Everything posted by TBlack
Help with depicting extra line on bitts
TBlack replied to usedtosail's topic in Masting, rigging and sails
Gregory, They are bowlines, sheets and clews. Here is the plan view: Given this information, maybe Lester's solution is the best one -
Tom, So far there doesn’t seem to be an answer to the issue. I’m facing the same problem with my Sophie build which is an alteration of Speedy. Hope someone comes up with an answer. Tom -
Now I've served and rigged the lower main shrouds which will be all the progress for a while, as we are away for a week:
- 347 replies
- Sophie
- Vanguard Models
Isn’t it water soluble? At the very least you should be able to sand it off.
- 496 replies
- minesweeper
- Cape
I've tried, desperately, to include pictures of my progress. Not going to happen! Nevertheless, you'll have to take my word for it that I've installed the Jeer block/tye assembly, the truss pendants, futtock staves, catharpins, and finally the fore stays.. I've got a picture or two; they're just not very good, for what it's worth, here they are. Anyway, I'm on to installing the shrouds for the main mast.
- 347 replies
- Sophie
- Vanguard Models
Greetings from a clueless Patrick O'Brian fan
TBlack replied to Galkar's topic in New member Introductions
Galkar, Your interest in the HM Sophie hits a soft spot for me. I, too, am a fan of the O'Brian books, and, as it turns out, my youngest daughter is Sophie. So there was nothing for it but to build a model of the HM Sophie. As you have discerned, a good starting point is with the Speedy from Chris Watton (I have a very early version; you should benefit from the up-dates). Check out my log (HMS Sophie). The interesting part is the back end that has to be bulked up to accommodate a quarter deck and captains cabin. Otherwise, the build is pretty straightforward according to the kit instructions. Tom -
Something to do with where the boiler has to be?
- 732 replies
- Lula
- sternwheeler
,I should have mentioned that, too. Good eye/hand coordination!
- 496 replies
- minesweeper
- Cape
Good idea on the sub decking. Your idea of heating the glue is new to me. Good luck. Tom
- 496 replies
- minesweeper
- Cape
Gary, I’m late to the party, and I’m reading that you are dealing with stiffness in the shrouds. Some folks put a little water on them to make them more pliable. Tom
- 422 replies
- Vanguard Models
- Sphinx
I've done the lower fore shrouds. I thought serving them was going to be a challenge inasmuch as the serving thread was so small. But, no, with Chuck's little machine it turns out to be quite simple. That part was easy. Everything else, as always, I seem to have to do 2-3 times to get it right. In setting the upper deadeyes, I used the usual spacer. And that works OK, but Druxey has a different approach that he outlines in his TFFM vol. 4 and his Speedwell book vol. 2 that I think I'll try for the main shrouds. The benefit I'm looking for is a neater appearance of the seizing around the shroud above the deadeyes which can be done off the model. I think before I do that I'll rig the truss pendant on the fore yard, using Toni Levine's excellent tutorial.
- 347 replies
- Sophie
- Vanguard Models
