Ahoy MSW
Thank you. Your posts have been most helpful :)
I always wanted to do treenails but they were just too much work. I was trying to manually push the wood through the drawplate. Working down to the needed size. Kick me, I follow instructions. I gave up after I did the math, 50 hours just to make the treenails for my build.
After reading your tips I took a toothpick, stuck in in my dremel (I have the flex shaft), pushed it into the drawplate and can now make them in seconds.  :P
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Tony
i am sure Garward will answer but i think after yuo drilled as many nails as you can you just cut off the top of the wood at the depth you drilled too then they wil automaticaly come out or you push them out leaving the piece of wood will all th holes in it :)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Thanks, Adrieke. Sounds reasonable!
Tony
Aaaah! Missed it! Thanks for pointing that out!
Tony
Dear colleagues, thanks for an assessment of information and discussion. I am always ready to answer your questions on the given technologies of imitation of nails of a deck flooring. As far as I know, besides given here exists also other technologies, it would be interesting to look at them and to discuss.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Very interesting thread, Ive read through it several time.
Garward, On the syringe needles, do you know what gauge needle is used for the treenails? I have some 19g that Tammy gets from the OR which look like they might work.
Many needles can be suitable for these purposes, usually the needle is selected experimentally, depending on diameter of an imitated stopper.
Best regards,
Garward
I reckon you guys are missing the fun of drawing bamboo through a drawplate.  Its quite satisfying making treenails that way.
To whom that is pleasant!  :D
Best regards,
Garward
First, thanks for sharing the information.
I have purchased and sharpened a couple of 18 ga needles and placed them in my drill press.  Unfortunately, the nails always break off inside the needle.  There, they turn to dust and are not useful.
I tried pine and maple woods, end grain and side grain.
Is there some special wood I should use or do I need to use a high speed drill?
спасибо
(Thank you)
спасибо
(Thank you)
For production of nails it is desirable to use the same wood of which the deck flooring is made.  It is possible to try soft wood a linden.  As for the boring machine, here it is necessary to pick up correctly turns, usually it becomes experimentally, taking into account a type of wood and type needles.
Best regards,
Garward
My method of making  treenail
pushpin to be installed in the machine chuck
installation of the workpiece
Edited by PSF
Попков Сергей Федорович
brass treenail
apparatus for setting a brass treenail
Great results.  Is that a regular die (like you use to thread metal) that you've chucked in the lathe or is it something special?
Hi, my first post. I have completed a number of builds over the years but only recently attempted treenailing. My method was as follows:
Take a cotterpin/splitpin about 40mm long. File the top of the pin so it is a flat surface. Drill an appropriate sized hole in the flattened surface. I have a Proxxon Drill press and have used 0.5, 0.8 and 1.0mm bits. Mount the cotter pin in a Dremel Multitool and then mount the dremel onto the workbench so the cotter pin faces upwards. I use bamboo skewers as my treenails. I split them longways into four sections and roughly sharpen the end so it can be guided into the hole that I have drilled in the end of the cotter pin. Switching the Dremel to a relativey high speed allows  the bamboo to be forced through the hole and the appropriately sized treenail is extruded through the bottom - each treenail is about 0.5 - 0.8mm long (but long enough to do the job). The hole in the cotter pin usually stays sharp enough to get a hundred or so treenails cut. I'm going to experiment using a stainless cotterpin next time as this may have a longer lifespan.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
These photos probably aren't in the right order (bit of a techno-cretin) Hope they give the general idea
Since I posted this, I have invested in a Byrnes Draw Plate. One of my best investments yet. Beats all other methods of making tree nails hands down (in my humble opinion)
Edited by hornet
Hornet
I drill or punch the holes. Cut a bunch of round toothpicks in half. Wet a half toothpick in wood glue. Insert in hole. Wait to dry overnight. Trim tooth picks with toenail clipper. Sand. Very simple ;)
(Instead of that dental pick, I now use a jig made with 4 nails in a piece of wood, to make 4 equally spaced holes at a time )
Edited by Ulises Victoria
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Looks real nice! I must experiment on this as I have never done this on any previous builds. Thanks for the detailed pictures
Regards, Scott
Completed builds:
Awaiting construction:
  • 1 year later...
Like vths, I find regular toothpicks to be great tree nails. I actually get 4 nails from each toothpick by using a small file and sanding board to create the sharp pointed spike needed to get a deep enough penetration to insure the nail doesn't back out during the sanding process. No glue necessary....each nail is pressure fitted, as the wipe on poly finish applied to the hull will seal the nails permanently.
I also wait until after I sand the nail flush before applying a stain.
Dave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
