that is the question? given they don't really stand out too much on the real article i'm
wondering why i should bother? i know it seems most "hot" builds here go with the
pronounced deck treenail configuration but in reality they are almost invisible. so: to treenail
or not to treenail? that is the question.
there's no real answer to this one, I think this way. Take a 1" diameter treenail, reduce it to 1/64", (a common model shipbuilding scale) & then ask yourself  "Is it really worth it"? The other side of the coin is that some models look spectacular with a treenailed deck , or hull. It's all down to personal taste really. Hope that helps, a bit!
g'day brian,
                   are you the member building the trumpeter bismark? i noticed that float a boat had this kit in stock when i visited.
price i think was 330 odd. question for you: how much for the upgrade kit to this plastic model? as an ex pusser would love to
tackle her but only if i can get wooden decks, authentic blast bags etc etc.
cheers chris
ok sorry. was just blown away by the size of the box. and yes i now know your bismark is a wooden kit (envious).
you are doing a superb job on her. congratulations. funny how a ship our nation so reviled when she was afloat
has now become one of the most admired ships in modern history!
cheers chris
One can treenail a model subtly. It depends on the diameter of the material used and the specie. However, at any scale below 1:48 it would be very difficult to carry out subtly enough!
That's the way I do it Joe.  Except I use a small drill bit (perhaps a #75 on a 1:64) to insure consistency of the holes.  Yes, it needs to be very subtle below 1:48 scale.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
I'm sure I read somewhere that Chuck described this method? I intend to try it on some scrap before committing it to my next model. Endeavour hopefully!!
You 'nailed it' Geoff.  Time spent making samples before committing to a full deck or hull is well spent.
Augie
Previous Builds :
One thing I've learned from hours of studying the builds on this site is that there is a right way and a wrong way to do treenails. Not so much in the technique used, dowel or filler, but in placement. The pattern, size and consistency, seems to define the aesthetic success of the application.
Warm regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
Ahoy Mates :D
I am a big fan of the treenail (who would have thought)
 Just like many of the other "slightly out of scale items"  we joyfully add to our builds; treenails represent an important aspect of the actual construction of these ships, add interest to your build and look great. If your abilities are up to the task you should always consider including some
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
I agree with Joe and Geoff as far as the way to do it.  As far as whether to do it I think Bill Hime is right--if you can't get it too look right don't bother.  No one will look at your deck and say "mmm no trenails" but they could well look at it and say "what a crummy job on the trenails."
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Treenails are not always invisible. I recently took a heap of photos of the Endeavour Replica which lives at the Australian Maritime Museum in Sydney. It is one of the most accurate maritime replicas in existence. The treenails were quite noticeable.
I did some calculations for the size of a treenail using the diameter of the actual treenail on this replica as a guide. In reality the treenails were about  34mm in diameter. Using the trusty modelscaler app on my phone this came out as about  0.5mm on a 1:64 scale model. This is visible. However, on a model any smaller than 1:64 I think it would be too difficult to make treenails small to be in scale and they would be practically invisible even if you managed it.
Due to the one size fits all attitude of mass production, another point worth considering, in my opinion, is that in some cases the actual deck planks provided with some kits are out of scale.
Edited by hornet
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Speaking of making very small diameter treenails you might want to consider using bamboo.  Bamboo can be draw down to very small diameter without breakage.  May not be worth the effort but it can be done.
My advice and comments are always worth what you paid for them.
Yes, bamboo is my favoured material as well, drawn through the Byrnes draw plate. I still think that beyond 1:64 it is probably not worth the effort.
The thread below also discusses tree nailing options. I detailed a small tool you can make to do the initial dividing of the bamboo before drawing it through a draw plate.. Saved me a lot of bamboo splinters - nasty little beggars!!!!
http://modelshipworld.com/index.php/topic/2959-treenail-detail-option/
Hornet
Ahoy Mates :D
I use a Dremel to push pretty much anything through my drawplate. If it fits in the chuck its a treenail in about 5 seconds.
  J.Pett
wow! didn't expect my innocent question to attract a 2 page response. and i'm still
tossing up whether to treenail bounty's deck or not. i'm using a 4 butt shift so i guess
it may enhance the pattern somewhat.
cheers chris
Brian, could you possibly post a pic of what your silver ash tree nails look like once fitted to a deck. I've not used this timber for tree nails before and would be very interested to know how it looks. You are right, bamboo is a bit of a pain but it gives a good strong treenail that is easy to insert and provides a nice contrast to most decking timber.
Hornet
Chris,
It's basically boiling down to: "It's your ship.  You are the Captain.  Do it your way".  Treenail seems to one of the more "emotional" topics around here with "yes", "no", "do it this way", "do it that way".   There really is no right or wrong way as far as method nor are they mandatory.
jeez brian;  just when i think a decision has been reached you hit me with this stunning pic!
well i will finish planking then post pics and see what the consensus is. great build by you
by the way.
cheers chris
Thanks for posting that pic Brian. BTW - great work. I can see the treenails. Will have to investigate further.
Steve (hornet)
Hornet
