To Whom it May Concern, Greetins
Chuck Passaro mentions in his Planking Tutorail - Lining of a Hull using 3" see-through low-tack scotch tape which he can write on.
Has any body  out there a more precise article desciption, number or anything that would help me, to order such tape in Germany, Europe or the US???
Greetings from Hamburg and the river Elbe
Peter
building: 3-masted schooner HEINRICH from 1907 (on hold)
on the drawing board: 3-masted top-sail schooner M.A.James
If you have an office supply store near by check out the packing tape supplies to get anything bigger than 1 inch; there are some low tack - not so sticky packing tape that pulls off very easily or look around in the painters area of the hardware store.
Current project: Retired
www.howefamily.com
I used 3/4" wide regular scotch tape and it worked fine, just use the dull finish type, not the glossy. If you need wider tape, you can always ues two or more strips overlapping and get a wider surface.
Ken
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
I just use regular packaging tape.  Its slick but a pencil will write on it if you use the edge of the lead.  I have also used a grease pencil and a sharpie.
Chuck
Thanks a lot, folks,
this will set me up for investigations.
Peter
  • 7 months later...
