Three-mast schooner ATLANTIC by IgorSky - FINISHED - 1/600 Scale - BOTTLE
It was actually the White waterline, that I was curious about. Is it painted, or is it a wooden plank that you bent around to meet nicely at the stern?
Hi Patrick,
No, it isn't painted and it isn't the curved wooden plank.I inserted a thin wooden plate between parts of the hull and also I processed everything together an emery paper.The top and lower parts of the hull didn't allow to grind off more than it is necessary.
Best Regards!
Igor.
Link to comment
Share on other sites
Link to comment
Igor, excellent work, I like it.
It's something different and interesting (for me).
I follow with curiosity. :)
Cheers, Matija.
Link to comment
The addition of the simulated frames on the bulwarks adds a really nice touch.
Hi Patrich,
I watched some photos to understand these elements are visible or not. On some of them they were hidden by a covering, on some are well visible. But I am going to establish a gunwale over boards and additional thrust blocks are necessary for me to paste them as thickness of boards is too small for this purpose.
Best Regards!
Igor.
Link to comment
Link to comment
Link to comment
Hi Igor
I really like the deckhouse that you've built. The rounded edges that you've put on the roof is a nice touch, as is the skylight you've also built. Well done on both scores.
As for the ship's boat, well she's a beauty! I guess if she's too big, you can always display her proudly elsewhere.
I look forward to seeing more.
All the best!
Patrick
Link to comment
Link to comment
Link to comment
The little boat is looking better than the big boat.  The little steering wheel is amazing.
Bob
Current build:  SS_ Mariefred
Link to comment
Igor,
You always surprise me, when I think that this limit, you skip it ...
your work is amazing.
Regards, Matija.
Link to comment
Small progress today.
For the boat I need to make a windshield.
I used for this purpose thin transparent plastic and a brass wire with a diameter of 0,15 mm.
Now I can establish a steering wheel and a windshield on the boat, to compare the new boat with old and to try to set it on the deck.
Link to comment
Link to comment
Railings...
I tried two options, possible for me, - from a thin wire and with application of photoetched details for models in scale 1:700. I think that on the model I will use the second option. But I think to add to photoetched details of the racks from a wire.
Link to comment
The little boat is lovely.  It's nice to have the bigger boat to practice on, I like the little one better.
Bob
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
