A good start then mate - the buiding berth is becoming busier.  What technique are you uising to ensure the bulkheads are true upright and perpendicular to the spine?
cheers
Pat
not sure what is called bit its a metal rules 25 mm long with a device that you can slide and lock and meaasures 90 degrees and 45 degrees angles
i slid the ruler out to use it
also using angle brackets to keep it inline while glueing
last i use a digital calipers i measure at the false keel then lock it in
i use this to cut the dowels to the right length and then when they are dryfitted (clamped) i go round the whole outside of the bulkhead to make sure its all
the same
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Hi Adrieke, that's a big one you started. Will follow your built log. Have no intention to do her myself, the rigging is scaring me away :o
Good luck and have fun.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
yes Pat that is exactly the one. did you peek in on my workbench :P
yup John she certainly is a step up from the virginia :)
i am going to take it slow as i stil have plenty of work on the king and i want to finish her the best i can
tonight i added 3 more bulkheads .
1 more at the front and then i wil need to think on making some balsa filler blocks for the last ones
almost done just the front 3 parts (they are already glued together) and the back part.
i ran out of dowel . fortunately the angel brackets where just the right lenght to fit in between th eboulkheads to keep them straight and i will put some balsa blocks in between afterwards
not sure how i am going to glue that back bit on as it has nothing to glue against at the top
shot from above shows that everything looks square
Pat,
I've got to say this:  Check the square before using it.   I've had 3 of the darn things and not one of them was "square".
Hi Mark and David, I was simply showing a picture to confirm what Adrieke was trying to name :)  I agree, some of them are pretty bad, I tossed one and then took a small (certified) engineers square to the shop next time :).  I don't use these for squaring.  I have invested in several cheap engineer squares (Indian made) which I check against the precision one.  I have not found one of these not to true yet -  not all cheap stuff is clumsey or imprecise it seems :)
Someone has posted the following before, but I don't know if it has been caught-up yet?
A quick way to check if the square is true is to draw a baseline on your bench or a piece of paper.  Line up one edge of the square and draw a line down the other edge.  Flip the square horizontally, line up the base edge again and try to have the other edge align with the vertical line just drawn.  Draw another line down this edge and the two should be coincident if square; if it is not, then the degree of imprecision can be easily determined.  Another way is to use a hard straight edge as the baseline (make sure it does not move :))
A similar process can be used to determine if a straight edge is actually straight also.
Hope this helps?
cheers
Pat
Edited by BANYAN
after reading that i am glad i didnt rely on just the square but used the callipers to measure too
i glued in some filler blocks at the back.
when its dried it wil be sanding time again . yaaay ;)
Hi Adrieke,
When you are going to sand, are you using a tool or just a file?
I have bought a little sanding machine called a mouse and that works perfect.
i will use my rotary tool with sanding drum to get it to the rough shape then will use files and manualy sanding
A lesson I learned with using balsa for filler blocks is to ensure they are sealed when you have finished sanding them to shape; otherwise the planks will not stick to them.  I used a simple 50/50 PVA to water diluton and painted it on.
cheers
Pat
thanks Pat
i have seen people mentioning it before but good that you remind me again to make sure i dont forget to do that :)
hi Matthew thanks for looking in . not much progress on her as all  my time is spend on the kom.
i ll probably finish of the fairing of th ebulkheads when i am at the finishing stage (lots of railings to add) of the kom
Hi Adrieke,
Great, another Endeavour build to follow!
Looks like you are off to a flying start. How do you manage to do so many builds though :o
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
yup it felt good to be doign somethign again on her  Pat :)
hello captain slog . i have actualy not worked much on her for the last month as all my buidling time is taken up by the kom.
and the paper model is just for those times i cant get to my workshop :)
Adrieke,
Nice ship you started on. WIll keep your hands bussy, as will the unfinished one. I'll be popping by from time to time
Carl
thanks Wim and Carl.
i l be slowly working on her now . hopefuly get to stage of plankign by the time the kom is alomsot finished :)
almost made a big mistake. i decided to glue the rest of the decks on. during drying i had a check and noticed that the deck had a bit of a dip between 2 bulkheads. further investigation showed that the deck didnt even touch agisnt the false keel there. then it dawned on me that i actualy never finished fairing the top of the bulkheads. i gently tried lifting the decks off. all came off wiht no damage. just need to clean off the glue.
i should have checked.
Hi Adrieke and All,
I'm also building the Endeavour and have read your comments with much interest. This is my very first wooden model ship build and I should've read the part on the box that says something about modelling experience..... never mind. I have found many of the flaws that you have mentioned in your build and carried out similar actions to remedy the problems. I have learnt fairly quickly that as I progress through the photo instructions and move to the next stage, to look through the next several photo instructions to understand what the instructions mean and where confusion occurs, to research it. I purchased a wonderful copy of Ray Parkin's book "H.M. Bark Endeavour" and that has been invaluable as a reference source. I live in Melbourne (Australia) and have had the opportunity to visit the replica and take as many photos as possible when it visited. It's interesting to note the differences in the model against both the book and replica vessel. I picked up the problem of the hawser holes from another forum and resolved that by making a guide for the drill so that it angled the drill upwards by 15 degrees (back drilling from the bow to the deck) and the bottom of the holes were spot on level with the deck (if that helps). I'm up to photo 27 in the instructions and painting the stern as I don't like the 3 ply wood appreance or the metal appearance of the windows and stern decorations. Have a great day and good modelling,
Rowan D.
Edited by rowand
