialy from the Yard aft side, and be attached to the second jackstay row
checking the Yard swiviling capability
the geometry of the yardracks must allow a Close as possible Position of the leeward yardend to the shrouds when full braced
startig jib boom tackle and safety netting
the solid bobstays are from brass wire
the Albatros figurehead is attached removable
Build log part 21 to follow...
Nils
Current builds
-Lightship Elbe 1
Completed
build log part 21
variety of Yards in different completion stages
view skywards
jib boom rigging done
without figurehead
Albatros at its place
side hull bumpkins for bracing tackle
bulwark bolts to be cut and nuts and washers to be painted white
Build log part 22 to follow.....
Nils
Current builds
-Lightship Elbe 1
Completed
Ed and David,
Thanks to both of you for your comments
Nils
Current builds
-Lightship Elbe 1
Completed
thank you John,
Nils
Current builds
-Lightship Elbe 1
Completed
