Then it was the turn of the upper deadeyes and chains.
This time the deadeyes are all the same and the chain lengths, so added the deadeyes to the fret till needed.
Having Dafis hints and tips is a great help, this I downloaded from his site.
With it you cannot go wrong and having the relevant books makes this much easier.
After removing the poop/quarter decks I found one or two problems will also ad some more plastic strip to the hull sides.
Think I have the right planking this time.
Also note the rope at the stern end, this is the rudder/tiller ropes that will pass up through to the ships wheel.
Frank :piratebo5:
Thank you  Lawrence .
Having near all the relevant parts and being retired allows me to do a little each day. plus this site has so much information even if its a wood build, the Victory is still the same ship in configuration.
Plus I have the Victory model site by Pete Colman which is crammed with Victory detail. this and all the wonder full books out on this subject.
How can I go wrong one asks, only in my skill as a modeller.
These aids are there but its the modeller who determines how his model turns out.
I am really enjoying this build for all the above reasons.
I also like looking at others to get some idea for my own build, and there are so many very nice works of art here, you could spend all day/night browsing.
Take your build for instance, makes me want to start my wood ship. :rolleyes:
Having built many ships with out sails, its a challenge indeed on one with sails.
Regards Frank. :piratebo5:
On again with the thickening the upper deck sides.
Will add strips of plastic, then wood strips, this should give the correct thickness to the hull sides and allow the eyelets to grip for securing the guns.
Also testing out the boom on the mizzen mast.
Plus the making sure the masts sit right.
Foxy :piratebo5:
Following on from yesterday, today I finished the plastic strip on the hull, next when dry will ad the wood strip.
Also started the Admirals quarters.
Then it was a test of the bowsprit, this needed no assistance to stand on its own with out fixing.
All though I had weights in case.
Next it was Dafis resin Anchors there are six for this ship and have primed ready to spray black when all dry.
Cheers Frank :piratebo5:
Another update 0n the progress of Anchors, Knights head and belaying pins and racks/rails.
Added brass belaying pins as they will be used later.
Just waiting on a few more which arrived today.
Frank :piratebo5:
Edited by foxy
Hi David.
The smaller bottles are Life Color and the taller are Admiral paints, both very good.
Easy to spray or use brush I find.
Cheers Frank. :piratebo5:
Edited by foxy
That's a tricky question.
You have to shake well and I add with a syphon one water to one from the pot.
But all depends on how much paint you need for the job.
smaller half and so on.
I like to put on thin and do more once dry, find this not only dries quicker but coats on better without blobbing. That is running into bobs of wet paint.
Some like to do it in a milky way, but find it clogs up easy on the gun, this paint dry's very quickly.
Trial and error, I do first on a bit of waste to check its ok.
In between I flush through gun with water, Iwata's  is what I use. one with top lever and other with trigger. Top lever for fine and trigger for overall spraying.
As I say its trial and error, but once you get the hang of it then your home and dry.
Frank. :piratebo5:
Edited by foxy
:Moved on a touch more with the 12 Pdr cannon.
Added most items to these, there are 40 12 Pdr long and short for the upper/quarter decks.
Next job was to add dafis trunnion caps, these have to be folded, so used a primitive jig for this.
Finished the Anchors.
Plus finished one side of the inner hull with wood.
Next it will be the hanging Knees.
Looking for some red boxes that adorn the ship and found some old AirFix ones.
Plus some Cannon ball clusters.
Then added the rest of Dafis etch King George motives.
A handy little tray for keeping all them titchy parts.
Foxy :piratebo5:
Edited by foxy
Thanks Keith shipmate.
Yep she is moving along nicely now.
Have noticed however from the real ship that the belaying pins might be a tad short.
hammocknetsgunportstrbrd1_zpsopbhiegz.jp
But can live with that.
Although I believe the ones shown in the picture are from a merchant sailing ship.
Here's the tackle for the 12 Pdr guns and how they need to look.
I think hemp rope will do the trick for these.
One more picture to capture the ships wheel(done),the Binnacle(done)and the red boxes strewn about the decks.
Plus must make up some lamps to hang from the rafters.
The fire extinguisher is a modern addition.
foxy :piratebo5:
Edited by foxy
Well been at it again, this time finished the wood inside and now working on the Admirals quarters.
Most know the layout for this end on the Victory.
But will be panelling the sides and paint very light green.
For the stern I will be panelling mahogany and a seat the length of the stern windows.
One important point is if your detailing the interior then leave off doing the gun hatch's till later.
The damage is superficial and can be sorted later.
Also adding carpets to the floor, that black and white pattern is very bad on the eye's!!!!!.
Next its the hanging kness of which I need 64 for the upper/forecastle and more for the Captains quarters.
Done 88 so far.
foxy :piratebo5:
Edited by foxy
Still onto the Admirals quarters with the panelling in sleeping, dining and day room.
Making the panels from plastic card and wood.
Two layers to get panel effect.
Hats off on this deck.
Will paint light green and brass decoration.
Made up two of the three sections, with the dinning to do.
Frank :piratebo5:
Well moved on and finished panels to the sides, now working on the inside panels.
Bit like a jigsaw puzzle.
Once all done can fit together.
Also started the rear window display, first the back bench that runs along windows.
Shown in a diff light.
Surprising how the light makes it look.
The beams etc will all be this colour with brass decoration. red curtains.
Frank. :piratebo5:
Thanks Keith mate.
Yep thinking that to a while back.
But had another  bit of advice.
That is to have pictures of the interior and show beside ship model, so folks can see what has been built inside.
I have the complete build saved on separate external hard drive .
Can make smaller and an A4 can show one deck, so two A4s should be enuff.
Have not decided yet on the lighting!!!!.
Frank :piratebo5:
Hi John.
Thanks for the praise. First light grey, let dry and then admiralty  black paint. once dry a coat of Klear/varnish to give a shine and protect the surface.
Let the grey show through and just use a swipe of black.
Also the light helps to give the impression.
If I took the picture from another angle it would look different.
All this will be covered later, but will have pictures to prove its there.
Glad you like it. :)
Frank :piratebo5:
Well its the quarter decks turn and had a lot of thought on what I was going to do to this, having to alter the main mast opening by half a mm,  planking this deck with 2 mm wood strips, I decided to removed all raised detail and plank, then use evergreen to make new hatch's etc.
The way it is at the moment.
Sanding down with a sanding block.
The decks all cleared ready for planking.
Frank :piratebo5:
Edited by foxy
Well done, love the spirit!
XXXDAn
Yep was a tedious job Daniel, but got there.
Another tedious job was the ropes for the guns, added etch eyelets to one end.
Would you believe there are 40 here done.
Guns strung with rope and coming on nicely, still to add block and tackle to each gun.
Most of these made up.
Frank :piratebo5:
