Hi all. Some more photos as progress continues The first few show the hull with the deck template over the hull. This is important because it gives me a good idea of where the internal bulkheads for the cabins, etc will lie.
The next few photos show the hull after I "painted" it with a black permanent marker. The reason I did this was so that the high spots and hollows can be easily identified as the hull is fine- sanded. I've also started to plot the correct shape and position (although not shown in the photos) of the internal deck(or floor). Getting this correct, is of course, fundamental, because it determines the height of the accommodation bulkheads, etc.
Hope you enjoy the photos.
Hi Omega1234, your build is comming together nicely. There is just somthing about those Herreshoff boats
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Hi everyone. Well, progress continues; albeit slowly!
I've started on the internal floors of the cabins/accommodation. The floors are individually planked and once sanded, they should look a treat! I then started marking the locations of the bulkheads, furniture, etc on the hull and the floors.
I also started to build the deck using a jig with the correct deck camber. The deck's fully planked on one side, whilst partially unplanked on the other side. This is done deliberately to allow the internal accommodation to be viewed. Both the deck and the floors are individually planked using strips of birch and wattyl respectively.
Admittedly, there's still a lot of finishing to get a good fit between the hull and deck, etc, but, that's all part of the fun of building, isn't it?
The hull has also been puttied and sanded, but I won't paint it until all the rough stuff is done. There's no point doing it now, only to find that I've accidentally damaged the paint during the building phase.
Edited by Omega1234
She is looking good , nice work on the deck
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi everyone! Back again. Progress has been slow, but, I've started on the internal bulheads. This is the part that I really love, because I always see it as a real challenge to try to fit in as much detail as possible, yet being mindful of how small everything will be. Nonetheless, that's the fun of it, isn't it?
Pictured below are the bulkheads, with their panelling and doorways cut out ( in readiness for the doors). Some photos show the bulkheads temporaily sitting in their respective pats of the hull. This gives you some indication of how it's all coming together.
Pls bear in mind that some of the bulkheads such those of the galley and crews quarters will be painted white; whilst the staterooms and grand saloon will be done in wood, reminiscent of the rich panelling and decor of a luxurious mega yacht of its day.
The deck has also been nearly completed. It now features the diagonal bracing which Hereshoff would have designed to give the steel hull additional strength.
By the way, there's still a lot of cleaning up and finessing to be done, especially to the underside of the deck which look a bit rough at this stage. All in good time, though.
I hope you enjoy the progress so far!
The bulkheads,and diagonal bracing look great nice detail work, she is comming together nicely
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Where did you find the gnomes and elves you hired to build at that scale?  They are doing a great job.  If I were you I'd keep them around.
Bob
Edited by Cap'n'Bob
Current build:  SS_ Mariefred
Hi everyone. Many thanks for all your likes and comments. I especially like the gnomes and elves. I wish they could give me the winning Lotto numbers as well!! Oh well.
Pete48 - I noticed that you have a link to the Herreshoff Society. I accessed the link but wasn't able to find a lot of info or photos about the Ingomar on it. Would you know what other links or resources I could try?
Edited by Omega1234
Hi Omega, The other resource I use is the Mystic Seaport museum here is the link : www.mysticseaport.org/  I also found this link wich may be helpfull : www.ingomar.info/  I hope that helps
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hi all. The original deck was really looking sub-standard and was really getting me down! The more I did to it to fix it, the worse it got. So, I ditched it overboard and built a new one; this time, I left even more of the deck exposed for the internals to be seen.
Hope you enjoy the photos. The first photo has the old deck next to it (destined for the scrap wood pile). The other photos show the bulkeads glued in place, in readiness for the cabins, etc to be built around them.
Hello Omega,
that is a very impressive build, I love that sight into the open structure and deck and all in scale 1/192, I never thought that this would be possible in that way...
Well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks Nils. The challenge at this scale is to try to fit everything in at such a small scale. Sadly, the reality is sometimes that wood can cut only be cut so thin, before it splits, or becomes unworkable. Thus, some of the panelling and the deck beams are probably slightly over scale. Nonetheless, at this scale, I'm satisfied that it looks the part. I only wish I had the skills of Phil Reed, Llyod McCaffrey or Donald McNarry...those guys always make working at this scale easy!!!!
Hi dgbot. The bulkheads and panelling are Australian Jarrah. This is a lovely red hardwood, which polishes/varnishes beautifully. It's very durable, but, ironically when cut into tiny sub-millimeter strips of veneer, it has a tendency to splinter and/or shatter. The planking of the internal floors is an Australian wattyl, which is far easier to work with. It has a beautiful colour and warmth to it and sands easily. The deck planking is birch, which is also easier to cut into tiny strips. It varnishes really nicely and has a warmth to it that's similar to lime wood.
Someone in an earlier post suggested that I get some holly. I'm still trying to source some, but hopefully I'll be able to get some...maybe in time for my next model.
If you have any other suggestions for wood that can be used at this tiny scale, then, I'd love to hear from you or anyone else! Any thoughts, anyone?
Edited by Omega1234
Boxwood has always been a good choice. A couple of others are holly, apple, pear, and degame. These are used by modelers I know who build at 1/192 or smaller. They all have a very tight grain and have the strength.
David B
Nice work Omega, the new deck looks great.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
